Question about RIM BlackBerry Curve 8310 Smartphone
My phone goes into a sleep mode if it sits for any length of time going into my voice mail if anyone tries to call me. What is this? Then while on the phone always during a conversation it cuts off and this hour glass starts spinning and it won't stop then when it does it says verifying security software. How do I fix these problems?
    Sniper:
  • 92 Answers
It sounds like it has a problem with the software. I would try to reload the software and see if it takes care of the problem. You will need the Blackberry Desktop Manager and the latest device software which you can download for free from Blackberry.com. The links below will take you to the downloads of ATT and T-Mobile
ATT
Tmobile
Posted on Jan 31, 2009
Why wont the voice notifications for incoming texts and calls work anymore
check with your cell service provider. If your voice mail has a password to access your messages, that same password has to be entered into your phone voice mail app so that the phone can have automatic access to the message alert system. You may have accidentally turned off the feature. Check your settings, especially if you phone has a sleep mode.
Feb 13, 2015 | Cell Phones
HOW DO I TURN OFF THE SLEEP MODE ON MY PRINTER BROTHER MFC 7420
Setting the Sleep Time reduces power consumption by turning off the fuser inside the MFC while it is idle. You can choose how long the MFC is idle (from 00 to 99 minutes) before it goes into sleep mode. The timer is automatically reset when the MFC receives a Fax or PC data or makes a copy. The factory setting is 05 minutes.
To turn Sleep Mode off press Menu/Set, 1, 6, 2. Then use the dial pad to enter the length of time the MFC is idle before it goes into sleep mode, in this case 00 so it wouldn't go to Sleep mode at all. Press Stop/Exit.
Feb 04, 2011 | Brother Office Equipment & Supplies
How to extend the rintone length on my binatone 2210 it is far too short. when it rings I can't get to in time it only rings about 3 times, and the person thinks i am not there.
When it stops ringing, the caller goes to your voice mail, right?
If so, then you need to contact your phone company and have them change your "Ring Cycle" -- that's the number of rings before the voice mail system picks up.
Some phone companies have a way for you to do this yourself from their website, other require that you call up the customer service line. Either way, the thing you want to adjust is your voice mail ring cycle.
Sep 27, 2010 | Lands Phones
Unable to leave voice mail, says good-bye
I don't think the voice mail is going bad.
On my 4424D+, I can turn off voice mail.
I use this feature when I'm gone for an extended period of time so I don't come back to 100 VMs.
Dial into your voice mail.
Choose the prompt for Call Answer Mode. (Option 8 on my phone.)
Then choose the prompt for Record Mode. (Option 1 for me.) This allows callers to record voice mails on your line.
Feb 17, 2010 | Avaya 4412D Corded Phone
How do you extend length of ring before it goes to voice mail.
try the following key sequence...
**61*xxxxxxxxxx*11*yy# <send>
xxxxxxxxxx = your voicemail number
yy = time in seconds before it diverts to voicemail (maximum 30 seconds)
Jan 04, 2010 | Samsung SGH-A877 Impression Cell Phone
Need more rings
You have to change the rings from the voice mail server. If you don't know your way around the server, its best to get a local NEC tech although it is fairly simple to navigate. Depends on your skill. Typical default password for the server is NEC
Oct 16, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Iphone does not ring on sleep mode
1. File manager in ipcsuite
/System/Library/SystemConfiguration/PowerManagement.bundle
2. Find the file:
com.apple.SystemPowerProfileDefaults.plist
Then rename it to:
com.apple.SystemPowerProfileDefaults.plist2
3. Reboot your phone
Apr 07, 2008 | Apple iPhone Smartphone
Inter-Tel Axxes phone outside calls don't go to voice mail
I had this same challenge with an InterTel 5000 system. Outside calls going right to the receptionist. My solution: You cannot fix this from a phone, you must open the DB Session Manager, move to Call Routing Tables (this is right above Voice Processor) and move all of your extensions above the "NO MATCH" and "EMPTY" lines on the bottom. Anything below those two lines will bypass the extension and go straight to the main attendant. At least in my configuration it does. See below...
bb752dc.jpg By just moving that last extension "5059" above the "NO MATCH" line, calls will now go to the extension from an outside caller. The trick is to hold your mouse on the pen icon and click several times to activate that line, then you can drag it to where you want. See below...
8e5e1dd.jpg Hope this helps someone?
vandata1
Sep 27, 2007 | Inter-Tel Axxess Corded Phone
Motorola c290 phone problems
First, try going to motorola.com and downloading their software upgrade. (this is free by the way). You'll just need to connect your phone to the computer with the proper data cable and run the software. This program will do the rest.
May 11, 2007 | Motorola Mobility RAZR V3
RIM BlackBerry Curve 8310 Smartphone Logo
60 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
