Question about Pioneer PDP-6070HD 60 in. Plasma Television
My 60''pioneer plasma blinks 12 times after i turn it on
When i first turn it and i touch the input button it tells you it is warming up then it shuts down after about a minute then the blue light will blink 12 times
  • 1 more comment
  • dslater7 Feb 02, 2009
    pioneer tech dept. is no help
  • thielectronick
    thielectronick May 11, 2010
    I think this might be a software issue, I would start by contacting Pioneer at 1-800-421-1404
    They're typically really helpful. If you need indepth troubleshooting let me know.
  • Anonymous Mar 15, 2014
    My Pioneer 151fd blue light blinks 8 times, won't turn on, troubleshooting guide no help
  • 505 Answers
Looks like 12 blue blinks is a communication with the Digital tuner error. pioneer had a software upgrade/fix for this in some cases, others might need a new digital tuner pcb. I would unplug all power, wait 5 min, plug in (wait1 min) and try it again. If it is software, it should hopefully work. Make sure you pull your cable card if you have one. If it still won't turn on, you probably need the digital tuner board = $200-500 repair. Pioneer is usually very helpful, I'm really surprised they didn't help at all.. They'll want model #, serial # and date of purchase.
Posted on Feb 03, 2009
I was watching TV it shut off and the power button flashed a bunch. I unplugged it waited for a while plugged it back in. It did not turn back on until i held down the menu button on the set.
I found the following blog on the web.
Panasonic Viera Plasma Failure Page
November 14, 2010 ·
Blink Codes and what they mean (8-13):
8 blinks Driver SOS 3 SS Board (SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG BoardDTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Boardwith IC8001
Make sure the inside of the TV is clear of DUST especially by the power supply and fins.
May 02, 2015 | Panasonic Viera Tc-p42x5 42" Inch Flat...
Find activation code for pioneer
My pioneer 5020FD Kuro tv. when I plug power to the unit, a blue light blinks 8 times pause 2 sec. and blink 8 times repeating this and if i press power button it clicks red light and makes a clicking sound and goes back to the blue light blinking again, it did this once before and the picture came on fine until i turned it off and now it just blink the blue code.
Dec 10, 2014 | Pioneer PDP-5020FD 50 in. Plasma HDTV
For the last 24 hrs, our 50 in plasma has had no picture,no sound, but yet a blue light blinks 12 times, pauses blinks 12 times,what does this mean
Pioneer has this to say about the issue:
"On the models listed below, Engineering has determined this to be part of the normal operation, if the unit will power on.
If the unit does not power on, service may be required on the set.
Please contact our Plasma support at 1-800-421-1625.""
Elite models:
PRO-940HD, PRO-1140HD, and PRO-1540HD
Pioneer models:
PDP-4270HD, PDP-5070HD, and PDP-6070HD
Good Luck
Thomas
Dec 02, 2013 | Pioneer Televison & Video
My tv will turn off by itself every 30 mins and has a blue light that blinks 12 times! how do i fix this problem?
yr sleep program is on. Find this in the menu and turn off. It is also on yr remote, u can turn it of from that just take yr time and work out which is the sleep mode button and click until the screen shows off or something similar. cheers
Aug 14, 2012 | Pioneer Elite PRO-950HD 42 in. Plasma...
Pioneer PDP-436PU TV blinks red 10 times
Most likely a bad power supply board= you are going to have to find a Pioneer dealer to get it fixed or even get the part--many shops including the one I work for will not touch this brand of set.
Apr 25, 2012 | Pioneer PureVision PDP-4340HD 43 in....
Just moved and rehooking up the plasma. Plasma does not turn on/has no power. Cable box plugged in, power cord rechecked to ensure plugged in correctly and checked power cord it has 110/120 at the plug...
Check that the outlets "GFCI" fuse or reset button hasn't been triggered. If this isn't a GFCI outlet, then verify the breaker is on. If still no luck, verify the device input power i.e. 110/240V
Sep 26, 2017 | Pioneer PDP-6020FD 60 in. Plasma TV
I have an Elite faltscreen television that has been working well for over one year. For an unknown reason, the blue light (next to the on/off switch0 is blinking and the TV is not responding or turing...
Please count the number of flashes of the Blue LED. It will flash Ex. 12 times and pause for 2 seconds and then flash 12 times again. The number of times it flashes will tell me more as to what the solution is. I am assuming the set works otherwise ?? What is the model number of the set ?
Scott
Feb 14, 2009 | Pioneer Elite PRO-1540HD 60 in. Plasma...
Plasma Display Starting Up
Could be heat build up in the Plasma display unit. Make sure it has the correct space around it for proper ventilation. Also count the number of blinks on the power indicator it is a code for the reason the unit shut down. On the Pioneer PDP-5060HD I have I was getting 12 blinks on the indicator which indicated a tuner issue. Check your instruction book for info on the over heating problem if it continues. You may have a fan out.
Apr 29, 2008 | Pioneer PDP-5060HD 50 in. Plasma...
Pioneer Plamsa CMX 43"
pioneer customer service: 800-228-7221
C-Dog
Feb 10, 2008 | Pioneer PureVision PDP-4340HD 43 in....
Pioneer PDP-6070HD 60 in. Plasma Television Logo
2,436 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
