Question about 791XV The 791XV is a 2-way Security and Remote Start system. Th
Got a new remote for my viper 791XZ and reprogrammed it .
I programmed my new remote for my alarm.after i programmed it there was a confirmation beep from the siren saying it was reprogrammed.when I press the unlock or lock button on the remote the remote beeps 3 times and while it 's beeping the antenna light on the remote flashes
  • Anonymous Mar 13, 2014
    I put in a new battery for my Viper 580 two way transmitter. Now every time I press any button the command works on my car, however, the transmitter then give 2 beeps, 3 times.. and the F button flashes
  • Anonymous Mar 24, 2014
    when opening the door with viper 2-way remote I get two beeps from f key. They repeat for times.
  • 905 Answers
This usually means that the remote did not recieve a signal back from the module or the module did not recieve the remote signal
have you tried repeatively to press the unlock button? does the remote starter work or aux( trunk ) ?
also when putting the battery in the remote , be easy because there is a connector plug soldered on the board real close to where the battery is , and if it is hit by the battery hard enough it will cause those solder connections to disconnect and you will get the beeps and or other malfunctions
Posted on Feb 03, 2009
I have a viper 5900 car alarm with the 7701 vpx remote and the lock and unlock are reversed. How do I fix this
according to Viper tech support (I emailed them your question):
Thank you for contacting Directed support!
You may need to reprogram the remote to your phone. Please use the following instructions to reprogram the remote:
To program the remote to your system please do the following:
1) open the driver door
2) turn the key to the "on" or "run" position
3) locate the valet switch (small black button under driver side of dash) and press once, release, then press again and hold
4) after the siren chirps one time press the lock button on the remote
5) the alarm will give you a unique confirmation tone
6) turn the key off (the same unique tone will be heard again)
Warm regards,
Nigel McGee I Customer Service Rep.
Viper Support
Apr 28, 2016 | Viper Vehicle Parts & Accessories
Viper 479V Viper Responder Remote how to program
open the door, turn the key on, press valet switch one time and press it again and hold it until alarm beeps if it dosent beep it means that alarm hasn't read the door open if it beeps press lock on the remote and it should beep again and its will be set. (if the alarm dosent beep you have to put the door trigger wire (green) to ground and repeat steps from beggining
Apr 02, 2014 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
HOW TO PROGRAM VIPER 479/V/P/X
Open the door, turn the key on, press valet switch one time and press it again and hold it until alarm beeps if it dosent beep it means that alarm hasn't read the door open if it beeps press lock on the remote and it should beep again and its will be set. (if the alarm dosent beep you have to put the door trigger wire (green) to ground and repeat steps from beggining
Apr 01, 2014 | Viper Vehicle Parts & Accessories
Need to fix problems with 5104 viper remote
It is possible that you need to reprogram the remote.
1st you need to enter the remote into programming... Hold the Function button until the remote gives a long beep and LED light comes on the remote a (it takes about 8 sec.) Then press and hold the remote start buttom until the remote beeps 3 times and LED lights up. Now your ready to program the remote
One of the door has to be open . Insert the key - turn the key to the On position then press the button on the antenna once and then press it again and hold it
You hear a chirp and then you press the lock button on the remote and then you hear a second chirp to receive confirmation and then release the button and the turn off the key .
Remote should be program
Jan 21, 2013 | Viper Televison & Video
How do program a replacment two way remote for
If you go to the website then to the support page under guides, you can find your models manual which give you installation and reprogramming instructions.
Oct 26, 2009 | Viper Vehicle Parts & Accessories
I lost my remote for my viper 350 hv,and when i used my key to open the door the alarm went off,and disconnect the viper box,and bought a new remote,and when im trying to program my new remote and plug my...
You have to turn your ignition on and press the valet button switch, to turn off the alarm. Then, you have to use that same valet button to learn the remote to your alarm, following the steps in the installation manual.
Sep 20, 2009 | Viper Security and Remote Start System...
Viper 5701 remote programming
1st you need to enter the remote into progamming Hold the Function button until the remote gives a long beep and LED light comes on the remote a (it takes about 8 sec.) Then press and hold the remote start buttom until the remote beeps 3 times and LED lights up. Now your ready to program the remote
You hear a chirp and then you press the lock button on the remote and then you hear a second chirp to recieve confirmation and then release the button and the turn off the key .
Jul 11, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
My viper alarm remote just beeps flashes TX and will not unlock doors or disarm my system. It has a new battery.
Try to reprogram this. If this routine does not work please let me know and we will try something else
May 06, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper 5701 remote
read the owners guide look at page 11 remote control programing you have to follow the instructions after your in the programing mode go to page 12 look at the unlock symbol and finish the programing
Dec 21, 2008 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
791XV The  791XV is a 2-way Security and Remote Start system. Th Logo
1,014 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
jason
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
