Question about Samsung HLN617W 61" Rear Projection HDTV
Samsung hln617wx/xxa: color starts to blink or flicker after about ten minutes
My tv started acting up today. It started to flicker, kinda like there was a loose connection or something. I unplugged the tv, but after about 15-20 minutes, it started to flicker again. I put a fan right near the rear exhuast, but it still goes T.U. No lights on the front, temp and lamp are fine consistently. Appreciate any help, late. P
I have same problem. I saw on msg board that I should replace the color wheel. I can't believe how poor these tv's are. Samsung should replace or credit all of us for the pieces of expensive poo.
Posted on Sep 05, 2007
8/25/07 Coincidentally, I have just run into the same problem. I spoke with Technical Service at Samsung yesterday and after 15 minutes on the phone they couldn't tell me what was causing it. I then did numerous web searches and came across a sight where technical experts discuss problems. Turns out it may be a problem with the Digital board, the A/V Board or the DMD board. Cost for repair (depending on which board it is) will run $400 - $1,000 or more. Repair man is coming out Monday to diagnose the set.
Posted on Aug 25, 2007
SOURCE:
We have a Samsung 61 inch DLP tv. That started buzzing a few weeks ago when it was turned on. At first it only lasted a few seconds. Kinda sounds like a bad barring, Then this last week it began to last...
Highly likely that the sound was coming from the bearing in the color wheel assembly. When the bearing fails, the color wheel cannot spin at the correct speed, and because the speed is measured by the control board, the TV will shut down.
If you can handle a screwdriver - entire color wheel assembly can be replaced for about $100 and 30 minutes of your time.
Oct 08, 2013 | Samsung HL-R6167W TV
Wd65738 flickering
I had a TV do that about a year ago, the repair man said it was the color wheel inside the tv. I changed the bulb to see if he was BS'ng me and eventually got the manufacturer to send a color wheel and I change it myself, was very easy...TV works fine ever since. Hope this helps
Jul 10, 2012 | Mitsubishi WD-65738 DLP TV
Hi I have a Samsung HLN467W, a 46" DLP TV. And after 50-60 minutes, it starts to flicker white, like lightning flashes. But the whole screen is not blank white, it's more like the images are...
It seems color wheel problem in your tv that gets problem after some time and you hear high pitch noise along with picture flicker.
Color wheel need to be replaced to solve this issue. Required color wheel is available with PartStore.com (click to view image of part and price info) and it is job of qualified tv repairman because light engine will take apart for that.
Hope these info will help you.
Thanks.
Mar 15, 2011 | Samsung HLN467W 46" Rear Projection HDTV
Samsung HLP5085W DLP - lamp replaced about 7 months ago. I powered up TV and got strange colors with flickering picture. Turned unit off and triangle symbol appears with lamp showing - needs replacement....
Strange colors and flickering picture symptom shows problem with color wheel and/or dmd board.
Lamp is only light source in dlp tv and it has nothing with colors or picture flicker.
TV goes to protection mode because of some internal problem as mentioned above.
If you wish to repair tv by yourself then you should have service manual copy in hand and that can be downloaded from HERE for small fee.
Thanks.
Jul 04, 2010 | Samsung HLP5085W 50" Rear Projection...
Ok i have a 47in samsung hd tv today it started acting funny the picture and colors arent right like there a blue red and green colors its like the main picture is being copied 3x times once by each color...
this issue is caused by a failure in the convergence ic's and possibly a bad resistor and fuse in the circuit if you need instrution on how to change I may be able to help though it is kinda tech heavy
Jan 25, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung DLP HL-R5067 blinking lights
when is the wheel is broken doo you cleaned the glass around because if it not rotate tv not turning on it is a one of the posibilitis
Mar 02, 2017 | Samsung Televison & Video
Samsung HLM507 FLICKERING PROBLEM
how extended is that warranty, and what does it cover? Sounds to me like a classic video controller board about to fail.
Mar 24, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung HLN617W 61" Rear Projection HDTV Logo
373 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
