Both Radios are on channel 5. but one of the radios wont transmit to the other.
SOURCE: motorola spirit mu21cv
Sounds like you do not have your radios programmed to match one another. The MU21CV is a user programmable model. You might call your local Motorola dealer or one of the companies online to have someone walk you through programming the radio(s). With this model it can appear the radio is not powering up, when it simply is not programmed correctly.
SOURCE: Lost manual - can only get one T3 radio to transmit
http://www.motorola.com/mdirect/manuals/fv200_userguide.pdf
Check your Interference Eliminator Code.
SOURCE: can transmit to other frs radios but cannot
Check the "code" (interference eliminator code) on the FR60 and set it to off or zero. It appears from your description the Cobras do not have "code" turned on. Refer to your user guide to find the instructions for turning off the code. (As of this date we have not found an FR60 manual posted online.)
Best regards.
Testimonial: "I set interferance code to zero and it works Thank you Ken"
SOURCE: Motorla Xtn446 - Kenwood Protalk Dosent Transmit
One or both of your radios have PL ( aka private line, tone code, interference eliminators) activated. Here is a link to a link which contains the XTN446 manual(s). Click on the "support" tab to see the list: http://www.motorola.com/Business/XU-EN/Business+Product+and+Services/Unlicensed+Two+Way+Business+Radios/XTR446_XU-EN
First I would try setting the radio's CODE to off (usually zero) and see if that solves the problem. Otherwise, you'll either need to experiment, or find a user guide for the Kenwood. (You could try posting in the Kenwood forum.)
Best regards.
SOURCE: We just purchased the Motorola
Reset to Factory Defaults (Pg. 34) Reset to Factory Defaults will set back all radio features to the original factory default settings. To do so, press PTT, SB2 and SB1 simultaneously while turning ON the radio until
you hear a high tone chirp.
Here is a link to the user guide: http://www.twowayradiosfor.com/pdf/RDX-Non-Display-manual.pdf
Programming instructions begin on page 36.
Best regards.
