Question about Refrigerators
Replace dispenser arm
Hello....any idea how to replace the water dispenser arm on my Kenmore Elite refrigerator model 106.53293202
  • 410 Answers
On the bottom of the ice dispenser front cover is 2 slots insert a small screw driver into these slots and carefully pry the cover off (be careful not to scratch your door) one the cover is off there will most likely be a wiring harness that you can unplug and put cover out of your way. next you will need to move the white bracket out of your way there is either 2 thumb latches or 2 screws that seure it. it will not come all the way out so you may need someone to hold it out of the way for you. in the center of both of your levers you will see 1 screw with a cardboard spacer and brass spring BE CAREFUL NOT TO LOOSE THESE! remover screw spacer and spring afte that you should be able to work the levers right on out. the ice lever is a little tricky trying to get it around the ice door but it will come out.
Posted on Jan 31, 2009
How do I remove ice and water dispenser from a Kenmore Elite refrigerator model 795.72043.110?
Hello Nelson;
My name is Peter. I am a retired field service refrigeration technician.
Most of the components to be removed are secure with plastic pop out tabs. Look under the bottom of the front cover, there may be a screw on each side in addition to plastic tabs. With a small flat head screw driver pop the cover off. Be careful these tabs are easily broken. Ground yourself by touching something metal. Static electricity will knock out a control board.
Go into the following website. Type in your model number. You will get an exploded view of your dispenser. Water Filters Lawn Garden Appliance Parts
Dec 14, 2014 | Kenmore Refrigerators
Kenmore side by side refrigerator water dispensor will not shut off
Your water control valve is defective and will need to be replaced. Even though you hear the electrical part of the valve turn off the mechanical part of the control valve is stuck open causing water to continue to flow. What is your model number? Kenmore model numbers look like this example=> 312.234567 If you can find your model number I will show you the replacement part number, Thanks Sea Breeze
Nov 29, 2012 | Kenmore 18.3 cu. ft. Top Freezer...
No water coming from water dispenser.
It is possible the water control valve for that dispenser has failed and will not open. This happens a lot for those and the ice maker valves. All you need is the model number for your refrigerator and that will look like this for Kenmore. 213.564897 for example. and I will help you find the correct part number. Sea Breeze
Nov 24, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite trio 24.8 model #596.76603600
may be is the board or or refrigerator door is (ajar)
Mar 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water has stopped coming out of the filtered water dispenser
I just had this same problem and finally figured it out. The water in the line was frozen because my freezer was turned to 6 (note on inside of freezer says recommended temp is 4) so I turned the freezer to 4 and the refrigerator to 3. Next day the water was flowing.
Hope this fixes yours,
Sherry in Pittsburgh
Jan 10, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Replacing the Ice dispenser motor on Kenmore elite refrigerator?
There is a small door under neath ice maker shelf (literally) w/ 2 small screws that keep it in place,or a button that can release ice maker on the rt. side of machine. Good luck!!
Dec 30, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice and water dispenser lock light stays on and comes back on quickly after pushing and holding. No water or ice dispensed while light on. Kenmore Elite 23.1 ft side by side refrigerator
I resolved the problem on my Kenmore Elite model 106.55616400 by removing the drip tray, taking out two screws that hold the panel, and disconnecting and reconnecting the wires from the panel to the board. Unplugging the refrigerator did not work.
May 28, 2008 | Kenmore 25.1 Side-By-Side Refrigerator...
Refrigerators Logo
392 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
