Question about George Foreman GF20G Indoor Grill
My george foreman grill won't heat up
I checked the thermister that is in series with the ac power input and it is open. I put a jumper wire across it and the grill heats up. I need to replace the thermister but can't find one. The part number on it is 232512. Any ideas as to where I can buy it?
Thanks
Dan
I have same problem. Just ordered a replacement from Digi-Key. Their part # is 317-1087-ND. Their part is made by Faston, but the specs are the same as the T-KEY C1-2021. Cost is $6.92 plus $1.90 for shipping and handling.
Posted on Jun 16, 2009
If you use the part number specified in the previous response (317-1087-ND) your grill will only heat to 85 degrees Celsius. Specs of the previous Thermal regulator switch is 175 degrees Celsius. It will take a long time to cook anything at 85 Celsius!
Posted on Nov 15, 2009
Need pre-heating a and cooking time list.
instructions to pre-heating and cooking time
Dennis, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
George Foreman GGR50B Owner Manual
http://www.grillmeats.com/Manuals/GGR50B.pdf
Free George Foreman Kitchen Grill User Manuals ManualsOnline com
Apr 06, 2016 | George Foreman GGR50B Electric Grill
George forman fusion grill
George Foreman GR70CAN Owner's Manual - ManualsLib
www.manualslib.com > ... > George Foreman Manuals > Grill > GR70CAN
Grill George Foreman Fusion GR70 Owner's Manual. (44 pages). Grill George Foreman Grill Instructions For The Use & Care. (12 pages). Grill George Foreman ...
George Foreman Fusion Grill Instructions - YouTube
? 1:26
https://www.youtube.com/watch?v=wSMbMDFltuE
Oct 9, 2014 - Uploaded by BBQ Grills & Smokers
George Foreman Fusion Grill Instructions. BBQ Grills & Smokers ... Best Technique for Cleaning George ...
Dec 07, 2015 | Kitchen Appliances - Others
Grill not powering up
Probably a thermistor gone bad. When unit gets too hot the thermistor opens and cuts off juice to the heating element.
Replace the thermistor.
Aug 22, 2017 | George Foreman Kitchen Appliances - Others
I HAVE ERROR 189 ( TIME TOO LONG FOR HEAT UP BOILER ), CAN YOU HELP ME PLEASE ?
Sounds as though the boiler has lost the supply to the heating element, or the supply is low.. Check that the thermal fuse in series with the boiler heater is not open circuit (there may be more than one in series). If it is OK, check for continuity across the heater inputs - if that measures open circuit or very high resistance, the heater has failed.
Otherwise just backtrack along the wiring harness looking for the power supply to the boiler, there will be at least one relay (contactor) and switch. Make sure all are working correctly. You should be easily enough able to locate where the supply to the boiler's heating element is getting lost :o)
Nov 06, 2013 | WMF Coffee Makers & Espresso Machines
I have an error code H401 on my sharp AR336 copier. Help please
H 401 means Heat roller low temperature detection. i.e. The temperature does not reach the
preset value within the specified time (3 min. in usual modes; 5 min. in curl correction mode.) after the power relay is turned on.
Possible causes
Thermister defective
Heater lamp defective
Control PWB defective
Thermostat defective
AC power supply defective
Interlock switch defective
Possible remedies
Check heater lamp for blinking with SIM5-2.
If lamp blinks properly:
Check thermister and its harness. Check thermister input circuit of control PWB.
If lamp does not light:
Check heater lamp for broken wire and thermostat for operation. Check interlock switch.
Check lamp control circuit of AC PWB and control PWB.
Clear the trouble with SIM14.
Jun 13, 2011 | Sharp Office Equipment & Supplies
AC IS TURNING ON BY IT SELF AFTER I SWITICH IT OFF, HOW TO SOLVE THIS PROBLEM
Sounds like a problem with the furances circuit board. With the furance powered off, disconnect the two wires at the circuit boards thermostat terminal strip. These are probably red and white wires connected to the "Y" and "C" thermostat terminal strip on the circuit board. These two wires send 24 volts to the outside A.C. condenser unit when the thermstat is se tinto the cooling mode. With the thermostst in the "off: postion measure across the "Y" & "C" terminals at the furances thermostat terminal strip. If you have voltaged than either the board or thermostst has failed. The next step to determine which has failed is this. Disconnect all the thermostat wires at the furance. To check the heating circuit jumper across the "R" & "W" terminals, the furance should fire off for the heating circuit and run non stop beacause the thermostat is no longer controlling it and is isolated from the furance. Now remove the jumper and jumper across the "R" &"Y" terminals, the blower should run at your furance for the cooling mode and you should have 24 volts across the "Y" & "C" terminals for the outside A.C. condenser compresor contactor.Next check for blower operation by jumpering across the "R" & "G" terminals. If everything checks outs than the thermostst is the problem. Tou may also want to check the control wiring at the thermostts , furance & out side condenser unit. If the wiring has connnected somewhwre between these points or at the terminal connection this may also be bring on the A.C. when the thermostat is in the "off position.
Feb 13, 2011 | Hitachi Heating & Cooling
Pleas can you help, when i turn on my Sharp Ar 337 i get this all the time earra cord H3-00. can you tell me how i can solve the problem .
H3: Heat roller high temperature detection
cause:-
  • Thermister defective
  • Control PWB defective
  • Improper connection of fusing unit connector
  • AC power supply defective
check and remedy:-
Check heater lamp operation with SIM5-2.
If lamp lights and stays lit:
Check lamp control circuits of AC
Jan 23, 2011 | Sharp AR-M237 Copier
George Foreman GF20G Indoor Grill Logo
2,308 people viewed this question
Top George Foreman Kitchen Appliances - Others Experts
Mike
Gerry Harvey
Gerry Harvey
Angel Joseph Jr.
Angel Joseph Jr.
Are you a George Foreman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
