Question about Toshiba Satellite M45-S265 Notebook
How to turn on the 10-key number pad
Just noticed I have keys 7-0, u-p, j-;, and m-/ that show the standard 10-key pad on most keyboards. I can't find how to use it tho. How do I turn this function on?
  • flanaganwill Feb 01, 2009
    all i needed was to know how to turn on and use the overlay numeric pad. I found it was Fn + F11. Thx, anyway.
Does the keys 7-0, u-p, j-;, and m-/ is working under MS-Dos command or not? If not the problem could be the carbon of you keyboard is worn-out, you have to cut the carbon of your keyboard that has connected on the motherboard, but before you cut take off the plastic of the caron atleast 1/2 inc. and cut the old carbon. Make sure that you turn off your power before you do anything. If still the same problem it means that some carbon inside of the keyboard is already worn-out, you have to replace the whole keyboard. Remember if some keys are not working this is hardware related not software nor setting.
Posted on Jan 31, 2009
How to work key pad
Key pad? Do you mean the keyboard or what?
Mar 21, 2016 | Dell Inspiron 1525 Notebook
How to unlock keyboard?
press numlock button once
Mar 04, 2015 | Computers & Internet
When my number lock is on the letters will not print as stated they will print a number or other
This is normal for a keyboard with embedded number pad, rather than a separate 10-key area. Turn off the number lock to type the alphabetical characters and use the top row of numbers to enter values. Turn on the number lock when entering only a long string of numbers.
Alternatively, connect a USB external keyboard to the notebook. Either get a large keyboard with a separate number pad or get a 10-keypad only (http://www.cyberguys.com/product-details/?productid=37379 ). Then you can have a normal keyboard and stil have the 10-key functions without toggling the NumLock often.
I hope this helps.
Jun 11, 2011 | HP Pavilion DV9620US Notebook
How do I reverse selections on number pad? I presume it is achieved with a key stroke like the caps lock. Which one?
I am not clear on what you want to do ... you don't want to put the 1 where the 7 is ... do you?
You can set your key pad to be numbers or you can use the other features listed on the keys, To change between numbers and features, you press the "Num Lock" key which is normally just above the 7 key.
If you do want to put the 1 where the 7 in, for example, you will have to remap your keyboard. And this is entirely possible ... I am not going into that detail here ... it is beyond the scope of what happens here normally. You can find instructions for remapping from Dell or any other fine computer manufacturer. Also, if you want to pursue this, you could 'goggle' remap my keyboard' for instructions.
Thanks for your question at FixYa.com
Feb 04, 2011 | Dell 0Y3740 Keyboard
I press certain letter keys and numbers appear, the number keys are fine just the letters, what is the fix for this error?
You have your numbers lock on, press the NumLk key and that should correct it. You will notice on you keyboard that there are small numbers on it below some of the letters, this is so you can use the keyboard has a 10 key number pad/ calculator etc. If pressing the NumLk key does not work, the key may be stuck or you have a bad keyboard
Oct 12, 2010 | Panasonic Toughbook CF-51 Notebook
Where is the Fn key an a dell keyboard?
This is a simple problem, due to the size of laptops, the manufacturers cannot fit on a normal number pad as on a standard keyboard, so what they do is use a function key to turn a portion of the keyboard in to the number pad.
to get rid of this you need turn the 'number lock' off this may be a single key or a combination.
for my laptop its:
press together; the function key (normally 'Fn' bottom left) and the number lock key (Num Lock).
hope this sorts out the problem.
May 30, 2010 | Acer 91.63X07.001 Keyboard
Letters are typing as numbers
one of the F keys turns certain keys on the right side to number keys, so it can act like a full size keyboard with the 10 key panel on the right.. Look carefully at the F keys to determine which one it is. Or consult the manual.
Aug 31, 2009 | Dell Spacesaver USB Keyboard J4624 SK-8115...
Reset users pin
Settings for the Administrator Mode 1 Call the Utility Mode to the Display. ❍ Calling the Utility Mode to the Display (p.7-1) 2 Making sure that ?U--? appears on the Display, enter ?5? from the 10- Key Pad. 3 Press the [Start] key. Input Account Procedure (A-2) 1 Call the Administrator Mode to the Display. ❍ Settings for the Administrator Mode (p.7-16) 2 Making sure that ?Ad-? appears on the Display, enter ?1? from the 10- Key Pad. 3 Press the [Start] key. 4 Making sure that ?A--? appears on the Display, enter ?2? from the 10- Key Pad. 5 Press the [Start] key. 6 Enter the 3-digit account number from the 10-Key Pad. ? Do you know the restrictions on entering the account number? ➜ The account number must be in three digits ranging from 001 to 999. ➜ If an account number entered already exists, the entry will be rejected. Enter a different number. 7 Press the [Start] key. This stores the account number. ✎ Tip To program another account number successively, repeat steps 4 through 7. Using the Utility Mode 7 Di152/Di183 7-21 Delete Account Procedure (A-3) 1 Call the Administrator Mode to the Display. ❍ Settings for the Administrator Mode (p.7-16) 2 Making sure that ?Ad-? appears on the Display, enter ?1? from the 10- Key Pad. 3 Press the [Start] key. 4 Making sure that ?A--? appears on the Display, enter ?3? from the 10- Key Pad. 5 Press the [Start] key. 6 Press [ ] or [ ] key to select the account number to be deleted. 7 Press the [Start] key. The selected account number will be deleted. ? Do you know what to do to delete another account number? ➜ Repeat steps 4 through 7. 7 Using the Utility Mode You can go to the Konicaminolta US web site and down load a operators manual for youself
Apr 23, 2009 | Minolta Office Equipment & Supplies
I cant use my number pad on the right side of my keyboard.
Have you tried pressing the NumLock-key?
It is located right above the key "7" on the numpad/calculator pad.
Dec 17, 2008 | Logitech Cordless Desktop MX3200 Laser...
Number Pad not working
I would try re-seating the keyboard cable
http://www.priorityelectronics.com/images/pop_3f4800ef5205420fabcba8488924da5b.jpg
notice 2 screws at top holding the keyboard.
Feb 20, 2008 | Acer NSK8458AN Keyboard
Open Questions:
See all Toshiba Satellite M45-S265 Notebook Questions
Toshiba Satellite M45-S265 Notebook Logo
154 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
