Question about Maytag Neptune FAV6800AW Top Load Washer
My maytag neptune wash machine does not drain and spin clothes it
Blinks dc but i ran it empty and it worked ok what do I do? I am out of warranty. This machine is a nightmare
  • 640 Answers
Its ok dc means the clothes are unbalanced..even the load open lid and restart..onthejob
Posted on Jan 31, 2009
Brew Drive Motor 33V DC with 7V DC.
Sorry but this device is specially made to be , so called , NOT FIXED!
You can still contact the shop/store where you bought the product and ask for a repair.
Sep 08, 2012 | Saeco Vienna De Luxe Espresso Machine
We just moved and the house came with a Maytag Neptune TL which won't spin if there are clothes in the cylinder. It will spin empty. Please help! Thanks.
Washer bangs around in spin cycle and throws a DC or UC unballance code with cloths in the wash basket is that correct?
If so it's a Clutch issue.
If you want read more about what I feel is your issue read this post Maytag Neptune load unbalance
Sep 08, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune MAH8700AWW washer will not complete the spin cycle. It spins both directions but never goes past 6 minutes on the display. Eventually you get the "DC" error. It does this with or without...
If the clutch fails the first thing noticed is a UC or DC error displayed and there is no drain or spin.
If you are seeing the above error and having a problem with spin and drain then the most likely cause of this is the clutch. The clutch fails to lock down the spinners and the basket is unable to go into spin and without a 90 RPM there is no drain.
Replace the clutch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question(&^%
Sep 15, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Maytag - MDB6769AWB touch panel blinking
Time to call the business that sold the machine for warranty service or immediate replacement! The threat of losing a sale will usually get them off the dime in short order. Hope this gets the problem(s) resolved in a hurry. Good luck!
Jul 24, 2010 | Maytag MDB6769AW Builtin Dishwasher
Will not spin fast enough on final spin cycle to
ITS POSSABLE ITS NOT PUMPING FAST ENOUGH. CHECK THE DRAIN HOSE AND MAKE SURE IT HAS NO KINK. IF THATS OK IT MAY HAVE A BUILDUP OF SOAP. RUN A EMPTY CYCLE WITH NO SOAP. IF THAT DONT WORK YOU NEED A REPIARMAN TO CLEAN OR REPLACE THE PUMP.
May 15, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune TL clothes still dripping wet after full cycle
Pump out time of 40 seconds sounds good.
No ND error code and you spin up to 850RPM which is max for the machine.
You have no standing water in the wash basket.... I'm scratching my head.
Could you do a Spin Only cycle with that same wet wash load and set the SPIN for Max Extract. After you start the Spin Only cycle put the machine in Service Mode and watch the RPM range. This cycle sets the display to 12 minutes. Let’s see if the wash load remains wet and what max RPM is reached.
""Maybe the pump is not turning on during the spin cycle?"" You have no standing water in the wash basket correct? I feel the pump is turning on or you would have standing water in the wash basket and the pressure switch would have never indicated an empty condition (Low Level pressure switch contacts) to the Control Board. The Control Board would have stopped the wash cycle with a ND for no drain error code.
The pump in the spin cycle will turn on a number of times see if you hear turn on in a Spin Only cycle
I just ran a Spin Only light wash load with about 5 gallons of water in the wash basket. Timer went to 12 min. I toggled into Service Mode to watch wash basket RPM. At about the 5 Min mark (toggle in and out of Service Mode) the wash basket reached 850RPM then a few minutes later it stepped down to 830RPM to end of Spin Only Cycle. You don’t have a water valve stuck open or you would flood/over flow of the machine. Did you here the drain pump turn on several times during the Spin Only cycle?
Rich
Apr 08, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Averatec 3120V - AC adapter light blinking, no charging
get another ac adapter or check if the power dc jack is loose.
Apr 01, 2010 | Averatec 3120V Notebook
I Have a Neptune HE TL fav6800aww and it keeps giving me the DC error code which i understand is a balance code but i emptied the washer and ran it and still get the code?
hris,
The FAV9800AW the dc/UC errors are caused by a clutch malfunction.
Your machine is shutting down with those errors so your Tub Displacement Sensor is working as designed.
Fix the Clutch malfunction and you can wash a single sock or a load of blue jeans and you will not take the dc or UC unbalance errors. See this post for the fix.
It is a tight work area but if you are handy you can get away with a re-lube of the One-Way rollre clutches in the clutch pully you could be working today. If you need to replace tthe clutch I recommend a $60 clutch. Call in a repair service and you are looking at around $300. I will help you thru the process.
Post back if you have questions or need help.
Rich
Oct 11, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
291 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
