Question about Frigidaire FDB641RA Built-in Dishwasher
Dishwasher not completing cycles
I have tried new timer, cleaned filter, checked heating element, etc... but for some reason my dishwasher will not end cycles. For example after short wash cycle, the dishwasher will continue to run forever, full water and spraying, unless I push past to next cycle (rinse cycle) by turning timer manually. This is why I thought there was a timer problem, but this proved not to be the case. What else could it be. I thought there might be a another sensor that I did not think of before that indicates to dishwasher it can move on ... is this possible and if so what could it be?
  • 4 more comments
  • Michael Loh Aug 09, 2007
    It seems that the water is heating up. The element definitely gets hot. When tub fills, should water actually be over heating element? It seems to me to be just below - perhaps not enough water?
    Problem still exists. I do not see relay in wiring diagram, perhaps it is in timer which in my case is now new.
    If I turn off for hi temp wash, all is fine, everything proceeds. The element does heat up for dry cycle.
    Element measures at about 13 ohms, is this close to correct?
    I will likely try new thermostat...but thought I would see if you had any other ideas.
    I did a few experiments yesterday - water level does not actually get to float before it stops filling. Is this normal?
    When it was approaching cycle where it stalls, obviously waiting for temperature to reach certain level - I filled dishwasher with more water using sink hose, getting water at least to level of float.
    In this case, it worked, the dishwasher cycle completes and it moves on.
  • Michael Loh Aug 12, 2007
    Crytech,
    Thanks for your input, it helped towards figuring out issue. Essentially my thermostats needed replacing and also as water level does not get very high, takes a little longer for water to get heated to appropriate level, or at least for thermostat to pick it up.
  • Mark Mar 06, 2013
    Michael sounds like i have the same issue. Timer OK, element OK, could you send me a picture of your thermostat, i think mine is integrated into the heating element . however not sure. Also heard it could be the relay any extra help would be appreciated.
  • Anonymous Mar 18, 2014
    it will run a rinse cycle no issues but not a full wash and no water heat cycle
  • Anonymous Mar 21, 2014
    The timer will not move to the next cycle. Sticking on programme.
  • 51 Answers
Is the water being heated??? When the timer reaches the stage where it will not move forward any further, after 5 minutes or so, open the door & see if the water is heating up. The timer often waits for the water to reach the correct temperature. Temp is measured by the thermostat. If the element tests OK, then it could be the relay that switches the element. The relay is turned on & off by the timer. I would say that if the timer is OK & the element has the correct resistance, then it is is more likely to be the relay. Last resort would be the thermostat, but my money is on the relay.
Posted on Aug 01, 2007
  • Ian Aug 12, 2007
    Water should reach a certain level within a specific time. could be your water inlet is restricted & the little filters in the intake vale or hose are semi blocked. Or your water pressure has gone low for some reason.
SOURCE:
Bosch shx43c at end of cycle doesn't completely drain. leavs some dirty residue on dishes (water temp set at 120) cleaned filters water standing in lower filter basin (creates odor) and took hose...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Jun 25, 2011 | Bosch Integra 300 Series SHX43C0xUC...
I have a maytag mdb5130 that the soap is caking in the dispenser so not going out and cleaning dishes
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Apr 17, 2011 | Maytag Dishwasher
Maytag dishwasher mdbh950aws does not clean dishes completely leaves residue on glasses and plates. using normal cycle. does any lines or filters need cleaning? followed all recomendations in manual.
Dishwasher
How to Buy
heatman101
Dec 08, 2010 | Maytag 24 in. MDBH950AWS Built-in...
My 24 in dishwasher the timer is not working correctly and is not cleaning the dishes, also water is standing in the bottom of washer at the end of the cycle.
heatman101
Nov 16, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
The heating / steam cleaning cycle does not seems to be complete
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
ll
Jul 16, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
Kenmore elite dishwaher 1646 not cleaning dishes.
heatman101
jklfryyr
Jul 06, 2010 | Kenmore 24 in. 16462 / 16464 / 16469...
My Dishwasher (Westinghouse907 series) will not advance past the prewash/rinse cycle. I have cleaned out the filters. I also turned it off for a while and when I turned it back on it worked, but has now...
Hi
Thanks for using FixYa. If the cycle doesn't complete, then the first thing that should be checked is the Timer and then the heating element. Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it. Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
May 23, 2010 | Westinghouse 24 in. MDP531 RF...
I have a Vikin Dishwasher Model DFUD042 and the arms are not circulating water. When we start a cycle it drains previous water then fills it up after that it runs thought its regular cycle but the arms are...
heatman101
42gda
Apr 21, 2010 | Viking 24 in. Professional Series VUD141...
Dishwasher is not cleaning dishes
heatman101
k
Apr 14, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
My dishwasher is not cleaning dishes - it is running through its cycles, but when it is done, there is a heavy residue of soap and hard water and the dishes looks worse than when i put them in.I've changed...
Hello there:
There are 6 areas that could cause this to happen Please follow these simple steps ok
Investigate each of these six areas if your dishwasher is not completely cleaning your dishes:
Water Inlet Valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Upper or Lower Spray Arm
Your dishwasher has a lower spray arm. It may also have an upper spray arm at the top of the dishwasher. These spray arms are designed to shoot high pressure, high temperature water at your dishes. It is possible that the holes of the spray arms, where the water comes out, are blocked with debris, affecting wash quality. You should inspect your dishwasher's spray arms regularly. Clean out the spray arms as need be.
Heating Element
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Filter/Drain Grate
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher. Consult your owner's manual for specific directions for removing your dishwasher's filter and cleaning it.
Detergent or Detergent Cup
It could just be that you aren't using enough soap to completely wash your dishes. Your dishwasher may be designed to dispense soap at two different times during the wash cycle. If you don't fill all of the detergent cups, then the diswasher will lose a cleaning cycle. Also, if you use a gel-type detergent, try switching to a powered kind. Powders tend to dissolve better in hot water. And don't buy in bulk. Detergents are most effective in the first two weeks. After that, they decrease in potency.
Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, please see our section My dishwasher detergent cup won't open.
Cycle Selector Switch
Sometimes a dishwasher's cycle selector switch is the reason why dishes are not coming completely clean. Test your selector switch to determine whether or not it has become defective. If it has, replace it.
Dec 30, 2009 | Kenmore 15899 Built-in Dishwasher
Frigidaire FDB641RA Built-in Dishwasher Logo
352 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Archie Ferrarini
Archie Ferrarini
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
