Question about EliteGroup P4VMM2 Motherboard
Memory Upgrade - from 256DDR1 to 1GB DDR1
Problem is that after adding the 1 GB pc3200 184 pin dimm memory I'm getting a continueous beeping upon booting up the PC. It finds the additional memory ok but then within a few seconds it beeps.
I even took out the 1 GB memory to leave only the 256 but the result is the same
On the board there's 2 DDR1 slot and 2 DDR2 slots.
Intel Pentium 4 2.4mhz
Model p4vmm2
Type X86
  • sysa007 Feb 01, 2009
    Thanks map9966
    I have tried a few times re inserting the 256 DDR with the same result. Could it be there's some other problem? What about the 1GB DDR PC3200, you said that it should be PC2100. Is it possible that have caused problem
    sysa007
If you go to the ECS website, there is the option to download the manual for the motherboard (make sure you get the right version). The manual will point out which jumpers you have to move or remove to get the memory to work. Hope this helps
Posted on Feb 13, 2009
    President:
  • 2,351 Answers
Sysa007,
EliteGroup makes two mother boards, P4VMM2, (No Revisions) & (P4VMM2 revision 8.1). Since your question states your memory is 184 pin DIMM your board must be, v 8.1. What does not make sense is the motherboard has two memory slots total.
(If you have 4 memory slots on the MB than the MB can not be the P4VMM2). Below is the link for the P4VMM2 (v8.1).
http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?CategoryID=1&TypeID=1&DetailID=436&DetailName=Feature&MenuID=45&LanID=9
The P4VMM2 v 8.1 can only use, two Double Data Rate (DDR) SDRAM memory modules. These sockets support up to 1GB system memory using 184-pin unbuffered non-ECC PC2100 or PC1600 DDR DIMMs. The two DIMMS you are using must run at the same speed.
Example PC2100 266MHz. OR PC1600 266MHz.
Continuous beeping means the memory is not seated correctly.
When using only one DIMM it should be inserted in the slot closest to the CPU. Re-check your memory. Remove & reseat. Make sure the latches snap closed on each stick of memory while inserting. Below is all of ECS P4VMM motherboards;
http://www.ecsusa.com/ECSWebSite/SearchResult.aspx?q=P4VMM2&f=Products&MenuID=104&LanID=9
Good luck sysa007!
More question, post here.
Thank you for using fixya.
If you find this helpful, please vote.
Mike
Posted on Jan 31, 2009
Can I upgrade my acer 5315 memory to 2GB with two 1GBs in two slots or I can put two 2GB slots adding up to 4GB? Thanks
You can upgrade it to 2GB (MAX) if icon_detail.gifMemory Type: DDR2 PC2-5300, DDR2 (non-ECC)
Maximum Memory: 2GB
Slots: 2
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.
Hope this helps.
Jun 17, 2011 | Acer Aspire 5315 Notebook
My name is Siavosh Eskandari. I have a desk top PC Compaq presario Desktop with Intel celeron processor 2.7 HHz Model SR1010NX, Prod. # DW25AA-ABA,Serial # MXK4180P8Y with 256 MB PC 2100 DDR SDRAM. The...
the model SR1010NX can take upto 1gb max of ddr 1 ram and must be done a 2x 512 ddr 1 chips
Memory Component Attributes Memory Installed 256 MB (1 x 256) Maximum allowed 1 GB (2 x 512 MB) requires the replacement of the installed 256MB DIMM Speed supported PC2700 MB/sec (messages at PC2100 Type 184 pin, DDR1-333 SDRAM DIMM slots Two
Nov 28, 2008 | HP Computers & Internet
Upgrade ECS FSB800 memory from 1 GB to 2 GB wont work
This board will support up to 2gb as shown below extacted from the website product page.Don't forget that if you have ddr 333 memory installed originally, you can only add the same clock speed memory, i.e. ddr 333. If you add ddr333 and ddr400 you will have problems as the clock speeds do not match. If you are matching clock speeds, the try bootin the system with the new piece of memory on its own to see if there is a problem with that stick, trial an error of both sticks individually, will give a positive result
MEMORY ecs_buttom_03.gif Single-channel DDR memory architecture ecs_buttom_03.gif 2 x 184-pin DDR DIMM socket support up to 2 GB ecs_buttom_03.gif Support DDR400/333 DDR SDRAM
Nov 02, 2008 | EliteGroup ECS P4M800-M Socket...
Ram issue with compaq presario 5000 G1 Series
as you can see from the information below there are different requirements for RAM to work stable in your system . Most importand are the RAM VOLTAGE , SPEED , and Configuration of chips. you will need to consult the manual for qualified RAM requirements. Some RAM will work but not very stable. make sure the voltage supplied by your system is enough for the RAM. If you are running DDR RAM in dual channel mode, the ram needs to be the same size also. DIMM modules for the HP computer must meet the following requirements
  • The number of pins on the DIMM must match the socket type.
  • DDR memory requires a 184-pin slot and 1.8 operating voltage.
  • DDR2 memory is not compatible with DDR1 memory and requires a 240-pin slot and 2.5 operating voltage.
  • Synchronous dynamic random access memory (SDRAM): Only use DDR type SDRAM memory if the computer came with DDR-SDRAM.
  • SO-DIMM modules for the HP computer must meet the following requirements
    • SO-DIMM memory requires a 200-pin slot.
    • DDR2 SO-DIMMs are not compatible with DDR1 DIMM and DDR2 DIMM memory modules.
    • With a computer running at a system bus of 533 MHz or 667 MHz, use a PC2-4200 (DDR2 DIMM 533) type.
    • The following requirements must be met for the DDR memory to function in dual channel mode:
      • Same density (256MB, 512MB, etc.)
      • Same DRAM chip technology (x8 or x16)
      • All either single-sided or dual-sided
      • Matched in both Channel A and Channel B memory channels
Oct 22, 2008 | Compaq Presario 5000 PC Desktop
Intel D865GBF Ram related questions
here are the specifications of *********** board go through it...
Processor Support Intel® Pentium® 4 processor, Intel® Celeron® D processor and Intel® Celeron® processor in the 478-pin package
Note: It is important to verify supported processors before using this Intel® desktop board. Supported front side bus speed 800, 533, and 400 MHz Integrated Graphics Intel® 865G Chipset with Intel® Extreme Graphics 2 Chipset Intel® 865G Chipset AGP Connector AGP 3.0 (4X & 8X Speed 1.5 and 0.8 Volt Only) Memory Type Dual Channel DDR 400 MHz (PC3200), 333 MHz (PC2700), and 266 MHz (PC2100).
Note: Be sure to review important memory and system bus speed considerations before using this Intel® Desktop Board Max Memory Capacity of up to 4 GB Memory Slots 4 DDR DIMM Sockets Slots 6 PCI
So it will support DDR2 and you can upgrade upto 4GB...
Sep 28, 2008 | Intel D865GBF Motherboard
DDR2 RAM for P5RD1-VM
The ASUS P5RD1-VM takes the PC2700/3200 DDR SDRAM DIMMs. You can upgrade your ASUS P5RD1-VM to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory. For best system performance use the maximum amount of allowed Memory per slot for your system i.e. 1 GB.
Thanks
Iqbal
Apr 14, 2008 | ASUS P5RD1-VM Motherboard
High density memory
need low densisty on ebay 35 buck eash 1 gb ok works on picky mobos way better
Feb 07, 2008 | Dell (E210882) Motherboard
Can't Install RAM in DDR2 and DDR3 DIMM slots
You cannot use DDR and DDR2 ram at the same time, because its always been like that (ie, no SD and DDR, or SD and RIMM)
What you should do is switch to all DDR2 sticks.
Jan 09, 2008 | Gigabyte GA-8PE667 Ultra Motherboard
Intel ASUS P4 845 GL Motherboard
Hi, For an ASUS P4BGL-VM Intel 845GL Chipset Ultra ATA100 MATX CPU Type: Intel Pentium 4 478-Pin (OEM), the Asus site specifies max of 2 x 184-pin DIMM Sockets support max. 2GB PC2100 / PC1600 non-ECC DDR or SDRAM memory but not "and". Personally, I find it more practical to install 2 X 1Gb rather than a single 2Gb. Hope this gives you some idea. Kind regards.
Aug 07, 2007 | Intel ASUS P4BGL-VM 845GL Chipset Ultra...
EliteGroup P4VMM2 Motherboard Logo
311 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
