Question about Logitech Cordless Desktop MX3200 Keyboard/Laser Mouse
MX3200 Cordless Keyboard alarm clock
I have a MX3200 Cordless Keyboard that has a window for the date and time. The alarm goes off at 2:00pm each day. How can I turn it off?
Also does Logitech have a manual I can download?
Hold down the FN button (next to the right CTRL button) and press the F11 button.
Posted on Apr 26, 2009
I need to know how to reset the time and date on the keyboard
there is a blue button next to the richt alt key on the keyboard press and hold this then press either of the following f9 mode, f10 set, f11 alarm and f12 start stop hope this helps
Sep 07, 2010 | Logitech Cordless Desktop MX3200 Laser...
How to set date & time MX3200 keyboard from Logiitech
use your mouse curser; place over "time" in lower right corner of screen in bottom taskbar; right click;should have adjust date/time; left click;adjust date/time
Mar 08, 2010 | Logitech Cordless Desktop MX3200 Laser...
Want to change keyboard clock
To adjust the LCD's time and date:
  1. Make sure that the time and date are shown on the LCD. If necessary, press (FN + F9) until the time and date are shown on LCD.
  2. Press (FN + F10). You are now in 'Set mode' (you can exit this at any time by pressing the Esckey).
  3. Set the correct hour by either typing the numbers on the numeric pad or using the cursor up and down keys, followed by Tab or Enter.
  4. Set the correct minutes by either typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
  5. Choose either 12-hour clock or 24-hour clock by pressing the cursor up or down keys to switch between the options. Then press Tab or Enter.
  6. Set the correct month either by typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
  7. Set the correct day either by typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
Sep 11, 2009 | Logitech Cordless Desktop MX3200 Laser...
Cant change the time and date in my logitech keyboard
At the top of the keyboard are the LCD function keys (F9 - F12). Press and hold the function key (FN, next to the left alt key) and press F10. Use the up and down arrows to change the time. Press FN + F10 again to change between hours, minutes, month etc.
Apr 23, 2009 | Logitech Cordless Desktop MX3200 Laser...
Time and date wrong on keyboard
To enter the date and time setting format,press the FN key and the F10 key at the same time.
Hope it works for you.
Mar 21, 2009 | Logitech Cordless Desktop MX3200...
How do i set the clock on my mx 3200 keyboard?
To set the clock and date all you nee to do is have it on the clock and date mode. If you have it on a different mode hold the function (FN) key and press mode (F9) to toggle through each of the modes until you get to the one you want.
Then, to set it hold the function (FN) key and press set (F10). Next type in the numbers that you need for the hour time, then the min, then select 12hr clock or 24 hour clock with arrows, then select the month with the arrows, and finally select the day with the arrows. pressing enter to get to each step respectively. don't forget to rate me
Feb 02, 2009 | Logitech Cordless Desktop MX3200 Laser...
I have a mx3200 cordless keyboard that has a clock and date window. The alarm clock goes off at 2:00pm how do i turn it off? Do you have a manual I can download?
got this off the logitech forum, The only instructions that I can find (which came with my relatively new pc) are on a large "Installation Guide," the most pertinent information from which is about setting the time and date: "To enter time/date setting format on the keyboard LCD, press the FN key and F10 key simultaneously." Also "LCD: Mode (F9): switch mode from Time/Date to Alarm to Timer to Character Count. Set (F10): press to set Time/Date, Alarm and Timer. Change batteries one by one to keep LCD settings. Remove the 4 keyboard batteries to reset Character Count to "o." Bell (f11): put Alarm On or Off. START/STOP (F12): start 01 pause Timer." The Logitech program group (should be on your Start menu) will give you further information for identifying keys, and for formatting the keyboard and mouse. Good luck.
Jan 31, 2009 | Logitech Cordless Desktop MX3200...
Clock reset
The time and date on the LCD should now be displayed properly.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you resolve your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
Nov 07, 2008 | Logitech Cordless Desktop MX3200 Laser...
Keyboard
Go to
this page on the Logitech support site
and follow the seven steps to adjust the LCD time and date on your Logitech MX3200 keyboard.
Don't forget to rate this solution once you've tried it !
Apr 28, 2008 | Logitech Cordless Desktop MX3200...
MX 3200 Cordless Laser Keyboard - Logitech
Press the FN key and *at the same time* press the F10 key for 1 second.
The first part of the time should start to flash.
Use the up / down keys to change the hour, then press TAB. The minute figs. should now flash. Use up/down to change the minutes and press TAB.. do the same with the date and month etc, you can also set 12h or 24h clock.
When you are finished press ENTER.
Nov 24, 2007 | Logitech Cordless Desktop MX3200 Laser...
Logitech Cordless Desktop MX3200 Keyboard/Laser Mouse Logo
1,231 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
