Question about Euro-Pro 7500XH Mechanical Sewing Machine
How do I oil my machine
I don't know how to oil my machine. I don't see any holes at the top to drop the oil in. I have lost the manual, and the company has no support offered on this model. Any help will be greatly appreciated.
    President:
  • 1,114 Answers
You can download the manual from the website below: http://www.euro-pro.com/europro/manuals/7500XH.pdf They also have a FAQ: http://www.euro-pro.com/europro/faqdetail.aspx?modelno=7500XH Lubricating:
Posted on Jul 31, 2007
Where do I put the oil on my Necchi Model # U229014?
On the top of machine and top of bed are tiny holes for oil. Use a teflon or sewing machine oil. Tiny drop will do. Some machines need no oil at all.
Oct 20, 2017 | Necchi Sewing Machines
Need to know where to oil parts in my oldie but goodie Kenmore! Do not have manual. Where can I download a free manual for this model?
If it's an oldie (mechanical), then you can probably remove the top, slowly hand-rotate the handwheel and apply a couple drops of fresh, good quality sewing machine oil every place that metal rubs on metal. Do Not oil plastic, cams, or belts! You may see oil ports (little holes located near joints) where you can apply oil.
Then access the bottom part of the machine and do the same there. Be sure to oil the feed dog mechanism. Apply a drop of oil to the outside of the shuttle.
Move the dials and levers and oil those mechanisms too.
Be sure to run some scrap fabric through the machine in case there is excess oil.
If things are a little sluggish, direct heated air from a handheld hair dryer into the internal mechanics (top & bottom).
Cleaning and oiling your machine frequently will keep it (and you) happy and healthy!
Apr 07, 2016 | Sewing Machines
Which holes are the oil holes?
Sandy, Re POST , make, model #, and complete question so we can answer your question effectively.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 10, 2016 | Sewing Machines
How do I oil it?
There should be at least 2 and maybe 3 holes on top of the machine, the size of ballpoint pen tip. That is where you oil your sewing machine. Two drops into each hole should be sufficient..
Oct 27, 2015 | Sewing Machines
Looking to tune up brother CP 6500. Squeaking And skipping occasional stitches. What grease to use and where to apply grease?
No grease please, only quality sewing machine oil. Some machines marked the oil positions with red. Small holes. Else take the top and left side covers of and use just a drop of oil where moving parts are joint. Here too you should find small holes that need a drop now and then.
Jan 11, 2014 | Brother CP6500 Sewing Machine
Is it true that the 14U85 needs 20-30 drops of oil in the top of the Ultralock? I acquired the serger and original manual, and the other holes only require 2-3 drops of oil. Any suggestions before I f
If you are getting that from from the manual... then yes. Sergers are a different critter and need to be well lubed.
for giggles I found this video. It might interest you to know that this "ultra lock" looks a lot like my Juki MO-104 from the same era.
http://www.youtube.com/watch?v=e5tcs29ZbrE
Feb 25, 2013 | Sewing Machines
How do I oil my Janome 664d overlocker
Does your overlocker have a threading diagram on the inside of the front cover? Often this will also show a couple of red dots where you need to oil.
Obviously always best to consult the manual if you have it; I haven't been able to find an image of the threading or oiling diagram for your machine.
If it doesnt have this diagram and you don't have a manual then I would hazard a guess and say that you need to oil the loopers where they move through another metal part. So open up the front and have a look at the lower looper mechanisim, manually turn the flywheel to move the looper and you should be able to see what I mean. The lower looper will move back and forwards through a metal socket piece and the looper bar may look lubricated on each side. So give the metal holding bit a drop and the oil should work into it. There may be a similar looking bit for the top looper, have a look and give it a drop of oil.
Some overlockers will have an oiling point at the back of the sewing table, it may be a little hole marked with red paint.
Sep 06, 2011 | Janome MyLock 644D
Where do I oil my serger, the motor has a bit of a squeak
Lightly oil all moving parts but do not oil the motor anywhere under any circumstances, if the motor is squeaking it may be worn motor brushes
Oct 27, 2009 | Juki MO-644D Mechanical Sewing Machine
My old Kenmore sewing machine makes a loud squealing noise.
It sounds as if your machine needs a little oiling. If you have a clear machine oil (not 3 in 1). place a drop in the bobbin case area and if you will notice, you will see small holes on the bed and on the top of the machine. place a drop of oil into each of these holes. If you can take the top and bottom covers off, you can put a drop of oil every where you see a hole..some of the machines actually have the oil holes painted a red color. Also place a drop at the handwheel as well. Just remember when oiling, less is better. After oiling, run for a few minutes, if you feel it still needs a litte more, do the same, one drop at a time. After this, if you machine sets for a while, oil just before starting to sew, that way when you put the machine away the oil has been worked through and it should help prevent the squeaking when starting up again.
Mar 01, 2009 | Kenmore 15208 Mechanical Sewing Machine
Oiling Bernina Deco 330
Use only good quality clear sewing machine oil from your Bernina dealer--ask them which is the correct oil for your machine. The likely place to oil is in the hook area (see page 44 of the manual). Be sure to apply a drop or two every 8 hours of sewing time. If you know your machine, you may notice a change in sound when it needs lube. Oiling anywhere else could damage your machine.
Do NOT place lube in any holes (as previously suggested) in the bed or top of the machine. These are not oil ports. They are holes for fastening accessories to your machine, ie circular embroidery unit, binding units, seam guides, etc.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwi8ubHe6o7XAhXpi1QKHb3zAngQFggxMAA&url=https%3A%2F%2Fwww.bernina.com%2Fen-US%2FSupportData%2FBERNINA-Nah-und-Stickmaschinen%2FBERNINA-3er-Serie%2FManuals%2F0333017104_2014-02_Manual_B330_B350_B380_EN-us&usg=AOvVaw0F7ScSQEEitpxEnDD0v8Y1
Oct 26, 2017 | Sewing Machines
Euro-Pro 7500XH Mechanical Sewing Machine Logo
395 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
