Question about Archos 604 WiFi Digital Media Player
Archos 604wifi How can I. or can I, transfer files on a jump drive to my Archos ? When I connect a jump drive through a lead to the archos it does not seem to detect it?
Use Windows media center as a go between if you have the capability. I would not expect that much functionality from the Archos. The extra step will save time in the long run. There is a usb port on the DVR station. Haven't really tried to utilize it, yet. It does recognize a thumb drive when plugged in. I just wouldn't expect you will get the same ease of operation as using media ctr.
Posted on Feb 02, 2009
How do i update my Archos 504?
How to install firmware ..?(update)
Step 1. Download the firmware to your computer-->click HERE to download the update file When you download the update file, your browser may warn you that the file 'could be harmful'. This is normal because browsers are not familiar with files that have a .AOS extension and suspect that they could be malicious. These files are not harmful to your computer.
Step 2. Turn on your ARCHOS device and connect it to your computer with the USB cable
Step 3. On the ARCHOS, choose to connect and wait a few seconds for your device to be detected by the computer
Step 4. Copy and paste the downloaded firmware (.AOS file) to the ARCHOS device.
  • Case 1: logo_firm_hdd.jpg Your ARCHOS is detected by your computer as a Hard Drive (E: for example) in Windows® Explorer. Paste the update file directly onto the ARCHOS hard drive icon.
  • Case 2: logo_firm_g4.jpg Your ARCHOS device is detected as a 'Mobile Device' in Windows® Explorer (not as a hard drive) and you see just two folders Data and Media when you open it. Paste the update file into the folder called Data.
  • Case 3: logo_firm_g4.jpg Your ARCHOS device is detected as a 'Mobile Device' in Windows® Explorer (not as a hard drive) and you see Internal Hard Drive when you open it. Open this Internal Hard Drive icon and you will see the various ARCHOS folders inside (Video, Music, etc.). Paste the update file into this area but be careful not to paste it into any of the folders there.
Step 5. Disconnect the Device
Unplug the USB cable (for 'Mobile Device' connections) or use the "safe disconnect" green arrow icon (for Hard drive connection) in the system tray before unplugging the USB cable.
Step 6. On your ARCHOS device, click on "Update Firmware"
Click on the "tab" button to show the settings screen. Select the "System" icon and then click on the "Update Firmware" button. For the ARCHOS 104, 202, & 204, go to the settings and open the icon "System" where you can find the Update Firmware button.
Dec 31, 2010 | Archos 504 500870 Digital Media Player
How do I transfer my sermons from my laptop to my Archos 101?
2 ways:
1. Copy sermon files from laptop to USB drive, then mount USB drive to Archos, go to files, external drive, copy files to ARCHOS from USB drive.
2. Connect laptop to Archos with USB cable & copy or drag files from laptop to Archos
Note: You will then need a reader / Office Suite/ or other app to view the sermon files. I assume the files are .doc files. Excellent app for this is Docs to Go.
Dec 26, 2010 | Archos 101 Internet Tablet 16GB 10.1"...
My archos is showing recovery code 101
It is indicating that there is a hard drive fault. Here is another users suggested method to clear the fault.
Following some extensive use I switched it on one day to find that it hung on the Archos home screen and kept going in a loop. Luckily I could see the red HDD light flickering so knew that the Archos was trying to do something and that the HDD was recoverable. When I entered into the recovery mode I found that I had an recovery code (101) which indicates a HDD fault.
I used the following steps to recover the HDD:-
1. Connect the archos to the PC using the USB cable (the unit will start but will need to be shut down again by pressing the power button)
2. Press the power button and the 'lock' button together for a few seconds and you should get a basic recovery screen
3. Scroll down to repair disk and select
4. Click on done and wait for a few seconds and you will see the archos as a drive in 'My Computer' (Note that this does take a few minutes)
5. You now need to back up your data, movies, music, widgets etc as the next step is to format the Archos HDD which will wipe it all.
6. Disconnect the Archos, turn it off and then turn it back on again by pressing the power and 'lock' buttons together.
7. Scroll down to format disk and select. The Archos will now delete all files on the HDD and you will get a message asking to connect to a PC and install the update file. This is the firmware file that can be obtained from the Archos website. You'll also notice that the recovery code has changed from 101 to 108
8. Connect the Archos to the PC, wait for a few seconds and you will see the archos as a drive in 'My Computer' again.
9. Drag the firmware update file from your PC where you've downloaded it to directly on to the root drive
10. Click 'done' on the Archos and it will begin to update the operating system.
11. Once this is complete then there should be an update successful message, select done and the archos should restart giving you the nice bubble screen and asking if you want to enable USB.
12. Note that the Archos is now in a 'factory built' condition so you'll need to adjust settings etc according to your preferences.
13. You can now start the long process of transferring your files back to the Archos.
Jan 12, 2010 | Archos Internet Media Tablet MP3 Player
How do I download pictures to my Archos 604 wifi
Hello.
Welcome to Fixya's Community.
When you are connected to a Windows® network, you can browse the shared folders of other computers in the network, using the Archos File Browser. From the Home Screen, select the Browser icon. Once in the browser, select ‘Network’. Your device will search for other computers in the Windows® network and you can start browsing their shared contents.
  • Using the Archos double browser, you will be able to transfer files from a computer onto your device, or transfer files from your device onto a computer’s write-enabled shared folder.
Additional Help:
Archos 604 Manual Guide.
Archos 604 WiFi Manual Guide.
Thank You For Using Fixya.
Please let me know If you need any Further Help.
Good Luck.
Nov 09, 2009 | Archos 604 WiFi Digital Media Player
Can you connect an archos 605 to a bell 9142 pvr
Archos Dish Network Plug-In says:
  •  Quickly transfer hours of your favorite TV programming from select DISH Network DVR receivers and enjoy the shows you watch every day- on the go.
  •  DISH Network customers with ViP622TM and ViP722 TM DVR receivers can enjoy this next generation of PocketDISH service with Archos 605 WiFi and Archos 705 WiFi models
  •  This plug-in is free for DISH Network Customers.
  •  Not a DISH Network customer? Find out more at www.dishnetwork.com and get the most out of your Archos player today
  • Jan 24, 2009 | Archos 605 WiFi Digital Media Player
    Archos 605 copying films from DVD to the player
    If change the setting of the 605 to "hard disk" then a PC sees the 605 as a hard disc when connected using the usb lead. You can then copy and paste files directly to the 605..
    Feb 19, 2008 | Archos 605 WiFi Digital Media Player
    Archos 605 Recovery code 108
    1. Download the latest firmware from Archos
    2. Format the drive on your player
    3. Connect the A605 to your computer using the USB lead
    4. Copy the new firmware the A605's root folder (Drive X: on your PC or whatever letter was assigned to your Archos
    5. Click ok and you are finished
    Feb 18, 2008 | Archos 605 WiFi Digital Media Player
    ARCHOS KEYPAD
    The 604 WIFI keypad starts off in small letters but by taping the key above the alt key it changes to captials but you have to tap it for each captial letter you want as it reverts to small letters once you tap a letter.
    Dec 17, 2007 | Archos 604 WiFi Digital Media Player
    Archos 700
    1. Connect the archos to the TV ( using the 3 leads red/yellow/white into the TV or DVD player) and the other end of the lad, a single jack into the back of the archos mini set-top box. Plug the single jack into the "RV Output". 2. Then start playing a movie on the archos. 3. Then press down on the flat silver button on the top of the archos device. Your screen should turn black/blank. This means your sending your movie to your TV. 4. Tune your TV to find the Archos movie in the same way you would tune your TV to find another pay TV set-top box ( like cable TV or Satelite). Problem solved.
    You can use the same steps to send archos music to your steroe. Just plug the audio leads (white & red) into your stereo instead of your TV.
    Oct 09, 2007 | Archos AV700 Digital Media Player
    Archos 604 WiFi Digital Media Player Logo
    101 people viewed this question
    Top Archos Audio Players & Recorders Experts
    kaiserh1
     Grubhead
    Grubhead
    Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
