Question about Garden
Have a McCulloch 3818 chainsaw. when it warms up it wants to die and then after restart after restart after restart, it boggs down. Air filter is clean Spark plug is fine new gas hose cleaned carb
  • dontbother10
    dontbother10 May 11, 2010
    Good answer roller. this may help: Carburetor Adjustment by Madsens.comhttp://www.madsens1.com/saw%20carb%20tun... CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly. Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run. There are 2 wav (sound - idle & full ? may not be highlighted) files that I find most helpful, I think you will too. Lou
Had this problem with my saw (3818) there are two adjustment screws on the side of the carb there is a hole in the plastic to get to them just fwd of the choke slide, not the idle adjustment which is farther fwd of the other. take a 1/8" flat head screwdriver, get the saw running and turn them ever so slightly till you can get a good idle, they only have a 1/2 turn of adjustment each, it doesnt take much
Posted on Jan 14, 2010
    President:
  • 2,220 Answers
Let us try this again. Good answer roller, this should help:
http://www.madsens1.com/saw%20carb%20tune.htm
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
Lou
  • dontbother10
    dontbother10 Jan 14, 2010
    I feel like a trout roller. Please look at the date, this one a year old. LOL
    Lou
    Still a good answer.
    President:
  • 2,692 Answers
Get a compression gage and see if the compression is to specifications. May two stroke cycle engines wear quickly due to the light oil ratio we presently use on them.
Posted on Jan 31, 2009
Ajust carb on mcculloch chain saw 3818
Turn in air/fuel adjustment all the way in and then
turn screw out 1 and a half turns out
Dec 03, 2014 | McCulloch Garden
How do you change the gas tank on a mcculloch 3818 chain saw?
Unfortunately the saw has to be mostly disassembled down to just about the block... You MAY get by leaving the carb and intake assembled. After removing the filter cover and filter, start by removing the top of the handle to expose the throttle linkage and trigger locks. Use an I-phone if possible to document every angle you can imagine to make sure reassembly is easier. The guide bar and outer side cover as well as the handle may even have to come off on this saw. The recoil as well will have to be removed. The fuel lines will have to come off the carb as well as the tank vent. Go slow and take a lot of pictures....It's not that difficult. Be sure to have the correct torx or allen head wrenches along with long needlenose pliers and possibly a phillips scredriver. Pick up a couple spray cans of carb cleaner to thoroughly clean the area prior to starting the project and plug in the air compressor. You are gonna need it.
Sep 01, 2014 | McCulloch Garden
Troubleshooting chainsaw
Check that fuel mix is correct ( one part oil to 5 gal gas), check to see if gas is stale, check fuel filter, check carburetor filter, if all else fails then take unit to a repair facility to make adjustments to the carb. If it starts and does not idle and just bogs and dies then adjustment for the throttle needs increased, if your carb only has the (L) adjustment. However if adjusted by a non professional incorrectly these settings can be hazardous to the unit and may cause a possible lean seizure. A lean seizure is caused by the working temperature of the chainsaw that can or may exceed 1100 degrees, normal temps are between 900 and 1100. At 1100 the piston swells and scores the cylinder walls and seizes.
Aug 23, 2014 | McCulloch Garden
Mcculloch parts diagram
You may download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
User manuals McCulloch Service
I trust this information proves beneficial.
Aug 19, 2014 | McCulloch Inner Bar Plate 2318 2316 2118...
Saw idles ok just when i pull the triger it boggs down and stalls
idle settings isnt ok! Air/Fuel mixiture problems- Or - It can bea a problem with crancase sealing, Ther is maybe air leak!
Mar 07, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I have a Mcculloch 16in maccat 35cc chain saw
Does the chain turn freely by hand? Is it being oiled properly? Check the fuel filter, air cleaner, and muffler for plugging. Does 'feathering' the choke make any difference? If it helps, try turning the H jet needle CCW about 1/4 turn which should make it run more rich and 4-stroke until you are cutting which should immediately cause the engine to 2-stroke. Hope some of this helps!
Jul 21, 2010 | McCulloch Garden
My mcCulloch mini mac 25 starts, runs, and cuts, but when it warms up it dies and will not restart
It sounds like the fuel cap is clogged. The fuel cap must be able to breathe in order for the carburetor to operate properly.
One way to be sure that it is the fuel cap is: The next time the chainsaw starts to die, loosen the cap for a second or two, it should start running properly again.
Jim
Jun 19, 2009 | McCulloch Garden
Runs but boggs out when given gas
If you don't already, pump the primer/purge till it's full of fuel before starting
Apr 05, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Garden Logo
742 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
