Question about Brother MFC 210C All-In-One InkJet Printer
Scanner i went to the brither website and downloaded the scanner driver, and i installed it, but everytime i try to scan. nothing happens...worried...and don know what i'm doin wrong... Thanks,
Does the pc auto detect device? If not the port may be blown . Try it on another machine .Or maybe the cable is perished
Posted on Jul 31, 2007
SOURCE:
Suddenly stopped scanning and gave error message that scanner not connected. This is not true. Went on HP website. Useless. Says there is no scanner attached to computer. Yes there is. I have used it for...
The scanner has a separate driver as does the printer portion. They are installed separately. Download the scanner driver or re-install the disc that came with your printer.
Nov 26, 2010 | HP Photosmart 2610xi All-In-One InkJet...
Printer works scanner does not
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Scanner:
  • Unplug the Scanner cable from the computer.
  • Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications
  • after installing drivers and software it will ask you to connect the Scanner.
  • then you can connect the Scanner and and try to Scan.
Hope this help. Please Rate My Response! Thanks!
Aug 20, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hp f340 will not scan
Scanner: Hi there, " Unplug the Scanner cable from the computer. " Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the Scanner. " then you can connect the Scanner and and try to Scan.
Aug 18, 2009 | HP Deskjet F340 All-In-One InkJet Printer
Can't use scanner
  • Hi there,
    GF
Apr 27, 2009 | Office Equipment & Supplies
Can't scan properly. Scanned item fragmented
PREM
Mar 23, 2009 | Canon PIXMA MP830 All-In-One InkJet...
EPSON STYLUS CX4800
You need to download a "Twain Driver and Epson Scan Utility" from
the Epson Website.
But before you start downloading the Twain Driver we need to delete
the previously installed driver in your computer.
1.) Click and open the MAC or Apple Hard drive / Application and trash Epson Scan and Epson Scanner Monitor ( drag it to your trash )
2.) MAC hard drive / Library / Image Capture / Twain Data Source., we need to trash ( *.ds file )
3.) MAC hard drive / Library / Application Support., trash the Epson Scanner Module
4.) Disconnect the connection ( USB ) between the printer and your MAC.
5. ) Empty your Trash bin and restart your MAC
After the restart we can now download and install the Twain driver to your MAC.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=58606&prodoid=56291067&infoType=Downloads&platform=Macintosh
After the installation try to launch Epson Scan under Application
Feb 10, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Visioneer scanner
You find the drivers here.
You need to register into the website first.
Then you login into the website above and chose the option save to HD to get the download.
Oct 04, 2008 | Visioneer 4400 Flatbed Scanner
Scanner blocks when scanning a bar-code
the metrologic scanner you are talking about has a barcode in the maual under the keyboard wedge section it is called stand alone keyboard this will cure your problem when you scan it. the reason being it fools the scanner into thinking there is a keyboard connected. hope this helps Pete
Aug 16, 2007 | Metrologic Instruments 9520 Voyager
Brother MFC 210C All-In-One InkJet Printer Logo
James Cagle
James Cagle
Jim Keysor
ctnozil
