Question about Canon MultiPASS C2500 InkJet Printer
Not printing at all
Canon MultiPASS C2500 INKJET PRINTER/FAX MACHINE will not release the ink from the new ink cartidge. Will pretend to print everything is working but no ink!?
  • 3 more comments
  • Rainey chubak Jul 31, 2007
    yes i did!
  • Rainey chubak Aug 03, 2007
    Not helping sorry!
  • Dara Dee Dec 29, 2007
    I just received a MulitPASS C2500 that my job was giving away. It sounds as if it is printing, but when the paper comes out it is blank. I purchased a remanufactured ink cartridge, removed the tape and all from the cartridge, did the head cleaning as suggested, but nothing is working. I have installed the work around (Cannon Bubble Jet BJC-4000) as well. I am running Windows XP. What do you think is the problem?
    Dee
  • TenForty Mar 08, 2009
    I have exactly the same problem and I have seen it with several other Canon printers. One day stop printing even with brand new cartridges. They go thru the motions but absolutely NOTHING prints. It almost seems as if it might be a distance adjustment (cartridge to paper or something like that).
    I have exactly the same problem and I have seen it with several other Canon printers. One day they simply start going thru the motion but outputing blank pages even with brand new cartridges. It may be something about the distance of the head to the paper or who knows what.
    President:
  • 317 Answers
This might sound a little obvious, but I've seen it before. But did you peel off the plastic covering from the cartridge before you installed it?
Posted on Jul 31, 2007
  • 1 more comment
  • Peter Burns Aug 07, 2007
    Try to perform printhead cleaning
    1. Press .
    2. Press (One-touch button '13').
    3. Repeat steps one and two at least 5 times.
    Then Check the status of the print head by printing a test page.
    The test page confirms whether sufficient ink is still in the cartridge (or tank) and if ink is ejecting from the print head nozzles.
    1. Press . The key is located at the top row of the One-touch buttons on the right-side of the control panel on the MultiPASS.
    2. Press the '*' (asterisk) key on the dial keypad.
    If none of this works, you'll need to return that ink cartridge and get a new one.
  • Peter Burns Aug 27, 2007
    Thank you Zt3000, I agree. It makes me not want to give advice if people aren't going to except it and just give me a not helpful rating.
  • Peter Burns Oct 11, 2007
    When troubleshooting a problem, it's common to try different solutions.
    Why rate me as not helpful so quickly? Don't you want to try other
    solutions that I have for you?
    Scholar:
  • 76 Answers
I think Jmorgan123 provded the correct final answer. Get a new ink cartridge. Not sure why the poster gave the knowledgeable advice a "Not helpful" rating.?? (when they accepted the answer later by someone else)
Posted on Aug 19, 2007
SOURCE:
What's your problem? After having had "wrong
Did you take the tape off the new cartridge. For the ink to flow. not trying to be smart it is easy to forget.
Sep 12, 2017 | Canon MultiPASS MP730 All-In-One InkJet...
I have a Canon MultiPass C555 InkJet Printer for my fax machine in the church office. I don't know how old the machine is. Whenever I receive a fax I cannot read it. I even change the ink and I still...
These machines have an integrated printhead built into the printer. The only way to try to fix this issue is to run the cleaning function anywhere from 3-7 times. First, remove the ink cartridges and depress the sponge side onto a paper towel. If you see ink on the towel, proceed to the next step. If no ink is present, replace the ink cartridges. They can be found for very cheap on this model. Next step, depends on whether or not the machine is hooked up to a computer or is just a stand alone fax machne. If it is not hooked up to a computer, go to the menu, scroll to maintainence and select clean cartridges. You will need to do this multiple times. Continue to do it if you see improvement, until you are satisfied with the print quality. You an also perform the cleaning from a computer. Locate the printer in the printer folder and right click on it. Select properties. At the bottom of that window, select preferences. Then select the maintainence tab, and select clean cartridges. Again, you will need to do this multiple times. Please advise if you need further help, or if this does not work and you would like info on current fax machines.
Sep 30, 2010 | Canon MultiPASS C555 InkJet Printer
Canon Multipass MP730...placed new ink cartridge in twice now...nothing be printed...what could the problem be?
For me, there can be 3 problems, and I will do what I do in order.
1. The print head may be clogged. To unclog it, you have to remove the 4 cartridges, remove the print head (lever up, and remove the printhead), run those silvery things under a luke warm tap and low flow and pressure for about 5 minutes or until no ink drips out, and dont aim for those silvery things, do not touch the contacts on the back. Install the printhead, cartidges, lever down and go for it.
2. Well still no results... Get the printhead out of there again as your machine is getting old and tarnished. Get a sharp knife. Stroke down on those contact things downward only with your knife, a couple of columns at a time, couple of strokes per column. Put everything back, lever down, and go for it.
3. A new print head $50. Sounds a lot, but the last cartridges were $1.69 a pop. These cartidges last quite some time, as long as you fire something through the printer each week. This has to be the most economical bubble jet printer in the world. I have 3 of them.
Jun 16, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
My printer wont print after i put in new ink
My printer will not print after I put in a new cartidges it is a Canon
iP1700.
Sep 13, 2009 | Canon PIXMA MP460 All-In-One InkJet...
HOw do I print a fax transation history report from a standalone canon multipass c3500 ?
I do not know for you particaler machine. May i sugest a hp officjet all in one printer or the officjet pro series.
May 01, 2009 | Canon MultiPASS C3500 All-In-One InkJet...
How do I install a new cartridge holder?
Click this link for a service manual free download for your multipass c2500 inkjet printer troubleshooting.
This will help you replace the holder.
If you cannot click just copy and paste the following link into your browser window.
http://www.nodevice.com/search.html
Apr 30, 2008 | Canon MultiPASS C2500 InkJet Printer
Error on screen INSTALL CARTRIDGE
Go here for a download of the service manual for your canon multipass c2500 inkjet printer.
If the link does not work, go here.
Feb 15, 2008 | Canon MultiPASS C2500 InkJet Printer
Ink flow is not good from cartdrige
sometime the head printer gets clog so what you have to do is go to maintance and there should be a program that will clean your heads on you printer then run a test run with you printer.willie
Aug 31, 2007 | Canon MultiPASS C70 All-In-One InkJet...
Canon MultiPASS C2500 InkJet Printer Logo
54 people viewed this question
Clive
Clive
old marine
old marine
Ekse
