Question about Hotpoint WMA30 Front Load Washer
Zanussi IZ12 mid program door light comes on.
Mid program door light came on, error E40 shows. No water in machine and can't open door...full of washing..Help!! is there any way of opening the door manually or overiding the door??
Simon.
  • Hotpoint Master
  • 3,463 Answers
E40 is a door interlock fault, it is either faulty or the wiring between it and the main board is at fault,
Only way to open door is to remove top cover, and try to force the door open from the inside, if you can see the door latch, try pushing it with a screw driver or something to release it, worst case scenario, is you will have to break the lock to release the door.
Please rate my fixya solution.
Thanks.
Posted on Jan 31, 2009
Door opens mid cycle??!
This video will show you how to open your Zanussi Progress ZWG3121washing machine door that is stuck shut
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 27, 2013 | Zanussi Washing Machines
Hi! I have a Zanussi IZ12 washing machine. After I turn it on, the door will not open and start/pause button just flashes. (I can select program and press start/pause, it just beeps, but the machine do...
I've had the same problem. I removed the top lit and found some pressure transmitter and a pressure switch. I suspect that the pressure transmitter is use for measuring the waterlevel in the machine. I think the membrane loses its flexibility over the years.
I pulled of the hose from the transmitter and blowed and sucked a few times on the transmitter. After doing this the machine washes without a problem since then.
Hope it helps for you.
Jul 14, 2010 | Zanussi IZ12 Front Load Washer
Machine stopping mid cycle
Count the number of green flashes(1st number of error code). count number of red flashes(2nd number of error code).
Common codes are:
E10 or 11 water pressure faults.
E20 filter/pump faults.
E30 pressure switch/heater faults.
E40 door switch faults.
E50 motor faults.
E60 Heater faults.
These are some of the error codes but there are many variations on some codes depending on the model.Hpoe this has been some help.
Apr 24, 2010 | Zanussi ZWF10070W Front Load Washer
Unable to use ZJ1217, start/pause flashing
Are you able to open the door ?if so door interlock switch could be at fault
Oct 02, 2009 | Zanussi ZJ1217 Front Load Washer
Zanussi aquacycle 1000 start pause button
Try some WD40 on the door lock on machine (not on the door) & open and close a few times. Of course the mains plug should be off the wall socket.
Feb 28, 2009 | Zanussi IZ12 Front Load Washer
Washing machine keeps stopping mid wash and coming up error (32 motor surrisc) zanussi keeps stopping and reporting E32 as a fault, how do i fix this?
Hello
ALARM CODES
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Feb 26, 2009 | Zanussi ZWF1430W Front Load Washer
Error`E40
hi there e40 fault is a problem with your door interlock. get it replaced and all will be fine..
Feb 28, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
E40 error code
The E40 error code indicates a loss of electrical power usually but not always due to the door not shutting properly or not locking. But, since you smelled burning it could be any electrical short that blew a fuse and shut the machine down. It could also be the motor windings with the internal overload protector shutting it down.
Dec 16, 2007 | Zanussi ZWF1440 Front Load Washer
RE: ERROR E40 ON ELECTROLUX ZANUSSI JETSYSTEM 1200
hi there e40 fault could either be your door interlock or main pcb
Dec 11, 2007 | Zanussi FJS1225W Front Load Washer
Hotpoint WMA30 Front Load Washer Logo
250 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
