Can i get the code to reset the machine
I'm getting a CH error, what does this mean and how can I fix it?
Posted on Feb 12, 2009
Sharp - How to reset code
To enter service mode press thesekeys: orange C button,Interrupt, 0, Interrupt. The screen goes black when you have done itcorrectly. It may take a few tries – must be done in certain time.
To clear the maintenance indication (service man): press 20, start,1, start (the display will start to flash when entered correctly).Power off/on to make the copier dude go away. Good Luck!
Posted on Feb 01, 2009
SOURCE: Sharp AL-1631
try this. Press C (cancel), Press Auto, Press C, press Auto
Enter 14 (code) e Press Print (green)
It´s a code to cancel H4, if it´s don´t work, send me e-mail to montgomery@brturbo.com.br
Posted on Feb 15, 2008
SOURCE: Sharp AL-1631 coper - toner problem
the problem in your machine is on the drum unit there is a arching on the mc unit.located in the upper portion of the drum unit.if you have an old drum unit try to install it again just for testing.and check if ther is a dumping toner again.
Posted on Nov 05, 2008
SOURCE: SHARP AL-1631 DIGITAL COPIER SHOWS ON THE SCREEN CODE H4
your copier is problem over temparature.h4 signal is blingking so it is over temparature or it fixed so heater lamp is burning program c photo c photo then press 14 press print key then machine is ready
Posted on Jul 20, 2009
SOURCE: Fixya: Sharp AL-1631 copier doesn't recognize new drum?
press the following keys in this order:
once the panel goes blank make your display show
Then press C until the copier restarts.
Posted on Oct 16, 2009
Testimonial: "Wow! A solution to my problem with a copier was posted within a couple of hours, and the procedure worked perfectly! Thanks. OB "
SOURCE: sharp al-1631 copier. drum error code
You can reset this indicator by pressing these keys in sequence:
Press "C" then press "Exposure Mode" then "C" again then "Exposure Mode" again.
Note that the Exposure Mode key is the far left key on the panel.
One you press these 4 keys in sequence the display should go blank. Then key in 24 as if to make 24 copies. Then press Print (Green Button)
Then key in 7 as if to make 7 copies.
Press print again. You should now get flashing 000.
Turn machine off then back on and the light should be gone.
Here it is in a short version:
C, far left, C, far left, 24, print, 7, print,
then power off and back on.
Posted on Nov 16, 2009
Testimonial: "Ok sorry thank u. I am new sorry i will be better in the future."
Oct 23, 2013 | Sharp AL-1631 Digital Laser Copier B/W...
Aug 12, 2012 | Sharp AL 1631 Copier
Feb 06, 2011 | Sharp AL 1631 Copier
Dec 26, 2010 | Sharp AL 1631 Copier
Apr 28, 2010 | Sharp AL 1631 Copier
Mar 07, 2010 | Sharp AL 1631 Copier
Nov 05, 2009 | Sharp AL 1631 Copier
Aug 09, 2009 | Sharp AL 1631 Copier
Jun 12, 2009 | Sharp AL 1631 Copier
Jul 24, 2008 | Sharp AL 1631 Copier
Jun 12, 2014 | Sharp AL 1631 Copier
Mar 17, 2014 | Sharp AL 1631 Copier
402 people viewed this question
