Question about Toshiba D-R5 DVD Recorder
Why won't my computer read it?
I have a pc and it won't even recognize that the dvd is in their when i put it in. Then i have a powermac G4, and it still doesn't read it. I took it in to the Apple store, they tried it there and still could not read it. But at home on my toshiba d-r5 and my sony, it reads fine. WHAT DO I DO????
  • 1 more comment
  • Ravi Gunewardena Aug 01, 2007
    I can't do that. My computer doesn't even recognize that there is a disk inn the drive. However any other dvd will work. I figured out that the format the toshiba burns in is DivX. So i went on their website to find software that would allow me to read the disk, but it didn't work, the computer just won't read it.
  • Ravi Gunewardena Aug 02, 2007
    The disk is burned. I burned it on my Toshiba D-R5. It is in Divx form. My average sony dvd player reads it no problem. However, my pc, or mac won't read it. I bought the software from DivX website for $20 but now when ever i select a function on the DivX player, the program shuts down. I am in a real bind, i have to do this for a wedding which is on Sunday August 5th.
  • RyanWilson Jan 05, 2008
    When I put Star Wars: Empire at War in my dvd drive, my computer didn't even see a dvd in there!? What is the problem with it? my email is rwils79@eq.edu.au
This is not a Mac/PC problem but because the DVD-Recorder burned a protected disc to prevent copying of TV programs. On most cases, the DVD can be played on a normal DVD player but cannot even be read by MAC and some PCs.
The 4GB+ DVD might even be interpreted as 8GB+ DVD to prevent copying of content. It is not easy to break this copy protection method but on a PC, it can be done. Although how to do it is a trial and error experience.
If you are able to read the disc, you might notice that there is an additional folder besides the usual "Audio_TS and Video_TS". It is a sure tell sign that the DVD is recorded from a DVD-recorder and is copy protected somehow.
Posted on Apr 23, 2008
    Genius:
  • 2,985 Answers
Finalize the disk in the computer.
Posted on Jul 31, 2007
  • john ash
    john ash Aug 01, 2007
    This disk is it a burned disk?
    If so what burned it?
    If it is not a burned disk- describe it in more detail
    I notice too that you are talking Mac here
    So is it a Mac compatibility problem?
  • john ash
    john ash Aug 02, 2007
    Looks like you will have to change to another burn system.
    Down load CDBurnerXPPro 3
    It is free and all the kit I have access to reads them.
    I do shows too.
SOURCE:
Powermac screen developed fine black grid and won't operate properly
Isolate the problem to see if it's the screen or video card by connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok without a problem then your original screen is bad and your video card is good. If the Borrowed monitor displays the same problems as your original then your video card inside the computer is bad.
May 29, 2012 | Apple Powermac G4 Quicksilver Logic System...
I want to reboot my powermac g4. i have the startup disk i dont kno wat to type at the black screen
All you should have to do is put in disk and powermac should start from it, if not then replace the pram battery and try again. The battery is on the motherboard and can be bought at any radioshack.
May 01, 2010 | Apple Power Mac G4 Desktop
Powermac g4 shut down
OK it's a G4 iMac.
Burning smells coming from macs often indicate a failure in the power supply module. That said, the G4 iMac (in my experience) has been the most reliable iMac ever and power module failures are very rare.
Your best option is to find a Mac repair centre near you and take in in for a quote. But be warned - it will cost. For some reason known only to Apple power supply modules are expensive (but not as expensive as the equivalent volume of HP ink) and replacing them is not as easy as on many of the other computers.
If it is the power supply, you will not be able to switch it on again. Your data on the HD should be safe (unless the smell was coming from that - - I've had it happen!). So when you get to the workshop and you've had your quote, if you decide not to go ahead with the repair, ask the workshop to remove your HD and put it into an external case so that you can plug it in to another Mac and continue using it.
Let us know what the outcome is.
Oct 07, 2009 | Quicksilver Power Mac G4 (Quicksilver)
Transferring software and files from PowerPC G3 to PowerMac G4
to mount somthing in a mac is basicly cutting it on for use.
For example if you instal a flash drive or an hard drive via an out side connection, The mac will mount it so you can use it.
Aug 09, 2009 | Computers & Internet
Computer help
The only way to solve this is to either get hold of an OSX disc, (you can find them on ebay) or, borrow one from a friend and use the reset password utility that is on the disc.
Mar 31, 2009 | Apple Power Mac G4 Cube Desktop
Monitor does not come on
The video card you used may work for the 2nd computer but not for the 1st because of the system requirements. They might be different simply because they are different models. check which video card is RECOMMENDED, NOT MINIMUM, and get the recommended video card.
However, if it is the right video card, then get it checked at a pc shop, like pcworld or somewhere like that and see what they think of it.
Sep 14, 2008 | Apple 64MB NVidia NV-11 Video Card for...
Apple dvd driver
there are no drivers it is plug and play
Nov 29, 2007 | Computers & Internet
Toshiba D-R5 DVD Recorder Logo
1,034 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
