Question about Kenmore Oasis HE 27082 Top Load Washer
Kenmore oasis. When washer is filling with water, I can see a sock floating between tubs. How can I get it out?
  • 15,935 Answers
I would suggest a long flexible brush - like a pipe cleaner... or chopstix.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 13, 2010
Kenmore washer top load model 110.24952300 Type 111 Fills but wont start. Motor buzz. Replaced old motor which was locked up. New motor installed, still wont start agitation. Still buzzing.
You have what they call a direct drive washer. If you look at it from underneath you will see the motor then the transmission and then the water pump. I have seen socks get sucked into those pumps and lock everything up. Two clips hold the water pump onto the transmission. Pop the two clips off and slide the pump off of the transmission and tuck it out of the way somewhere. DO NOT DISCONNECT THE HOSES! If you do and the tub is full of water then you will soak yourself and the floor in water. Now with the pump tied out of the way plug in the washer and turn it on, let it fill up if it is empty. If the washer tub starts agitating after it is filled then it means that there is something in the pump. When I have those pumps fail they still work but just leak, they never locked up on me unless it was a sock or something. Drain the water if you determine it is the pump, remove the pump and see if there is a sock in it and if you can fish it out. If not buy a new pump. They are $30-40. They usually clog from overfilling the washer and the clothing slips between the inner and outer tub.
If removing the pump doesn't allow the washer to work then the transmission is suspect or the tub itself.
Feb 12, 2018 | Kenmore Washing Machines
What does the FE code mean on my washer?
You may have a bad water valve,could be over filling. But. Still could be a drain pump. Does the tub ever fill with water when you are not using? Also too much soap and not using HE. Soap. Can cause this
May 05, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis washer does not lock
First, OL/UL stands for "Overload", so in other words, the washer things the tub is too hard to move because it's overloaded and the motor is struggling or the unit is way out of balance causing the washer to struggle. The most common problem is a nut below the inner tub that needs to "float". Floating is when the tub fills up with water to a certain level the inner basket will rise about 1 inch from the center agitator. What this does is disengage the basket from the motor so that the agitator can rotate independently from the basket. If the basket does not float then when it tries to agitate the whole basket will turn back and forth at the same speed as the agitator and this will cause the OL/UL error code.
Nov 22, 2012 | Kenmore Oasis 4.6 cu. ft. Canyon Capacity...
Kenmore oasis he washer 110.27062602,sd codes,and stripped put hub gears
Check the basket the very bottom ring is the float and some how leak and do not float well enough to disengage the basket when agitating and strips the hub.
Jan 12, 2012 | Kenmore Oasis HE 27062 Top Load Washer
When we turn our washer elite on it gives us a error of sud?
susds error is a an fault error ....the machine has detected excessive tub pressure could be from not using "HE Soap ....if your are good but you might be using to much.... whens the last clean cycle you have ran to clean excess inner tub buildup on your washer .....
1 #drain all water out of filter sump behind lower front axcess panel make sure washer is unpluged
2# reinsert filter sump and and leave axcess panel off u make have to do this several times...
3# now check black rubber hose that goes from pump to bottom of tub remove clamp check for any obstructions in bottom of tub clean float ball of debris and reinstall and reconnect clamp to buttom of tub..
4# now pour 1 cup of vinegar directly in the tub where your clothes go and shut door( dosent mater what kind of vinegar or an affresh tablet
5# plug washer back in now lets run a clean cycle or any cycle that usues hot water ....
6# if unit suds code again this could happen a few times we need to flush out the buildup you may have to repeat steps 1-6 a couple of times....
Jan 26, 2011 | Kenmore Elite HE5t Washer
Kenmore elite top load washer will not drain and buzzes until unplugged
Hello there:
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
Nov 18, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I hear gravel noise when the machine changes cylces
The machine does a quick test to determine if the spline is engaged before spin commences. The way it works is the tub fills with water and floats for wash. When the pump removes the water for spin the spline don't always line up. So artificial intel will give it a slight test to see if the basket is locked. I have a bravos manual that shows how it works I know yours is an Oasis but I believe these are all basically the same. See page 23
Apr 10, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
Sal De
fordexpert
Whirlpool
Whirlpool
