Question about M-Audio BX5a Speaker
No sound from M-audio BX5a monitor
I have a pair of BX5a monitors hooked up to a video editing suite.  One of the monitors is off.  They are powered to a working electrical supply.  They are driven off a Mackie DFX-6 with a 1/4" unbalanced connection.  No blue light on the monitor, no sound or hissing on that side.  I changed the fuse with the supplied backup and it powered up and the light faded quickly and was dead agin.  Can you help?
I have a pair of BX5a monitors hooked up to a video editing suite. One of the monitors is off. They are powered to a working electrical supply. They are driven off a Mackie DFX-6 with a 1/4" unbalanced connection. No blue light on the monitor, no sound or hissing on that...
Posted on Mar 08, 2009
Sound aoc l22w861 lcd tv pc monitor
It may be the game options or the system options may be set to something else than speakers
Mar 20, 2014 | Sony Playstation 3 (PS3) Console
How to replace capacitor on M Audio bx5a speaker
http://mr-ives.blogspot.nl/2011/09/mending-pair-of-m-audio-bx5a-monitors.html
Apr 20, 2013 | Klipsch Synergy Sub12 Subwoofer Speaker
I'm a video editor (MAC OSX). I playback audio at fairly low volume. Recently, I turned on my speakers (BX5) and only the R came on. L was dead and inspection revealed it was "blown". Can't...
Hi, cases like that always comes u. Earlier you said just replaced it, that's not too good for anew monitor speaker.
You could test the fuse inside the speaker if it's still working, might be power fluctuation that might have caused it to blow.but you need to test it. If it is the fuse,fine! you can replace it, it does not cost much to replace.
Also if i can recall,most new stuffs always comes with guarantee with it,right?. I would suggest you could take it back and get a replacement, and i guess if they see it,since it is on guarantee,they can fix it for you without even charging you a penny.
Hope that helped.
Thanks and feel free to pass on your comment.
Thanks for using fixya..
Jan 12, 2011 | M-Audio BX5a Speaker
I have connected my BX-5a monitors to the fast track audio pre-amp with 1/4 inch to RCA adapters, which is connected to my Mac book pro. I am still not getting any sound out of the monitors. What do I do?
I would suspect the Mac isn't passing any audio out. Test it with headphones before we troubleshoot the audio hardware. OR, connect a different audio source to the preamp to see if it works with something less complex than a Mac.
Jan 10, 2011 | M-Audio BX5a Speaker
Where do I find a replacement woofer for a bx5a monitor
http://reconingspeakers.com/product/m-audio-bx5a-woofer/
Jan 02, 2011 | M-Audio BX5a Speaker
I got a pair of bx5a What do i need to connect
Here is your resolution that how you can connect your BX5a to PC.
well I had provided some pics attached in that I had marked and given some information follow that accordingly and you will be able to connect it your PC.
But you need XLR code through only you can connect it to your PC.
If you still have nay other problems regarding same or any other do reply me.
Naiven.
May 24, 2010 | M-Audio BX5a Speaker
Tv problem
Since the NEC is not a TV but a monitor, it does not have a tuner nor speakers that it why it has no RF input. So if you want to watch TV on it you need a cable box with an HDMI and an audio out, and a pair of amplifed speakers. You can use the cable box's universal remote to turn your monitor on and off.
To get TV video, get an HDMI-to-component video (red/blue/green) cable then to get audio connect the cable box's red/white RCA audio out with an inexpensive set/pair of amplified PC speakers. For this you need a 3.5mm-to-RCA adapter to hook these up properly.
Because the audio is coming from independently powered speakers, it will be nice to have a set that goes on standby when there is no audio signal from the cable box. This would eliminate the need for you to stand up and power off the speakers when you have shut down your TV (monitor) and cable box. Or even better, get one that has a remote so that you can raise or lower the volume or power off as needed.
Hope that helps.
Aug 28, 2009 | NEC 42 in. EDTV-Ready Plasma TV
M-Audio BX5a Speaker Problem
Not sure i can help with the led problem but i just fixed a hissing problem with one of my BX5a monitors. It developed a hiss when on (both tweeter and bass) and a very loud thump when switched off. I found a slightly swollen power filter capacitor on the internal board. They are the two biggest black capacitors, labelled as 25v 6800uf. Only one of these was bulging. The tops of these should be totally flat. The indented X on top of the caps make any bulge easy to spot. Worth opening it up and having a quick look. I could only find 35v 6800uf caps at my local electronics store but they did the job ($3 each). I swapped both out and it's now working great. An easy DIY fix, just be sure to always have the power cord unplugged before you put your hands anywhere near the guts of the thing. Hope it helps.
Sep 17, 2008 | M-Audio BX5a Speaker
How do you hook up a Power amp to a XR8600 peavey power head to run monitors or mains
Hook the power amp into the actual main and monitor input, and then hook your main and monitor speakers into the power amp.
Jun 30, 2008 | Audio Players & Recorders
Connecting headrest monitors to Kenwood DDX-6019
Youll have to run sets of cables from your head unit to the seats, youll prob only need video, power, and ground if the sound will come from your speakers. For the same display on either monitor run to first position then link the 2 monitors.
May 10, 2008 | Sony XVM-R70 7 in. Car Monitor
M-Audio BX5a Speaker Logo
1,629 people viewed this question
Top M-Audio Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
jason
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
