Question about Lexmark P915 InkJet Photo Printer
Lexmark p915 printer stuck in photo mode
I can't seem to get my printer to get out of the photo mode so it won't print documents from my computer.
  • darbsllim Mar 03, 2009
    My printer is also stuck in Photo Mode and won't print documents from my computer.
tom19511
  • 1601 Answers
SOURCE: Driver for my Lexmark P915 printer- CD in storage!
Here you go:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=Lexmark+P915
Posted on Mar 02, 2008
Ajkill
  • 2035 Answers
SOURCE: Cartridge problems with the P915 Lexmark printer.
First check they compact able once, refilled cart are recognizied
by printer,,,,
Cleaning the contacts on the cartridge carrier
Step Action
1 Power the printer/All-In-One off and unplug the power cable from the outlet.
2 Open the printer/All-In-One lid so that the cartridge carrier can be accessed.
3 Gently move the cartridge carrier into a position where cartridges can be removed.
4 Remove the print cartridges. (For information on cleaning the cartridge contacts, click here.)
5 Using a dry, clean cloth wipe the carrier contacts gently from top to bottom.
6 Repeat Step 5 for the other cartridge slot (if applicable).
7 Reinsert the cartridges, slide the cartridge carrier to its original position, and close the printer/All-In-One lid.
8 Plug the printer/All-In-One back into the power outlet and power it back on.
If your cartridges are not being detected when they are snapped in, do the following:
Open the cover of the printer and unsnap both cartridges.
Snap them back in after a few seconds. Close the cover.
Repeat these steps (1-2) three or more times in succession. You will be prompted to go through the menu on the printer display to finish the process. Follow the instructions displayed.
If your printer is posting a LOW INK LEVEL or CHANGE CARTRIDGE error, snap the cartridges in and out as directed above (steps 1-3). When you close the front cover, you should see the message Cartridge Change - NEW on the display.
Press Select to indicate that you have just installed a new cartridge.
Posted on Mar 16, 2008
SOURCE: lexmark 4300
Are you on Vista or XP operating system ?
Lexmark web site has updated drivers for both.
I am using a p4350 on vista, I downloaded the vista driver from Lexmark, it works but Imaging studio doesn't seem to.
However use 'Paint' to scan and don't forget to select or make the P4300 the default printer.
Jim
Posted on Jul 15, 2008
  • 684 Answers
SOURCE: Lexmark x2600m printer not queueing
The best Solution for this would be goto Start click on Run type in Services.MSC and click ok now on that window u will see an option saying print Spooler just restart that by right clicking on it......
now go to control panel and go to the Printers Folder......
Right click on the Printer Icon and click on Properties......
Now click on Advanced and then go to Print Processor.......
It will be by default on Lexmark LEMF change it to Lexmark NTEMF 1.008......
Click on Apply click ok......
Restart your Computer and try to use it it should work......
Good Luck...........
Posted on Jan 19, 2009
yooperbud
  • 8637 Answers
SOURCE: Can't get Lexmark X5410 to print. Printer is on "Copy Mode"
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
Install for free
Please visit the Lexmark website to download and install the Lexmark P915 Printer Driver on your computer - for free. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen to complete the installation.
I hope this helps.
Mar 12, 2012 | Lexmark P915 InkJet Photo Printer
What type of power cable is required for P915. thank you. I just have a USB.
Lexmark P915 requires 25 Watt HV Adapter (220 - 240V AC, 50/60 Hz) in HV countries OR
25 Watt LV Adapter (100 - 127V AC, 50/60 Hz) in LV countries.
So, you have to buy a power supply as per above specification.
In case the cable marked at '2' above is missing, you can find/ use a similar cable, which can be purchased from a local computer store.
Lexmark P915 Setup Guide
Hope it helps! Good Luck!
CreativeTECH
May 10, 2011 | Lexmark P915 InkJet Photo Printer
Reintal again if you have the dvd if it comes dell.com site and you can find all you need
Oct 17, 2010 | Lexmark P915 InkJet Photo Printer
How can I install my Lexmark P915 printer to my vista O/S laptop
Unplug the printer usb cable from your computer. To install, I suggest you use the Lexmark P915 printer software you can download from the Lexmark website. But check if your Vista is running on 32-bit or 64-bit operating system by clicking on the Windows logo Start menu > right click on Computer > Properties. For 32-bit, click on this link: http://bit.ly/9MpwNB. For 64-bit, click on this link: http://bit.ly/d4tR3d. Download and install. Follow the instructions carefully. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 03, 2010 | Lexmark P915 InkJet Photo Printer
Will print but not copy or scan
sir,
click this link to solve your problem
thanks
good luck
Nov 26, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Lexmark p195
i need program to instale printer
Aug 05, 2008 | Lexmark P915 InkJet Photo Printer
In this case u can download the drivers from the website........ Link: http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:465:0:0
Select ur Operating System and Download the Drivers for ur Computer..... Install the downloaded drivers by double clicking on it...... Thanku
May 04, 2008 | Lexmark P915 Photo Printer with LCD...
Lexmark P915 InkJet Photo Printer Logo
457 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
