Question about KitchenAid KAWS850L Top Load Washer
How do I replace the drive coupling?
The machine became unbalanced during the wash cycle, smelled like burning rubber and stopped working.
  • 640 Answers
Ok ...unplug unit first...remove the 2 screws on each corner with a phillips head screw driver..if the screws are not in the front console corners there on the back...now flip the console back and let it hang..look at the top of unit remove lid swtch connection..2 gray wires on one side and a brown and greenist,,connnected by a white connector...ok at each end theres a brass clip on booth corners..pry the up with small screw driver...now pull the cabnit toward you,,jus the cabnit ,,move it to the side,,now we have to kneel down,,,the white plastic pump have to be remove,,push the bottom clip down and the upper clip up..i do it with my hand you made need a pair of pliers..dont take the 2 big black hose of pump just let the pump hang,,,ok your going to reach around on the right side of the motor and remove that connection just press down on the top on the connection clip...good ...now remove the motor clips you may have a 1/4 nut driverscrew through the clip ..remove clips the same way you removed pump clips..now change your broken drive coupling...just reverse to put toghter...onthejob please rate on completion..
Posted on Jan 31, 2009
MACHINE STOPPED - BURNING SMELL COMING FROM WASHER
The burning smell is from your coupling and when this breaks the rubber spins across the plastic face of the opposite coupling. Your washer will not wash or spin until this is replaced. fortunately these are cheap and easy to replace. Refer to my step by step instructions to replace yours.
Here is the guide:
http://www.fixya.com/support/r4355933-washing_machine_repair_direct_drive
Mar 24, 2010 | Washing Machines
During spin cycle a grinding noise starts and a burning smell develops if I let it spin on then smoke comes out
could be your motor coupling, clutch or brake linings. if it smells like rubber burning then it is your motor coupling,, ,,,,mine was doing that and found out the clip that holds on the part to disengage the brake had ground off the end of my basket drive tube and the arm fell down thus no spin ,part cost more than the washer is worth! guess i'll be picking up a new 1! yea the grinding noise could be in your clutch,brake area!
Feb 10, 2010 | Kenmore Washing Machines
I have a Kenmore series 90 washing machine, Model 110.26902691. I changed the motor coupling last week and after being proud of my work, I was able to complete one cycle before I started to smell a burning...
Considering the info you`ve provided, specific to the history of replacing the drive coupling. You stated that right after replacing the coupling it started to smoke or as you said "I started to smell a burning smell". Can you identify if it was electrical, or was it rubber/plastic ?
I`ve seen these coupling`s when not put on correctly start to rub against the motor or the transmission, you might want to double check your work with installing the coupling.
Aside from that it could possibly be the motor, but if it agitates and manages to advance through the wash & rinse cycle up to the spin, I`d be skeptical of a motor problem. You should check to make sure the lid switch is being fully closed, in the event it isn`t closed properly the unit will do everything except spin.
Hope that help`s. Good luck.
macmarkus :)
Dec 08, 2009 | Kenmore 24902 Top Load Washer
Washing machine spins slowly and smells of burning rubber
The belt could be worn and will be slipping on the pullys, as it spins up the rubber , rubs against the pullys and that is what creats the burning rubber smell, the belt needs replacing.
regards jonno
Apr 21, 2009 | GE WBSR3140DW Top Load Washer
Empty washer tub wobbles during spining, plus burning smell
BOTTOM OF TRIANGULAR PLATE ARE 3 SKID PADS, USUALLY WHITE OR BROKEN HALF MOON SHAPE WHEN WORN OUT RESULTS IN THIS
Nov 30, 2008 | Kenmore 24032\24036 Top Load Washer
NAV6800AWW - noisy
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 04, 2008 | Amana 3.2 cu. ft. Top-Load Washer
NAV5800a top loader washer
The inside of your agitator became worn, and possible strip out the spline that allows the agitator to properly grip the shaft. The loud noise mustly occurs during the spin cycle. If you hear this loud noise your load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it.
Sep 02, 2008 | Amana NAV5800A Top Load Washer
KitchenAid KAWS850L Top Load Washer Logo
112 people viewed this question
Top KitchenAid Washing Machines Experts
Sal DeAngelo
thinksewfast
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
