Question about Dell Pentium 3, 500 MHz Pentium III Processor Upgrade
Computer primary and secondary IDE not found
I do installn anty virus software in my computer, the installation went successfully the computer reboot perfectly.the next day when i power on the computer it display primary and secondary IDE not found
    Scholar:
  • 70 Answers
Usually it's a contact problem, try to reattach the cables to the device and see if it helps.
Posted on Jan 31, 2009
Installing purchased Anti Virus program has been challenging. After several attempts to download - no success.
Several firewalls are known to interfere with the download of Anti- Virus software. I recommend you switch it off while downloading and installing the Anti-virus. Some even recommend removing the firewall and installing it after you have installed the Anti-virus.
Oct 18, 2015 | Computers & Internet
How do i restore my compaq presario v2000 to factory condition without recovery CDs, F10 and F11 not working and NO System Recovery option in the start menu
Your computer is infected with viruses. Solution: install and update anti-virus. You can use anti-virus free (Avira or AVG). Perform a virus scan process, with the option, if a virus is detected, the primary action "Repair" and secondary action "Quarantine".
hopefully help
Sep 23, 2011 | HP Compaq Presario V2000 Notebook
Today I installed SATA HDD at red SATA port 1 . But in BIOS, it shows Primary IDE master not detected....Primary IDE slave not detected....Third IDE master detected..I wanna know why my HDD is not detected...
there is no diffrence between primary & third ide hdd ,if you install nay booteble hdd in master so system try to from that frist . boot sequence of motherboard is try to boot from primary master first then Primary slave then secondary master and then master secondary ..................,
Jun 12, 2011 | ASUS P5GC-MX/1333 Motherboard
Whenever I connect any removable drive automatically 4 shortcuts got created of control panel.
You have a virus on your PC. Unfortunately, once you have this virus, it usually does not help updating your anti virus and running a scan since the virus is running in the memory of the PC and every infected file the anti virus removes - the virus just puts back again. Try one of two things to remove the virus:
1] First update your anti virus (if you dont have an anti virus, download the free AVG Antivirus and install that and then update it. Click here to go to AVG's website. Once installed - Boot your pc into SAFE MODE. This is VERY important otherwise the virus will load into memory and it wont help running the anti virus to clean the system as the memory resident virus will just replace any infected file that is removed by the scan. To boot your PC into safe mode: Read this article: Click here.
Once you are in safe mode - Open the Anti-virus console and do a complete system scan.
2] Remove the infected hard drive from your PC and install it as a secondary drive in a clean, VIRUS PROTECTED PC!!! ... i.e .. any pc that has the latest anti-virus system installed and is up to date!. Once you have installed the infected drive in the protected PC as a secondary drive, run a scan on the infected drive and remove the virus.
Once you have removed the virus, also scan ANY USB devices on that PC, including any Cameras, cellphones, photo frames, etc that you might have plugged into the infected PC.
Good luck
Feb 07, 2011 | Computers & Internet
Cloned hard drive "C" (WD 40GB) to A Deskstar 8oGB using external enclosure. When I remove the old drive and install new drive and boot up I get Msg drive 0 not found retry or enter setup. If I enter setup...
there are few thing you ahve to keep in mind
there are two type of hard disk
1. IDE
2. SATA
As per your hdd capacity it should of IDE type.
Now there are two IDE slots on motherboard. One is Primary and other is Secondary
You can fix two hdd with one IDE Slot that mean you can fix up upto faour IDE hdd at a time
Now again there are Primary master and Primary Slave
and
Secondary Master and Secondary Slave
Now You have to examine what was the location of previous hdd
1 Primary Master
2 Primary Slave
3 Secondary Master
4 Secondary Slave.
Now you have to make a HDD master or Slave.
just in between data cable connector and power cable connector there is a jumper. that specify the master or slave. do reply me if it works well thanks
Oct 01, 2009 | Hitachi Deskstar 7K250 80GB...
Cannot find primary or secondary drives
you need to enter the BIOS as the computer starts by tapping del or the keycombo your dell asks for to enter startup or BIOS setup, i vaguely remember f2 or f10, but the combo is posted on the screen as you start the computer.
once in the bios, the first screen should show your harddrive on the primary and your cd rom on the secondary. If you can reset these to "auto", restarting the computer should auto detect them unless a cable is lose inside or you have a virus . try this and post again here...
regards...
Apr 02, 2009 | Computers & Internet
Still needed solution of problem
Go to Control Panel - click on System - Click on Hardware - Click on Device Manager - click on IDE ATA/ATAPI Controller.
Then right click on Primary IDE Chanel - then click on Properties - Then Advance Settings - For the Device 0 in Transfer Mode select DMA if available. Then Click OK.
You can also select DMA for Device 1 too
Feb 09, 2009 | Compaq Presario Notebook
Operates fine, than all of a sudden, the printer disappears.
That sounds a lot like the driver software is unsuccessful in installing or you have something like anti-virus or anti-spyware that is stopping the installation from completing all it's stages successfully.
Try downloading the latest version of the software then disconnecting from the internet before temporarily disabling your anti-virus and anti-spyware software and THEN installing the driver again.
As a general rule it's better to have the printer unplugged from the computer while you do this and then plug in when prompted...
The computer will want to reboot and finish the install so do this when prompted and make a note of any errors you receive if you get any.
Hope this helps.
Jan 30, 2009 | HP Officejet Pro L7680 All-In-One Printer
Setting up a Computer to install Windows XP Professional.
Pedro -
I'll assume each of these is an IDE device, meaning each has a wide connector versus a narrow SATA connector commonly found on newer hard drives.
Your motherboard should have two IDE channels, labeled IDE 1 and IDE 2, Primary IDE and Secondary IDE, or something similar. Each IDE channel can support two devices.
For best performance between the drives, you will want to have the Hard Drive connected as Master(Drive 0) on the Primary IDE channel; The CDROM should be connected as Slave(Drive 1) on the Primary IDE channel. Connect the DVDROM as Master(Drive 0) on the Secondary IDE channel, and the ZIP Drive as Slave on the Secondary IDE channel.
When connecting the drives, make sure you set the jumpers correctly; Both the Hard Drive and the DVDROM should have their jumpers set to Master, the CDROM and Zip drives should have their jumpers set to Slave. An alternative is to set the jumpers for every drive to Cable Select(CS), allowing the physical connection of each drive to determine whether its a Master or Slave device.
*Note*
If your Hard Drive is a SATA device, connect it to the '0' or '1' SATA connector on the motherboard. Have the DVDROM set up by itsself as Master on the primary IDE channel, the CDROM as Master on the Secondary IDE channel, and the ZIP as Slave on the Secondary IDE channel.
Hope this helps!
-thinstatic
Jun 11, 2008 | ASUS P4S8X-MX Motherboard
Computer won't run windows and come up with a trap-handler error
on the IDE Port, set the jumpers to the hard drives/cdrom on CS(Cable Select) this lets the BIOS and the ribbon cable decide which is primary (Master) and which is secondary (Slave) on that IDE cable. if they were configured wrong you would get an error.
If the IDE channel is no good, try switching the primary and secondary IDE ribbon cables.
May 26, 2008 | Intel Motherboard
Dell Pentium 3, 500 MHz Pentium III Processor Upgrade Logo
190 people viewed this question
Alun Cox
