Drum won't spin during wring cycle.
Sometimes it works, sometimes it doesn't. Clicking sound can be heard. Often, the drum will spin off balance and causes banging noise.
  • godtogive Jan 31, 2009
    my washer spins sometimes i readed that the wires might be loose well they were I just want to know if i can connect those 2 wires that go in the same place togerther
  • onthethejob1
    onthethejob1 May 11, 2010
    what type of washer,,and send model #
  • 15,935 Answers
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 13, 2010
What is the cause of a very loud, repetitive noise during spin cycle?
Sounds like the drum mounts are worn causing unbalance.
Sep 13, 2014 | Amana Washing Machines
Erratic Drum Operation
Can you clarify the problem, I don't fully understand what the actual problem is?
Oct 24, 2008 | Splendide 2000S Vented Washer/Dryer
Washer Spin Cycle doesn't work - sometimes
Hello T Wright - Based on the symptoms you are describing, it sounds like more than likely the unit is sensing an out of balance load, which could be too light or to heavy of a load, and the unit will not advance to high speed spin. However, often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Apr 13, 2013 | Frigidaire GLTF2940ES Front Load Washer
Is it normal for liquid to be present in the top part of the drum?
Yes I have this type of washer and it has the water in a ring at the top of the drum to help balance it out during spin, not quite sure why but yes it should be there. The gargling sound you describe could also be the balancing hooks that attach the drum to the top of the washer which sometimes make strange noises but there fine.
Mar 10, 2013 | Haier RWT350AW Top Load Washer, White, 3.0...
Washing machine travels during the spin cycle
Hi - Try to rotate the drum when it is not in use, manually and see if you notice the sound as well. If you do the drum is not balanced and you would need a professional technician to diagnose the bearing and pulley system behind the drum for repairs.
Oct 27, 2012 | Frigidaire ATF6000ES Front Load Washer
The mongrel won't spin.
Possible that when the drum spins out of control the excess load on the motor trips the system/control board and so it takes time to reset. So what is needed is to check the suspension of the drum, the floor setting of the machine to be leveled so that it will not spin out of control.Also the load on the machine particularly with thick blankets must be rolled and evenly distributed.I must confess that the presence of any limit switch to trip must be checked as I am unaware.
Jan 10, 2012 | Washing Machines
Drum hitting sides of machine in spinning cycle (unbalance)
It sounds like you may have to many clothes in it. Try to remove some or reposition them. Sometimes the clothes get pushed to one side of the drum during the spin cycle and all of the weight to one side is making it off balanced.
Dec 27, 2010 | Hoover Washing Machines
During a spin cycle what would cause the basket to be out of balance on every washload, even when there is not a balance issue. Basket acts loose and bangs against inside of machine
sounds like your bearings are excessively worn, open the machine door and hold the drum (stainless steel bit) try to lift this up if it moves freely without the tub moving (outer bit usually plastic or steel without holes) your bearings are gone. or the drum has broken off the wields that hold it to the shaft.
its sometimes cheaper to buy a new machine than repair the bearings and if the drum is loose it will eventually break something inside.
Jul 22, 2009 | GE Washing Machines
Maytag Atlantis screeches @ end of spin cycle,
may be something stuck in the drum or a segment raised on the motor. to test either remove the belt and spin the drum if no noise then the motor is faulty. if a noise then there may be a bra wire between the drum/tub.
Mar 16, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Sounds like a loose screw/bolt/nut during the spin cycle
There is nothing wrong with your machine. Don'f bother with the sound , You said you threw 2 pair of jeans, so its bottons are causing the sound against the drum during cycle. Finished your laundry and worry no more. To make sure, throw some another clothing asides form jeans, like shirts, and feel the normal silent of your machine.
Good Luck,
Eriez
Jun 05, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
