Question about Garden
Will not run.
The saw will only run if you put gas straight in to carb. I have cleaned carb but still the same problem.
  • Anonymous Feb 02, 2009
    Have changed out the carb.with a new one,saw will only run when gas is poured into caeb.
  • 10,865 Answers
Inside the gas tank of the saw you will find a little plastic tube attached to a little filter. Change that filter and you should be back in business.
Posted on Feb 07, 2009
Why won't the saw run other than when the choke is in the 1/2 position and dies whenever throttle is applied?
Your carb is starving gas from your saw. You will have to remove the carb. and take it apart, check the diaphragms for hardening or splitting, clean all passages and screen. There is a lot of small parts that have to be put back together correctly, also the diaphragms and their gaskets have to be installed right.
Feb 27, 2015 | Poulan Pro Pp5020av 20-inch 50cc 2 Stroke...
I have a p-3416 poulan saw it is getting spark but the saw still wont start
It's not getting gas. Possible wrong mix oil to gas, but not real likely. Possible sat over the last winter with gas in it and varnished. I'm guessing this is the one, more likely than not. take cover and filter off and clean and bag 'em. pour carb cleaner in the carb and soak overnight. Dump out (carb cleaner and old gas)into a sealable jar or can and fill with straight gas and soak an hour and dump into trash gas/carb cleaner. Use a bicycle pump to blow air into carb to dry it. At most use a computer air can. Then start with the right gas/oil mix, prime it, set the trigger and choke and drop start. (It helps to have the spark plug out during the soak. Then clean it and sandpaper the gap and the magneto area on the flywheel).
Jun 18, 2010 | Garden
Husqvarna 350- stopped while cutting
very straight forward to remove carb and take apart. replacing the fuel ines is a good idea. using compressed air is the best way to clean carby.
May 05, 2010 | Husqvarna 450 e-series 18" Chain Saw
Jonsered 2171 no gas going to carb. Put gas in carb run for few sec's. Blew out fuel filter seems to be fine. Not much use on saw.
the reason is you need to clean out the carb,if they dont get used much the oil/gas mixture turns to a varnish in the small carb ports and fuel can no longer get thru the carb
Mar 28, 2010 | Garden
NO GAS TO THE CARB HOMELITE 330 IF I PUT SOME GAS IN CARB IT RUNS FOR A FEW SEC.
Chain saws are known for plugged/pinched fuel lines
Drain the fuel tank
Remove the fuel line from the carb.
Blow air back in to the tank
Rinse out the tank
Repeat several times
Make sure your gas cap is clean and the vent in the cap is not plugged.
Make sure your air filter is clean
Refill with clean gas mix from a clean gas can
It should run for you
Let me know if this does not solve your troubles
Mar 15, 2010 | Welding Tools
Yard machine ym26ss straight shaft trimmer. New gas,
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 12, 2009 | Yard Machines Garden
Stihl 021 is hard to start, runs very briefly after ignition.
My guess is since you have ignition, it is a fuel issue: 1- the carb or the fuel lines or pump are plugges with dirt, 2- fuel pump is not working,3- carb needs cleaned 4- air filter is plugged which is very common also. When the saws sit for 6 months or so, the cylinder tends to get gummed up cause our gas is SO good & when this happens with one of my saws, I put spray lube in the spark plug hole & turn it over. When I am thinking, I store my saws with the gas tank down, so that gas isnt running into the carb/engine.
Apr 11, 2009 | Standard Oregon Chainsaw Chain For Stihl...
16" gas chain saw loses power and stalls
you will need to clean the carb and put new gaskets in it. Make sure it has clean thin oil. Dont over due it on the oil
Mar 31, 2009 | Garden
Poulan 18' model 2000 chain saw, quit running , will not start.
If you have a compression gauge, check the compression. Anything under 90psi is too low.
Check your flywheel key. If it is broken the flywheel will move and not fire at the correct time.
Note: if it does not sputter with carb cleaner then it's not your carb.
Next:
Remove your exhaust manifold. Look into the cylinder with a flash light. You are looking for scratches. Anything larger then a light fingernail is definite proof you need a new cylinder/piston assy.
If it passes that test do the following:
Pour mixed fuel straight into your cylinder until 1/4 full. Slowly pull your saw over while looking into the cylinder. If you see bubbles after the ring/rings go by then you need a new cylinder/piston assy. On rare occasions if no scratches are present on the cylinder wall or piston, you may be able to change just the rings.
Mar 31, 2009 | Poulan Pro Chain Saw 46cc 20"
Stihl MS 260 Pro wont run wide open or idle.
Hi brandon First change the sparkplug with the same heat range,Check and clean the gas filter with compressed air.Remove the carb and very carefully disassembly entirely.Check the gaskets and the diafragms.At the fuel pump side there is a fine screen(clean it).Check the needle,the spring and lever.Unlock the screws L and H(note how many turns are they).Put the corp of the carb in a special clean solution for 12 hours and then clean it with compressed air(something is clogged there).Put all back together and try to start the engine. regards savumihai71
Feb 12, 2009 | Makita DCS6401 20 20",64cc Chainsaw 2...
Garden Logo
66 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
