Question about Sony VAIO VGN-FS742/W Notebook
Loses network connection or says low connectivity.
Began about 1 monthago. 4 year old FS742 laptop wireless connection to DSL. Replaced DSL router still can't access internet. If I go to basement and reset router it usually connects. Phone co. replaced router 2 weeks ago, still having problem.
    Scholar:
  • 50 Answers
Hmmm... need to see if this is from the router end or the problem is your laptop. phone company replaced the router-- did they stick around long enough to see you connect to it with your laptop?
how long has the connection worked properly between the wireless laptop and your basement router?
can you visit a starbucks or whatnot to see if you can surf with your latop (i.e. it's not your laptop wireless card)
can you get a friend to come over to try your router with their wireless laptop?
what if you stay just in teh basement -- does the connection drop at all?
Posted on Jan 31, 2009
How to change browser to allow conection to internet
To connect to the Internet you need a few extra things aswell as a network or wireless card and install the LAN or wireless driver.
1. You need to sign up with an Internet service provider.
2. Connect a LAN cable from your computer to the DSL or cable modem
3. You need a DSL or cable modem and connect and configure the modem to inaccordance with your Internet service provider's instructions.
4. Install Internet Explorer if it has not been done.
5. If everything has been done correctly, when you open Internet Explorer youcan access the Internet.If you have a wireless router and it is connected to the DSLor cable modem then -
To connect to yourwireless router, the router needs its wireless settings to be configuredwith the SSID, encryption key etc., also the wireless cards in all thelaptops/computers needs to be configured with these router's wireless settings.Then the laptops/desktop computers can communicate with your wireless router.
Dec 27, 2011 | Computers & Internet
Aztech DSL 605 EW losing internet connection when I am connecting/enable the wireless connection. Could any one suggest solution? Rgrds
1. check connection by 1st pinging the network card That is go to the dos window and type " ping 127.0.0.1 you should get 4 replies.
if not then you need to check the driver set for you network card.
2. check the ether net cord with a know good one
3. reset the router by unplugging it and reboot the pc
4.Call your ISP to check for outages
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Aug 03, 2010 | Computers & Internet
I have secured my router by connecting my laptop to the router by ethernet cable so now my network comes up as security enabled but I can't seem to connect to my wireless network although it shows the...
Remove the neighbor's network from the preferred network list.
add your own network in the list. If your router is old router then upgrade the firmware of the router. Firmware is the software of the router.
You have connected your laptop to the router, to secure the wireless network. When you connect the laptop to the router, make sure that the wireless network connection will be disabled.
Once you change the wireless settings, enable the wireless connection and connect to your network.
Apr 25, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Laptop can't connect to DSL-G604T
You need to configure your router and use WPA encryption so that all accessing device can connect to it.
The obvious reason why the dell laptop can't connect is because of the WPA encryption set. It is different compared with what your router is actually broadcasting: WPA2.
So you can choose one of the 2 things to alter. Change your router's WPA2 encryption to WPA or change your Dell's setup to WPA2.
Mar 05, 2010 | D-Link DSL-G604T Wireless Router
Trying to connect a wired network wirelessly to a router
No. You'll need to run a "cross-over" Ethernet cable from one of the "LAN" ports on the "downstairs" router, connecting to the "WAN" port on another router that you will need to buy, and place "upstairs", and connect the 4 devices to the 4 "LAN" ports.
Or, run a long "straight-through" Ethernet cable from your DSL-modem (or cable-modem) that is "downstairs", and move your wireless router "upstairs", and connect the 4 devices to the router's "LAN" ports.
Your laptop "downstairs" should still be able to connect (wirelessly) to the wireless-router that is "upstairs".
Sep 16, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Vio and d-link wireless router dsl-2640u connection problem
hi
firstly check to see if the wireless is set for wireless access based on MAC address filtering
also check to see if both the laptop and the wifi router are communicating on the same channel
Jun 24, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
My desktop uses a DSL internet connection but my lap top will not pick up the signal from it to connect even when I have it sitting right next to my desktop. If I actually unplug yellow connection cord...
Having your laptop sitting next to your desktop will not let your laptop connect to the DSL link.
You need what's called a Wireless Router. (assuming your laptop has a wireless adapter, if not you'll need a network cable for that.
1. Go to the store, buy a wireless router
2. install router in between your DSL modem and the computer.
3. Plug the WAN port into the DSL modem (cable is usually included with the router)
4. Plug the desktop into the back of one of the ports of the wireless router
5. Run the setup disk
6. For manual configuration of the router you can usually go to: 192.168.0.1 or 192.168.1.1 or 192.168.2.1 depending on the brand)
7. If you don't know anything about networking, let the install disk do all the work.
8. Follow the instructions on what it tells you your configuration is for your wireless network.
9. Go to your laptop, apply said instructions.
10. ???
11. Profit.
Dec 02, 2008 | Acer Aspire 5050-3242 Notebook
Home Network issues
> you need to configure your wireless printer so that all computers will be able to detect it,your ISP or printer manufacturer will be able to configure that for you
Jun 30, 2008 | Actiontec GT704WG Wireless Router...
Linksys WUSB300N adapter not detecting wireless links
I am confused, you are using 2 routers, or you using their dsl modem/router? or your original??
Dec 29, 2007 | Intel PRO/Wireless 2200BG 802.11g/b
Sony VAIO VGN-FS742/W Notebook Logo
82 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
