Question about Lexmark X4270 All-In-One InkJet Printer
Fax number I have changed my home phone number but i do not know how to change the number that prints on the fax sheet. it still show my old number. any ideas.
  • Lexmark Master
  • 684 Answers
Unplug the Power Supply from the printer.......
Press and hold the Stop/Clear button on the Printer and Plug in the Power Supply while holding the Stop/Clear button it should say clearing on the screen at that point u can go ahead and release the Stop/Clear button..........
Now the Printer will ask for the Date Time and Country Language.........
Set everything up......
Good Luck............
Posted on Feb 12, 2009
We switch phone carrier and our fax number was also change, but everytime we send any fax to somebody our old fax machine number shows. So, how to remove the old number and let the new fax number printed...
If you are able to access the fax menu, you should be able to change a number of parameters including the number display of the sender. Good luck.
Dec 22, 2010 | Garden
My phone # has changed due to relocating. How do
you should be able to change the fax number from the built in set up menu try this link to find the info you need
http://h10025.www1.hp.com/ewfrf/wc/docum…
there is also a 5610v and a 5610 vi model(s) be sure you get the correct model number so you get the correct instructions.. ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Aug 05, 2009 | HP Officejet 5610 All-In-One InkJet...
Entering my own phone number to a fax machine
press help key then print your setting phone no or change
Jun 28, 2009 | Sharp UX 355L Plain Paper Thermal transfer...
My Sharp UX-355L Fax machine printed unwanted information
Sounds like you have the machine set up to print reports on all occasions, fax transmission, error, etc. You can change this by doing the following:
1 Press these keys:
The display will show:
FUNCTION
TRANSACTION LIST
2 Press a number from 1 to 5 to select
the condition for printing.
ALWAYS PRINT A report will be printed after each
transmission, reception, or error.
ERR/TIMER/MEM A report will be printed after an error,
timer operation, or memory operation.
SEND ONLY A report will be printed after each
transmission.
NEVER PRINT A report will never be printed.
ERROR ONLY A report will be printed only when an
error occurs.
To print from memory:
If the memory becomes full...
If the memory becomes full while the document is being scanned,
MEMORY IS FULL will appear in the display.
♦ Press the START/MEMORY key if you want to transmit the pages
which have been stored up to that point in memory. The remaining
pages will be ejected from the feeder. After transmission, the memory
will be cleared and you can transmit the remaining pages. You
will also need to transmit the page which was being scanned when
the memory filled up.
♦ Press the STOP key if you want to cancel the entire transmission.
Hope this helps. : )
Mar 30, 2009 | Sharp UX 355L Plain Paper Thermal transfer...
Confirmation
By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming and outgoing faxes
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
Oct 14, 2008 | HP LaserJet 3055 All-In-One Printer
I have a Sharp compact size plain paper fax mach. UX-300. I moved and forget how to change the phone number. Can you help.
I have a UX-355 in front of me that I think is similar to yours.
See if you have 2 green buttons for COPY/HELP and SEND.
If you hit the Copy/help button and the machine will print out a help sheet that should walk you through on how to change different things on your machine.
If your machine doesn't print out the help sheet, then try this:
Hit FUNCTION button,
Enter 3 and then Start Button.
You can use your # key to scroll through the functions.
I think you want to change the number that shows up on the receivers sheet. That is under OWN NUMBER SET.
Scroll through the settings til you see that.
It should walk you through on how to set it in that screen.
The # sign will move your cursor to the right.
Make sure you hit the START button to lock in your settings or else it will not save it.
If this doesnt work of you have more questions, Please post another question.
If i have helped you, please give me a good rating.
Have a good day.
Good luck.
Mac =)
Apr 22, 2008 | Office Equipment & Supplies
Fax confirmation set up
document.tlSearch.tx.value=unescape("") s.gif s.gif HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
Mar 31, 2008 | HP LaserJet 3050 All-In-One Printer
Fax Confirmation Sheet
Jan 22, 2008 | HP LaserJet 3050 All-In-One Printer
FAxing in "real time" rather then sending to memory
You can go into the setup mode. There should be either a memory clear which will reset it to default settings, or a setting to simply reset.
You can go into the menu on the machine and print out a help sheet which will help you through the problem.
And there should be a settings sheet to print out that will help you isolate which setting needs changed.
Dec 11, 2007 | Brother IntelliFAX 4100 Laser Fax
Change phone number on fax
FAX PRINTS OUT OLD PHONE NUMBER. FAX NEEDS TO REFLECT NEW PHONE NUMBER ON SENDING HEADER OF FAX
Apr 18, 2007 | Muratec F360 Plain Paper Laser Fax
Lexmark X4270 All-In-One InkJet Printer Logo
29 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
