Question about Video Game Consoles & Games
PS3 connection how do i connect my ps3 to a bang and oulfsen beovision 7?
  • 28 Answers
If I remember correctly the Playstation 3 is set to display through the analog output as default.
Plug in your HDMI cable, and plug in the analog SCART cable that came with the box, put your TV on the analog channel that matches the SCART input and start the Playstation. Once you complete the initial Playstation setup you can go to system settings and change the video output from analog SCART to digital HDMI.
Good luck.
Posted on Feb 04, 2009
How do i connect my ps3 to my beovision avant? please help!
The only way I can tell to connect, would be using a Playstation, R/F switch, or an after market R/F modulator switch. It converts the audio/video signals to a designated channel(usually 3 or4) to connect with the coaxial input in the back of the beovision box.
Mar 08, 2014 | Video Game Consoles & Games
Tip
How to update to 3.15 on PS3
If you are stuck on downloading the update here are a list of ways to fix it
1.Download the update on a USB stick
2.Restart your router
3.Use an ethernet cable to connect
4.Turn off the UPNP When setting up a connection or vice versa
5.Keep downloading the update VIA PS3 Sometimes it does it in chunks
6.Transfer the Update VIA PS3 to PS3
7.Try system restore
8.Try all the restores E.G system restore, game restore
9.Use a differnt router
10.Try it of somebody elses connection E.G friends, grandparents.
on Feb 06, 2010 | Sony Playstation 3 (PS3) Console
We have a bang and olufsen beovision 7 40 inch tv. when we try to connect our laptop through vga port the tv appears blank without any display, tried connecting the laptop through dvi port also. The...
First, try setting your monitor refresh rate at 60Hz using a known-working monitor. (The VGA input of the Beovision 7 is recommended for 60Hz refresh rate). If this fails to produce output from the Beovision 7, it is very likely, your video driver's resolution is set too high for the Beovision 7 to display signal. If you are using the Beovision 7 as your primary monitor, first connect a known-working monitor to the computer and reduce the resolution to 1024x768. Once you have changed the resolution, try connecting the Beovision 7. If you get video signal, increase the resolution incrementally until you find the maximum resolution the Beovision 7 will handle.
IF YOU ARE USING THE BEOVISION 7 AS A SECONDARY MONITOR USING EXTENDED DESKTOP, reduce the resolution on Monitor 2 output to 1024x768. If video appears on the Beovision 7 at that resolution, incrementally increase the Monitor 2 resolution until you find the maximum resolution the Beovision 7 will accept as a secondary monitor.
Jul 14, 2011 | Televison & Video
Got a PS3 hooked upto a Samsung 40" LCD TV via
I would suggest trying a different TV, and maybe see if you still have any Component or Standard Definition Composite cables to connect the PS3 to the TV and see if it works that way. I would assume you did this when you said you reset the resolution on your PS3, but turn it off, then hold in the power button until it beeps twice in a row. (Just in case) Make sure everything is plugged in twice and your TV is on the right input. If none of that works, there may be something wrong with the graphics adapters on your PS3 in which case you will need to contact Sony about fixing it.
Mar 04, 2011 | Sony Playstation 3 (PS3) Console
How to connect PS3 to the internet?
There are two ways to connect to the internet there is Wireless or Wired connection here is how to do both:WIRELESS (WIFI):
Step 1: Turn on the PS3
Step 2: Once on main menu go to settings and under settings select "Network Settings"
Step 3: Select "Internet connection settings" if prompted that you will be disconnected from the internet select "Yes".
Step4: Select "Easy" on types of installation.
Step 5: Select "Wireless" to choose what kind of internet connection you want.
Step 6: Select "Scan" to search for internet access points.
Step 7: Select your home connection when the screen comes up with all the found access points. If your home Internet access point requires a password enter the password when prompted and saveyour settings.
Step 8: Test the connection to check if you configured your settings right if successful you are good to go. If not go back and check your connection settings for your home internet access point. You are now connected to the internet!
HARDLINE (Wired): Must connect ethernet cable to PS3 before turning it on!
Goes like this: Arrows are the cable (===>)
Internet Line ===>Router ===>PS3
Step 3: Go to "Internet Connection" and select it to Enable it.
Step 4: Select "Internet Connection Settings"
Step 5: Select "Internet connection settings" if prompted that you will be disconnected from the internet select "Yes".
Step 6: Select "Easy" on types of installation.
Step 7: PS3 will automatically check your connection network setup and set the settings for you.
Step 8: The settings will appear and press x to save the settings.
Step 9: Test your connection if it was successful you will see succeeded nest to "Obtain IPAddress" and "Internet Connection" you are now connected to the internet!
Feb 27, 2011 | Sony Playstation 3 (PS3) Console
I have this router set up with a wired connection to a windows pc with windows 7 and using the wireless to connect a laptop and a ps3. when the wired pc is off the ps3 connects just fine, but when it is...
It sounds like you may have manually assigned the same static(constant) IP address to both the wired PC and the PS3. Check both the settings in the router, the PS3 and the wired PC to make sure that an IP address is assigned to both.
Feb 03, 2011 | D-Link DIR-615 Wireless Router
We just bought a new computer and now my ps3 cant obtain the ip address and for some reason i had linskys as my internet connection but now it switched to the computers internet connection and it will not...
You need to get a router. Buying one of these, (perferably D-Link model-DIR 615 best bang for your buck), will help distribute internet via WIFI. If your PS3 doesn't support WIFI just connect an ethernet cable. This should work.
Jan 07, 2011 | Sony Playstation 3 (PS3) Console
NEED HELP connecting my ps3 to computer to share internet
You need to configure Windows 7 for internet connection sharing (ICS)
http://www.home-network-help.com/windows-7-internet-connection-sharing.html
Mar 28, 2017 | Sony Playstation 3 (PS3) Console
Problems getting PS3 installed
Hi to be honest it should work straight away, sometimes if the display settings are not matching it can cause problems, ie that the PS3 is set not to show 1080i 720, etc etc you may not get a picture. have you got a different TV you can try to check the settings on, if so enable all of the display settings and try each one
Jan 25, 2009 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
532 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
