Question about Bosch PowerStar AE9.5 AE9.5 Point-of-Use Electric Tankless Water Heater...
Connecting a AE9.5
Specifications tell you to use #8 wire for 40A. Do I use #8/2 or #8/3 wire.
Thanks Paul
  • pplasschaert Mar 31, 2009
    Hi muttandjeff,
    Having followed your advice the water heater worked perfect. Problem arose soon after installation. The thermal kickout switch needs to be reset about ones a day. Bosch service suggested to backflush unit..it did not solve the problem. Use only one heating element...it is not hot enough ,120F. After 3 contacts with Bosch service to resolve this problem the lady service tech?? cut me off with "Good luck sir have a nice day" after I told them about the elements are only 10.7 Ohms and produce much more heat than specified at 240V. (Measured 190+F). Thermal switch will kick out about 1 min after shut-off I observed.
    In all the unit heats but I did not sign up for all this hasle and then be rebuffed by my friends at Bosch.
    Sergeant:
  • 359 Answers
I would use # 8-2-with ground to have positive grounding at device , not 8-3 witch is more costly , also copper only no aluminum
Posted on Feb 01, 2009
Sequencer wiring
This manual provides specifications of the timers and contacts, and a description of the 3 types of contacts.
http://s3.supplyhouse.com/product_files/White%20Rodgers%20-%2024A34-6%20-%20Install%20Instructions.pdf
Mar 05, 2014 | White Rodgers Water Heaters
In bain marie no output from relay
You can use the 40amp....remember the relay can handle up to 40amps. This is controlled by a fuse that is installed in the device.
Dec 24, 2013 | Hatco Food Rethermalizer/Bain-Marie Heater...
What size wire and how does it hook to thr unit rpkb-036jaz
Look at rating plate on side of unit for Volts, Amps, Watts.
Volts x amps = watts.
If unit is 240Volts, then you need double-pole 240Volt breaker
If unit is 8500 watts at max power, then 8500 watts divided by 240Volts = 35 amps.
What size breaker for 35 amps?
When electricians figure load rating for breakers, they use the 80% rule.
40 amp breaker x 80% = 32 amp safe maximum load for 40 amp breaker. Use 8 gauge wire with 40 amp breaker.
50 amp breaker x 80% = 40 amp safe maximum for 50 amp breaker. I use 6 gauge wire with 50 amp breaker.
60 amp breaker x 80% = 48 amp safe maximum for 60 amp breaker. Again, use 6 gauge wire with 60 amp breaker.
How to connect wires to unit.
First of all, all outdoor HVAC units require power cut off located next to unit.
This lets the mechanic, or service tech turn power off to work on unit, even if the mechanic does not have access to main breaker box.
Next, open unit to see where wires connect.
If unit has wires, then connect both hot wires from 240 breaker to the wires inside unit. Connect bare ground wire to green ground screw.
If unit has terminals. The terminals will be labeled L1 L2. Connect each hot wire from 240Volt breaker to either one of the screw terminals. Then bare ground goes to green ground screw.
Copy following links for basic illustrations connecting wires to terminals, and to breakers, and selecting wire size.
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
Jul 21, 2012 | Rheem R-410A Complete Split System Heat...
No hot water. Display reads ER3.
Hi, If you have the book for this system, then go to the problem solving to the rear of manual. This will tell you what code ER3 means, and what you need to do to correct it.
If you dont have the manufacturer's book then try to down load it!.
All boilers and water heaters have different fault finding codes, so can-not give any more info, unless you can tell me the exact problem.
Thanks Paul.
Aug 22, 2010 | Water Heaters
Model RE2424 W-Z (SP) one the 2 remote controllers is not displaying any power lights or 2 digit display. The other unit still works and the heater unit is functioning ok. Would like to get the other...
Disconnect both controllers. Put the one that works ok on the wiring supply to the one that isn't working. If it does not work you have a wiring problem. If it does work then the controller is faulty. This wiring is 12volt low amps by the way. When connecting the wiring can go either way on to the back of the controller. Don't let the two wires touch if the power is on to the heater, this can blow the circuit board on some older models.
Aug 05, 2010 | Rinnai Digital Remote Water Heater Control...
After installing my titan N100 the breaker keeps tripping went from 50 amp breaker to 60 and still keeps tripping how do Isolve this problem?
You had an instant heater there before? Or a different type? Your breaker numbers don't mean anything to me, I need amps and volts, what is the amp? 30? and the volt is 220? Or are you in Europe?. And you had the four wires in there before? And you have all 4 wires on the heater line? And the heater is grounded? It should work. Unless it is not getting enough juice, but you already upped the amp. Let me know what you got.
Jul 03, 2010 | TitanNet TITANTANKLESS. COM PRESENTS THE...
Re-connecting heating element wires
two screws on the element ... two wires ... in most cases. You probably have 220 volts, make sure it is off.
Apr 21, 2010 | Water Heaters
What size ground wire needed for A 120 AMP MAX CIRCUIT RUN WITH # 8 wire?
look at your voltage 120 volts, or 240 volts, then amp rating. #8 THHN wire, or #8 romax is only rated for about 40 to 50 amps, your ground wire would be a # 12.
Oct 25, 2009 | Water Heaters
Bosch PowerStar AE9.5 AE9.5 Point-of-Use Electric Tankless Water Heater... Logo
107 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
