Carrier jammed on printer
Carrier jammed on lexmark x5650 printer how do i fix it ?
  • 1 more comment
  • stoner35av Jan 31, 2009
    have tried taking ink cartridges out still saying carrier jammed
    still no joy carrier seems to be moving but making loud bang on left side
    thanks have tried all with no joy will take to be repaired
    Genius:
  • 2,920 Answers
It would be cheaper to buy a new printer than to get that one repaired...they run about 40.00 new and it would save some money in your wallet
Posted on Jan 31, 2009
  • 177 Answers
Hello and welcome to FixYa!,
It sounds like there is something in the Carrier such as Debris, Which is Blocking it /Jamming it!
Have a look and pull out what you see!
Hope this works for you, --P3NGYJ03
  • Jackson Henney Jan 31, 2009
    can you please rate my answer...
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
The could be 2 causes for a carrier jam error:
  • the encoder strip has ink smudges or bits of paper sticking to it; check, clean. The encoder strip would be the long but narrow clear plastic strip with barcode like markings. Other than the small bars, there should be no obstruction when a light is hined through it;
  • the guide rod. It is possible that the lubricant on the guide rod has dried up. The guide rod is where the carriage moves along. check, clean lubricate.
Post back how things turned up. Good luck and thank you for using FixYa.
    Genius:
  • 3,422 Answers
HI,
Please click on the below link and follow the instructions to clear the carriage jam:
http://images.lexmark.com/publications/pdfs/2007/3500/mhs/en/d0e10275.html
  • 1 more comment
  • Priya darshan Jan 31, 2009
    Did you try all the steps as mentioned in the link given to you?And did you try a reset by unplugging all the cords of the printer for 30min. and then plug them back in.Please let me know.
    There are two thngs that may cause the carriage to
    appear jammed - either the carriage really is jammed, or the encoder
    that measures the carriage position is giving an incorrect reading
    making it appear the carriage is jammed.
    Open the lid. Does the
    carriage move to the center or is it blocked? With the lid open unplug
    the power and try to move the carriage back and forth. If the carriage
    moves smoothly then you should clean the encoder strip which looks like clear plastic strip with the markings on it.
    Before trying this home remedy i suggest you to get it repaired if the printer is under warranty.Do not attempt to do this if your printer is under warranty.
    "The transparent encoder strip is the most important thing to fix it. Using
    rubbing alcohol and paper towel clean the strip. this problem get
    started when the assembly at the carrier stop position get filled with
    the dropping ink over the period of time. This assembly can be cleaned
    by removing it after getting access to it after removing two sides and
    backs of the printer. There are 2 screws in the back should be
    unscrewed and rest comes out after pulling the snap.
    IF you still face the problem then a physical presence of a tech will be required to fix the issue.
    Scholar:
  • 118 Answers
Open it up and make sure that the Ink Cartridges are placed properly. If that's not the problem, it could be the motors inside of it wore out, if it's pretty old you'll need a new printer, they are cheap nowadays. If you don't have the cash then call up the company, I'll get the number for you and I'll comment it to you.
  • Aron Jan 31, 2009
    Lexmark's number - 1-859-232-2000
  • 19,396 Answers
Try first unplugging the printer for ten minutes from power.
If the ink carriage is still jammed, try playing gently with the carriage.
  • Ginko
    Ginko Jan 31, 2009
    If the solution on my previous comment did not help, try the procedure descripted on website below, it is for a different model, but the procedure is the same:
    support.lexmark.com
I just bought ink cartridge and says ink low on my lexmark x5650 so i just bought ink cartridges for my hp 4140 and it wont work, is this a cproblem with my computer and not my printers? 2 printers do
As far as the Lexmark printer is concerned, try the steps below:
The problem could be due to a communication failure between one of the printheads (cartridges) and the All-In One (AIO) or by a short in one if the printheads. Please follow the steps below to identify and fix cartridge issues:
  1. Make sure the printer is on.
  2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
  3. Remove both cartridges from the carrier.
  4. Close the printer cover.
  5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
  8. Replace whichever cartridge is causing the error to appear with a new genuine Lexmark cartridge. Try to print a document again to verify that the problem is fixed.
Feb 12, 2012 | Lexmark X5650 AllInOne InkJet Printer
When i print the paper will jam
It could be that your cartridge is not properly inserted into the cartridge carrier. Try to open the printer and remove both your cartridges. Rebrick your printer by removing the power adapter (black box found on the back of your printer where the power cord is plugged in) and re-plugging after 30 seconds. That will give enough time for your printer to reset itself. When your printer turns on, re-insert your cartridges. Try to print a document again to verify that the problem is fixed.
Nov 10, 2011 | Lexmark X5650 All-in-One InkJet Printer
How do you close front to get ink cartridge out
Please follow the steps below on how to change the cartridges on your Lexmark X5650 printer:
  2. Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
  3. Press down on the cartridge carrier latch to raise the cartridge carrier lid.
  4. Remove the used print cartridge. Note: If you are removing both cartridges, repeat step 3 and step 4 for the second cartridge.
Jul 26, 2011 | Lexmark X5650 All-in-One InkJet Printer
I can't find the door? to open to put in a new ink cartridge
For the X5650, with the printer on, lift the scanner unit (lift from near the center - just above the keypad). There are supports on each side that will hold the scanner unit. The cartridge carrier should move into the replacement position. Then press down on the levers at the front of the cartridge carrier to have the cartridge lids open.
For pictures, see the manual: http://www.lexmark.com/publications/pdfs/2007/5600-6600/v7677571_en.pdf . Additional documentation is available here: http://support.lexmark.com/index?locale=EN&page=product&userlocale=EN_US&productCode=LEXMARK_X5650&focusedTab=PUBLICATIONS#1 .
I hope this helps.
May 31, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
Lexmark X5650 All-In-One InkJet Printer has a carrier paper jam how do i fix it
Hi. Here's an article in the Lexmark website that might help you out with the carrier paper jam problem. Just go to this link http://bit.ly/btHg8D. If you have tried all of the troubleshooting steps found in the article but still getting the same problem, you might be having a printer mechanical problem. If that's the case, I suggest you call Lexmark at 1-800-LEXMARK(1-800-539-6275) for assistance. Make sure to take note of the serial number found behind the printer.
Apr 25, 2010 | Lexmark X6575 All-In-One InkJet Printer
Hello there
ok try this my help you.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 25, 2010 | Lexmark X5650 All-in-One InkJet Printer
I havw a lexmark x5650, how do i get the fax to print out of the memory
my printer lexmark x5650 says the carrier is jammed how do i fix it
Mar 19, 2010 | Lexmark X5650 All-in-One InkJet Printer
My lexmark x5630 x56xx series displays carrier jam the carrier bangs to the left, i saw a thin strip of plastic in the printer looks like its broken off from something please help
just try to fix it .but i think it is broken so you need to replace the broken part i advise you to show it service center.
Have a nice day and do not forget to rate please...!
Feb 03, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
I have a lexmark x5650 and evertime I try to print something the paper will feed through on one side and not the other so it doesnt print properly. also it says paper jam. any ways to fix this??
if you have a paper jam error and you don't see a Jam it means the printer just needs to be reset.
Please try this to do a partial reset. Leave the printer on and then unplug it and leave it unplugged for about 1 minute and then plug it back in and turn it back on and see if the problem persists.
About the paper feed, first check the printer preferences, go to start, select printer and faxes. Mark the Lexmark printer, click right mousebutton and select properties from the menu list.
Check that you have set paper size to DIN/A4 and adjust your other settings as needed.
If the problem persist check if you have the latest drivers installed, if this doesn't help I think you will need to contact lexmark support.
Aug 26, 2009 | Lexmark X5650 All-in-One InkJet Printer
I have a paper jam in my lexmark x5650
hi try firstly to open the paper mount and then put ur hand to see if there is a paper jam there if not, try to open the color cartridge mount and remove the colour cartridge and install it back again if not, try to turn it off and on again.
Jun 07, 2009 | Lexmark X5650 All-in-One InkJet Printer
jasbo
jasbo
