Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Cleaning the bulbs and mirror on my Mitsubishi 55" WS-55313 TV.
I have a Mitsubishi 55" WS-55313 projection TV and I wanted to open it up and make sure the lamps and the mirror are clean to get the best picture possible. Is there anything I need to know to first open the TV to get the best access to the lamps/mirror, what do I use to clean everything so I don't have any future issues, and what do I need to look out for so I don't trash the TV. Step by step instructions would be greatly appreciated. The warranty is up.
Thanks for any help,
  • 139 Answers
You should re-consider having a tech do that for you. The access is by removing the screen assmbly which are somewhat fragile. If you want to give it a try, pull the speaker grill off, it comes off just from pulling it, there should be five screws across the bottom of the screen assy, remove those, there is also an access door on the front of the set with four screws, that has to be removed to unplug the cable that goes to the screen sensors. The screen assy has to be lifted straight up an inch or two and then you can pull it forward away from the set.
As far as cleaning the mirror and lenses, you can't get to the face of the tubes so it's the top of the lenses that you clean, just use a soft lint free cloth (cloth baby diaper) and wipe the dust off the lenses, you can slightly dampen the cloth with water if necessary, same type of cloth on the mirror and you can use a glass cleaner on it just don't press too hard on the mirror.
Posted on Feb 05, 2009
My 55313 power light dose not come on
The SMPS section is not oscillating. Your TV need a through checkup. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electric shock. Instead, contact any experienced service technician, or the nearest service center.
Apr 24, 2013 | Mitsubishi WS-55313 55" Rear Projection...
Mitsubishi ws-55313 vertical hold problem with tv
This set does not have a vertical hold control etc---try to explain what the set is doing or not doing so I or another expert can help you.
SD TECH
May 18, 2011 | Mitsubishi WS-55313 55" Rear Projection...
Hi, i need a circuit board for a ws-55313, tv no is js-5531378010478
Encompass Parts Distribution has List of Parts/Prices and Free Service Manual that you can print out online 1-800-638-3328
Model# WS-55313 Your Model# will be printed on the back of the TV.
Nov 09, 2010 | Mitsubishi WS-55315 55" Rear Projection...
I have a Mitsubishi WS-55313 55 in. Rear Projection HDTV. My problem is, the picture suddenly goes to a black screen, while the audio remains. When I turn the TV off, and then back on, I may or may not get...
your dose not use lamp, it is a crt driven TV . One of com problems for that model was loose connection on one of the yokes. When that normaly happens , there is a sudden flash and screen gose dark and sometimes it can flash back if not you get red light blinks. If you you know where the yokes are at check little small board . A small mirror will come in handy, access from front of TV. adios ... john
Mar 31, 2010 | Mitsubishi WS-55313 55" Rear Projection...
WS-55313 55in. Stored in cold garage fo two days will not power up in warm house. What next?
Leave it unplugged and let it sit for atleast 6 to 8 hours to become at room temp..Do not try to turn on anymore to where it could blow the bulb.After its sat that long atleast plug it in and enjoy..There is a protection relay in the tv to protect the bulb.Hope this helps you and have a great day
Dec 08, 2009 | Mitsubishi WS-55313 55" Rear Projection...
HDTV Reception
Yes , If  a  high definition device is connected to the tv then you can watch high deff tv.
Dec 21, 2008 | Mitsubishi WS-55313 55" Rear Projection...
Deflect power supply
PCB Power has the Deflection Power Supply onboard and has a list price of $215.50 + S/H
Nov 10, 2008 | Mitsubishi WS-55313 55" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
1,888 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
