Question about Epson Stylus CX9400 Photo Printer
Epson Stylus CX9400 Fax
The scanner function is not working. All else (printing, copying and faxing) work fine. When trying to open the scanner I get an error message saying not able to start. Computer (running Vista) reports scanner in not connected. I've hooked up to an XP computer and scanner works. On the Device Manager (Vista) the Epson Scanner is listed under "Other Devices" -- with a yellow '!' When right clicking on the icon and pulling us 'Properties" you get this message: "The drivers for this device are not installed. (Code 28) The system cannot find the file specified." I have installed and reinstalled drivers several times. Still no luck.
  • 6 more comments
  • prgerhard Feb 09, 2009
    Thanks for the suggestion. I followed all the steps, and the scanner is still not working.
  • Dcwarz Feb 10, 2009
    I have the same problem and went through over an hour working with an Epson support person to no avail.
    Scanner works on XP and with my wifes HP running Vista but not with my new Dell 530. I used PC Mover to move over programs from my XP machine to the Vista machine. Everthing else works but the Epson scanner. We uninstalled software, removed registry sections, deleted any remaining Epson traces but scanner still won't function.
  • prgerhard Mar 02, 2009
    Follow up on my epson scanner issue (from Jan. 31). Went as far as removing all Epson files from the registry. (followed directions from Epson).
    Had to re-read Dcwarz post from Feb. 10 because the same exact thing happened to me. With using PC mover and having scanner work on my wife's HP running Vista. Have tried all the above and still not able to get scanner working.
    prgerhard
  • Anonymous Mar 16, 2009
    Dcwarz here,
    Tried uninstalling, reinstalling, and it tries to install the new drivers but stops along the way noting it found the driver but encountered an erroe while attempting to install it.
    I was on the phone with Epson for over an hour to no avail, on this issue. They don't know what to do. I suspect it is a Vista USB issue because I just install a Logitec webcam and Vista won't recognize the integrated microphone but did accept the Video driver.
    Searching the internet there are a lot of USB issues with Vista and not much help from Microsoft on the problems. I should have stayed with XP on my new PC.
  • prgerhard Apr 08, 2009
    Sorry folks. Tried all three Options from: Smithbrother; Van_Fanel and Bunso26 -- Still no luck. Scanner works fine on wife's HP, but not on my Dell.
  • Dcwarz May 11, 2010
    Van...... I tried your suggestion several times, even uninstalling the Epson all together. However, when it trys to install the driver an error message still comes up stating "Windows found driver software for your device but encountered and error while attempting to install it." Then it lists the Epson printers for the driver driver such as CX0400Fax. And "The system cannot find the file specified.
    This same error message comes up with my new Logitech web cam for the integral microphone. The webcam works fine but it won't install the microphone.
    For both I've identified the new Vista 32 drivers but the install is stopped during the install process.
    Dcwarz here,
  • bbrako May 11, 2010
    epson stylus cx9400 photoprinter/fax will copy from computer but not from scanner error message appears after turning off & on scanner error has occurred. see documentation.
  • 25 Answers
From your Win Vista Computer;
1.) Try to uninstall ( epson scan ) in the Control Panel / Programs and Features ones it is removed.,
2.) Download TWAIN Driver and EPSON Scan Utility v3.20A > epson12384.exe
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=90753&prodoid=63070382&infoType=Downloads&platform=Windows
3.) Ones it is downloaded and installed to your computer., try to launch epson scan ( if same issue persist )
>> On the Device Manager (Vista) if the Epson Scanner is listed under "Other Devices" -- with a yellow " ! " < right click on it and click on update driver., make sure that the option selected is " Install the software automatically (Recommended) and then press next > ..... you may need to restart your computer after this procedure..
>> Then try to scan again
Note >> if a pop on your computer for ( New hardware Found ) just ignore it / close it., after the scanner driver is installed it will go away.....
Posted on Apr 08, 2009
  • Rheidell Reyes
    Rheidell Reyes Apr 08, 2009
    Additional work around., I was not aware that you have a web cam connected or installed to your computer......
    Note ::>> camera, video camera, web cam, scanners are Imaging devices
    You could try to disconnect other Imaging devices to your computer when your attempting to install the
    Epson Scan to your Computer., make sure the only printer connected is the cx9400f
    Problem Solver:
  • 7 Answers
I believed that you're having this error
"Epson Scan Cannot be started...."
This issue is usually happened when there is a previous epson scanner driver installed or other imaging devices attached or installed to your PC. Here is what you can try to resolved your issue
1. Make sure that driver is indeed installed, then go back to Device Manager.
2. Right click on the Epson Scanner then update driver
3. Select the option that says AUTOMATIC and it will try to detect the driver that you've installed, if it is successfulm it'll copy the files necessary and after that the CX9400F will appear now under Imaging Devices in your Device Manager.
4. After that you might wanna restart WIA (Windows Image Acquisition). To do this go to your Control Panel and look for Administrative Tools, look for Services and on the LONG list, scroll down and look for WIA then restart this service.
5. Re-launch Epson Scan and have fun scanning.
Hope this helps
Posted on Mar 16, 2009
    President:
  • 2,692 Answers
Download the VISTA driver that you need. Either 32 or 64bit. Epson web link for your model below:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=90753&prodoid=63070382&infoType=Downloads&platform=All
Posted on Feb 07, 2009
  • Thomas F. Schneider Feb 10, 2009
    You have alread rated me but, I was still wondering if you disconected the printer/scanner then uninsrtalled the software through the "add and remove programs" then reinstall the software that you downloaded for VISTA.
      Another question that comes to mine is does it still show the driver to be missing?
    Lastly, have you gone to the Epson website to the Q&A and found you problem listed there? I have never seen this problem after installing the corrected driver(s) but I doubt you not.
      I would write to Epson,since they claim compatability with yuor VISTA for your model.
3 Suggested Answers
Beni S-P
  • 1006 Answers
SOURCE: stylus cx3900 and windows vista
Here u go  :
http://www.driversplanet.com/os.php?os=vista
and if u not get help just try live asistance with me and i will fix ur problem ;)
Posted on Oct 25, 2007
Rain041304
  • 63 Answers
SOURCE: Scanner Not Recognized
You need to remove the yellow question mark on the device manager. Click on the plus sign of the Question mark icon. Right click on the item that will be displayed under the question mark and then uninstall. You need to uninstall the drivers as well. you can doo it on add/remove programs(winxp) or program features (vista). Unplug the USb cable/ Download drivers from support.epson.com and you just need to choose the right driver for your windows version. After Installing the TWAIN driver and Epson scan utility, you need to restart computer. When computer is ready you can plug in the usb cable and open up Epson Scan on your desktop
Posted on Feb 07, 2008
How to open up an epson 9400fax to clean
Page 16 of the manual shows you how to properly clean your Epson Stylus CX9400.You can view the manual here:
http://www.manualbuddy.com/3570/epson-stylus-cx9400-fax-user-manual
Jan 30, 2013 | Epson Stylus CX9400 Photo Printer
Why is my fax machine not working? it reads no dial tone when i try sending a fax and i cant recieve either
make sure it is plugged in right in the back.try using a different phone jack in the house
Jul 12, 2009 | Epson Stylus NX300 All-In-One InkJet...
Scanner bulb doesn't turn on during a scan
You can try to get and replace the scanner light. If it was the light, the new one will work. If it was some other electonic component that shut off the light, then the light won't work. Depends on the cost of a new light compared to getting the unit serviced by a tech. Or the cost of a new Multifunction unit. Do some research before you make the decision.
May 31, 2009 | Epson Stylus CX9400 Photo Printer
Printer prints blank sheets
I would suggest resetting the printer options to Default first. If that doesn't do it then reinstalll the complete printer software and be sure to deleted all the old software. To delete files completely download <AppCleaner> it's free and is fantastic. Your last resort is to then call Epson Tech Support.
Apr 04, 2009 | Epson Stylus CX9400 Photo Printer
Can't fax out on my Epson Stylus CX5800X
Verizon is lying to you. Fax machines are analog devices.
Mar 14, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson cx9400 printer/scanner/fax
Follow these steps to print a nozzle check:
  1. Load letter-size paper in the sheet feeder.
  2. Press the cp_button_1.gif On button to turn on the Epson Stylus CX.
  3. Press the Setup button.
  4. Select Maintenance and press OK.
  5. Select Nozzle Check and press OK.
  7. Press the cp_button_6.gif Start button to print a nozzle check.
  8. Shown below are some examples of what the nozzle check may look like.
Mar 01, 2009 | Epson Stylus CX9400 Photo Printer
EPSON CX9400
Did you hit the Auto Answer button? The green light next to it should be on.
Jul 30, 2008 | Epson Stylus CX9400 Photo Printer
Cx9400fax
Epson Quick Guide is incorrect.
Not sure of your exact situation but .........
Your answering machine MUST be connected directly to the output of your CX9400 and you can't use an answering machine with multiple "mailboxes". Set your answering machine to 4 and your CX9400 to 5/6 rings. Epson "Technical Support" has no clue of this problem .... yet.
The machine routes the call to your answering machine, it it's an incoming FAX and the answering machine starts the CX9400 will recognize the incoming transmit signal, turn on the FAX function, and disconnect your answering machine.
You may need to adjust the CX9400 rings setting based upon the duration of your answering machines announce message (longer message = greater number)
Jan 28, 2008 | Epson Stylus CX9400 Photo Printer
Epson Stylus CX9400 Photo Printer Logo
814 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
