Question about GE WVSR1060A Top Load Washer
GE top loader washer model S2100G3WN will not spin
Everything else works properly. It agitates fine, the water drains out, I can move the pulley and belt but I cannot move the drum. I can hear it trying to spin but it doesnt.
  • 11,896 Answers
Drum bearings or motor needs to be replaced
Posted on Jan 31, 2009
Model WJSE4150B2WW ser# AF171808G GE washer agitates but won't spin with front cover off motor turns belt in the right direction for just an instant and then stops interior basket can be turned...
When spinning the motor freezes up and will not spin. I released the motor and took off the belt off and the motor ran fine. However the pulley that the belt is also on will not spin the proper direction, only backwards.
Mar 03, 2011 | GE WJSE4150B Top Load Washer
Does not agitate or spin
Let me make sure I hear your symtoms right..
The washer fills...sound like the motor is running but it doesn't agitate or spin.. then when it tries to drain it bascially gravity feeds out until there is no longer enough water to force it out?
Sounds like the belt is off, or broken.. I am not all that familiar with your model, but I think most GE's are belt drive.
If it were the agitator coupler, the washer would probably still drain..
Pull the front cover off of the washer, you will see the belt and pulleys, make sure it is A: still on the pulleys, and B: tight.
If not, loosen the four bolts on the moter, put the belt on and then slide the motor towards the rear to tighten it.. then tighten the four bolts. They may simply have not tightened the bolts on the motor from factory and the motor slid back loosening the drive belt.
GOOD LUCK!!!
Jun 20, 2009 | GE Washing Machines
GE top loader not agitating
Your agitator splines are probably stripped out.
Remove the agitator and check the spline grooves.And the agitator coupling on the shaft.
Mar 04, 2009 | GE WBSR3140DW Top Load Washer
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Nov 27, 2008 | Kenmore 22422 Top Load Washer
Model #:WBSR3140DWW
My GE washer will not agitate or spin. Will fill up with water but wont spin. Looked at motor and it has a green light that flashes about every second constantly. I can turn the pulley both ways. Does anyone have any suggestions
Oct 18, 2008 | GE WBSR3140D Top Load Washer
Washing machine noise
check the dogs in the agitater
Mar 25, 2008 | Whirlpool GSC9455 Top Load Washer
Maytag washer will not spin
If your washer does everything but does not spin, it is your outlet filter which is blocked. Locate this and clean out, it has to work fine. Refer user's manual.
Jun 02, 2007 | Maytag Atlantis MAV6451 Top Load Washer
GE WVSR1060A Top Load Washer Logo
197 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
