Question about Jenn-Air JED8430 Electric Cooktop
Wiring for a jenn air cooktop jec8536adb
We have black and white coming in and black, red, and white on the cooktop. which wires go together?
  • susan young Jan 31, 2009
    which wires go where
  • 257 Answers
Hi, I'm sure by now you probably have this fixed. Anyway, It is important that you know some information, like what the voltage is of the black and white wires coming in. The electrical codes in most places call for the 3rd wire which would be a neutral. If the old wiring has a metal conduit it is possible that it is being used as a ground and it may have been assumed that if the ground and neutral wires in the distribution panel were connected to the same bus that it wouldn't matter. Not the safest way to go but it will still work if you have no other wires. The incoming would probably be each a 110vac leg which the black would connect to black and the red from the cooktop would connect to the white of the incoming and the white of the cooktop would be sealed off. If you need additional help please let us know. Good Luck!
Posted on Feb 08, 2009
Do i connect the red and black wires together
No you do not. You have a 220 system. What you do to hook it up is. In the box in the wall you should have 3 wires. 2 black and one white. Then on the cooktop you have the 3 wires 1 black, 1 red, and 1 white. You take the black from the cooktop to the black in the wall box. Take the red to the other black in the wall box. then take the whites and put them together. Now if you have a green or bare wire that is the ground. Just hook that to the wall box.
If you have any questions please ask.
May 09, 2010 | Jenn-Air JED8230 Electric Cooktop
Wire from circuit breaker is Black/White/Bare(ground). From Jenn Air is Black/White/RED/Green (ground). How do I wire? Jenn Air Black to Black, Jenn Air Red and White to White? Grounds (Jenn Air Green to...
depending on your local electrical code:and I see that the unit is 240 Volts A.C., then RED=Power/Black=POWER(L1 & L2)/WHITE="N"Neutral/and GREEN=SAFETY GROUND,on the new unit, then use from the wall power BLACK = L1 and White= L2. then on the unit RED=L1 and BLACK=L2(either way you hook these 2 up there isn't a polarity issue on these 2 wires) on the units hook-up/then use the BARE supply wire as neutral and tie BOTH WHITE and GREEN from the unit together to this BARE wire
Apr 29, 2010 | Jenn-Air JED8230 Electric Cooktop
How to wire a jennair cooktop. I have 3 black wires all hot. The cooktop has 4 wires black, red, white, and green(ground)
The wire coming in should have the same colors, just match up the wire colors and wire nut them together with large wire nuts ad them tape them. ground the green wire to the ground screw.
That's all there is to it!
Jan 26, 2010 | Jenn-Air JED8230 Electric Cooktop
Fixing wiring
yes, that is the correct wiring
Feb 08, 2009 | Jenn-Air JED8430 Electric Cooktop
We have a Jenn air jed8430. It was installed but never supplied power to it or tested. We want to make sure the wires are right before powering it up. Black is with Black. Red is with Black with Red...
I just looked, and there is not a wiring diagram available on the web for this unit.
I am concerned about the black with red stripe to red.
Check to see if there is a wiring diagram somewhere on the unit (there wasn't one in the installation instruction or manual for this unit.). I believe the red wire on the house side goes to the black/black wire on the cooktop side (so I believe you are correct on your concern.).
House side green should be to the coiled silver cooktop side silver wire.
But the wiring diagram will confirm these things.
I think the black/red stripe is for the blower.
Jan 28, 2009 | Jenn-Air JED8430 Electric Cooktop
How to wire a jenn air cooktop JEC9530ADB
the new cooktops and ovens now have a 4th wire used for separating the ground and neutral. some new homes and remodeled homes have a 4th wire run from the circuit panel to the unit.
you dont have this but it is ok to just hook up the white and green/ground wires together. then red to red and black to black. it will work properly and thats all you have to do.
Dec 29, 2008 | Jenn-Air JED8430 Electric Cooktop
JEC8430 ADB cooktop wiring doesn't matchup - no instructions for this situation
hook the copper and white together. DO NOT leave the white unhooked.
Nov 24, 2007 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JED8430 Electric wiring confusion
On Cooktop From Box
Black to Black
Red to Black w/red stripe
White to Ground
Green to Cooktop frame
Nov 16, 2007 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JED8430 Electric Cooktop Logo
164 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
