Question about Dell Latitude D600 Notebook
How do I connect my laptop to my tv
Dell Latitude D600 and older model Toshiba tv with no s-video outlet...just normal video input. I have an s-video connector that allows me to plug a video cable in, but I can't see anything on my tv
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    Have you changed your Video Source for your TV?
  • 31 Answers
Right click on desktop. Select display properties tab, select the Extend windows desktop checkbox then click apply.
Posted on Jan 31, 2009
Can I connect my dell latitude d600 laptop to my tv?
The Dell Latitude D600 has a VGA out. If your TV has a VGA connector then you should be able to connect it to it. All you have to do is connect the cable, and press the hot key to enable VGA output. Usually its Fn+F5 or Fn+F7 for Dell laptops.
Jul 06, 2011 | Dell Latitude D600 Notebook
Why does the s video output on my dell latitude d600 not work?
You must have the correct drivers installed, and you must enable the output as a second monitor but to do that you must connect to the TV IN first. Right, well, IF your TV has a DB15 Female Plug on it then you CAN, connect it up and it will work, as a second "Monitor". OR If the laptop, has a "Composite Video" a Yellow RCA socket, then you can, connect to the TV's Composite IN. & it will be a second monitor. Otherwise you cannot, the VGA signal is NOT compatible with a TV's input. SOME cards have a connector that plugs into the DB15 and to the TV, but they are "Special". In saying that though you can "Micky Mouse" things together and get an output, but it real poor quality, and disappointing results, there are various posts on the net about doing this if you wish.
Remember DRIVERS, you also need the drivers installed & setup correctly in order for the hardware to work. As a tip, When connecting to a TV, always connect like this......First, plug all cables into TV's correct Video input(s). Connect up the Sound, plug all cables into laptop, turn TV ON. NOW, start the laptop, you should now soon see the an image.
NOTE: Some laptops & other devices, have HDMI out, sometimes, the AUDIO is not passed through, the HDMI cable, & the Audio must be run from Audio/Line OUT on laptop to AV IN on TV.Also some laptops have a socket that a multi-way 4/5/6/7 pins. A connector plugs into this, you then can connect to these connections, as you would normally.
Feb 17, 2010 | Dell Latitude D600 Notebook
HOW I CONNECT MY LAPTOP WITH TV LAPTOP MODEL IS DEL LATITUDE D600
all you need is a connecting cable depending on your laptop's tv out port. The following website displays several connecting cables. http://www.cableuniverse.co.uk/catalog/cable/pc-to-tv-cables/ Also, update your bios and graphic drivers
Nov 07, 2009 | Dell Latitude D600 Notebook
Connect Dell Latitude D600 to TV
try holding down the fn button and pressing at the same time the button with a small screen on it will do monitor switching
Aug 06, 2009 | Dell Latitude D600 Notebook
I have a Dell latitude D600 laptop
The D600 has no TV out option, the only Output for visual display is the monitor VGA port.
You would need a converter for the normal VGA to DVI Cable.
Mar 22, 2009 | Dell Latitude D600 Notebook
Can I connect my dell latitude d360 laptop to my tv?
you need to have the same connections on both my laptop has svideo or vga connector, some have Hdmi which is the newest, but the tv and laptop have to bot have the same connectors, it may be a dvi, or any that I mentioned, then you need a cable for your video, and another for your audio, both the audio and video cables are run to the tv, the only one that has both audio and video is the HDMI which tv's from the last hear or 2 usually do have. Then depending which input the laptop is using which it will tell you where the connection for the tv is, you set it to that input and that turns your tv into a giant monitor
Dec 22, 2008 | Dell Latitude D600 Notebook
How do I Connect Dell: D600 to a TV using S-video port
You have to press the Blue (Fn ) button on the bottom row of keys at the same time as (F8) function key at the top on Dell Latitdue laptops. You can toggle back & forth between laptop monitor only, TV monitor only or both monitors on at the same time. No need to install extra drivers unless something is broken.
Dec 10, 2008 | Dell Latitude D600 Notebook
Problem connecting my dell latitude laptop to my tv
Check the monitor settings under "Display Properties/Settins/Advenced/Monitor" (right click on desktop).
Dec 02, 2008 | Dell Latitude D600 Notebook
Connecting my laptop to my Samsung DNie 29' Tv
Are you connecting the S-Video directly into the video output port of your laptop? S-Video 7pin? Video output port 7 pin too?
Is there an adapter for the video output port, for your laptop?
Aug 14, 2008 | Dell Latitude D600 Notebook
How to connect my dell D600 to TV
Not all TV's are designed to connect to a computer, and some don't have the resolution quality expected if they do. Research the make and model of the TV to see if it's compatible.
Jul 06, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
129 people viewed this question
Alun Cox
