Question about ASUS M2N-SLI Deluxe Motherboard
No Video Output.
Hello
I got this motherboard new off Amazon.com but when I tried to connect the video cards I get no signal from them. The board gets power and so do the cards. I have tried resetting the CMOS and switching video cards with no luck. I tried bench testing it with just 1 sitck of ram and 1 vid card and no display, no error beeps, no obvious problems. Is it a dead board?
  • Francisco A
    Francisco A May 11, 2010
    Are you trying to use the motherboard graphics or a added on graphics card?
  • swufabuda
    swufabuda May 11, 2010
    If the only problem is no video I would venture to say that it's your graphics cards not your motherboard..
  • 50 Answers
Try without any RAM and see if there is a beep...if there is then mobo is ok. If no beeps still. Check the CPU. Also check the PSU if its giving adequate power to all the added cards. If possible try with another PSU. Try clearing CMOS as well. If all these doesn't do any good to the mobo, I think its time to RMA the mobo. Have a great day!
Posted on Feb 09, 2009
Reset motherboard video card ibuypower
Assuming you don't have another video card installed (if you do, it will disable the on-board video, so either remove it or use the connection on the card). Do you get a black screen or no signal message on the monitor? Does the PC have more than one video output of the same type (VGA, DVI, HDMI, DisplayPort, etc.)? If so, try one of the other ones and see if they work. If you're not using a separate card and have either tested the other on-board ports or only have one, it could be that it has failed.
Jan 01, 2014 | iBuyPower Gamer Computers & Internet
NO VIDEO OUTPUT IN THE OUTPUT TAMINAL BAT Y SIGNAL OUT OK
hello,
check the RCA cable used to connect if it okay, if it okay, the problem will be from the printed circuit board..
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} tries websites like Shopjimmy.com,Ebay.com to buy parts or the function board for the replacement.
May 24, 2010 | Pioneer DV-270-S DVD Player
I just bought my 875WP1-E and hooked the monitor up to the onboard video port and when I power up the computer the monitor just says "no signal." What's up?
This is due to your system is not switched ON or not properly configured. Follow the below steps will resolve your problem.
1st Step: Have you hear any beep sounds? If yes insert the memory modules properly.
2nd Step: check whether the keyboard lights are flashing while switch on the system. if no, check the SMPS or SMPS connections.
Revert back for more assistance and give your valuable feedback/rating for the solution provided.
Thank you for using Fixya.
Feb 20, 2010 | Intel Server Board S875WP1-E Motherboard
No video output
Depending on your computer/motherboard there is either a bios setting or jumper you must disable to router video to your graphics card. It is probably still trying to output video on your integrated video card.
Hope this helps,
Bill
Oct 04, 2009 | Evga NVIDIA GeForce 9500GT,, PCI Express...
Still didn't work
You have to ensure *********** board is having PCI Express slot or AGP slot for fitting graphics card. if *********** board does not have then you cant use it. normal slot is not supporting it.
connect your monitor video card cab le to newly fitted video output not on motherboard.
Jul 05, 2008 | ASUS P5N-E SLI Motherboard
Ge force 6200 video card installation
Hi dl1099, your motherboard L7VMM2 can only run a 4xAGP video card as noted in your manual pg. 2 Settings pg. 36
If your not getting video at boot up switch connectors on the video card.
http://www.amazon.com/XFX-PVT44AWANG-GeForce-256MB-S-Video/dp/B000CQ73PW
Mar 25, 2008 | EliteGroup L7VMM2 Motherboard
Dell dimension monitor output broke away from motherboard and now i get no output to monitor to "wake it up", nevermind being able to see anything on it. As soon as i unplug the monitor cable from the pin...
Depending on how much it has broke away, you may be able to resolder it back on, or find someone who can. Other than that it will be a new board, I suspect.
It seems at least a few connections are OK, so probably worth a try, before scrapping it.
Jan 16, 2008 | Dell (W2562) Motherboard
No video output - Desktop HP minitower Pavilion 6635 - cpu Intel Celerom 533Mhz
Try either a pci or AGP card. On most boards, it will recognize the card without changing anything on the board. Does the hard drive and other components power up? Just the video not working ? If so it is probably the chip on the video, if not it could be a board failure.
Nov 27, 2007 | HP (5064-6630) Motherboard
ASUS M2N-SLI Deluxe Motherboard Logo
184 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
