Question about American Standard Kitchen Faucet 6310 020 White Easy Touch Pull-Out Kitchen...
I am trying to replace the o'ring on my Kohler kitchen faucet 10416. The instructions ask me to pull out the spout to remove it from the body. However, regardless of how hard I pull, it refuses to come out. Should I be doing something different? Thanks.
  • Rakesh Jha Jan 31, 2009
    Thanks. I will try that. Stupid question - where do I spray the lub so that it gets to the rings?
  • Rakesh Jha Feb 01, 2009
    Thanks. It worked!
    President:
  • 2,692 Answers
The o-ring(s) is expanded or stuck. Try spraying silicone lub (found it at most discount ro hardware stores)  Keep twisting it back and forth as you raise it up . Yes. You may have to force it up which will tear the old o-rings that you are going to replace anyway.
Posted on Jan 31, 2009
  • Thomas F. Schneider Jan 31, 2009
    Down around the spout is the only place you can spray it and try to get it down in there.
  • Thomas F. Schneider Feb 01, 2009
    Thank you for the excellent rating. I am glad that I was able to help.
Can't remove the spout of a Kohler K-15176 faucet to get to the O-rings to replace them. The spout seems to be frozen and can't twist or lift it off.
The "o" rings are swelled up and causing it to be frozen. After you remove faucet handle and Collar that holds main body on, you may put some penetrating oil like 3 in 1 oil around sides and wait 5 minutes, next it takes all elbow grease to try and twist and turn to break the "o" rings and free it up to remove. It has to be forced and may take some strength, but it will come up.
Aug 28, 2011 | Kohler K-15176-PT-7 Coralais...
How do I remove the faucet to replace the "O"
Go here first http://www.kohlerserviceparts.kohler.com/ServicePartsPage.aspx?DocumentID=b88270fcf7464e44a3228751fb5f371c&ModelID=556ebdc2936d4f5d8d2dda4f02300621
You need a pair of chanel lock priers and a set of Allen wrenches some snap ring pliers some sort of small tool to get the o-rings off (a dental tool works good for this) and then just some general tools and some plumbers lube for the reassembly.
Mar 13, 2011 | Kohler K-10416-BN Fort½ Single Control...
I purchased the Danco 80701 "Repair Kit for Delta, Aquasource, and Glacier Bay Faucets with #70 Ball" so that I can repair a leak in my Delta kitchen faucet. The instructions on the package are...
Sounds like the old style center-control delta type faucet, rubber washers describe older type but still good. The rubber seats have holes in middle, supply water to the cylinder which diverts water to the spout, and has a seal over top of ball allowing stem for handle.
Think they are talking about flex-hose type faucet accessory getting clogged, Maybe: lift the flex-hose faucet housing off the center-control faucet body? Water to it runs directly from center-control faucet and if broken seat gets in narrow line could inhibit spray.
Kitchen faucet spout too has an O-ring under where it connects to the faucet body. Unscrew large nut where meets the faucet body unit (slip-joint pliers), once free of threads, spout should pull straight up, easy or slight tug. I use bent paper clip to remove old one trying to save it in one piece so as to get exact size (that's important) to replace, push on one side then other.
Jan 13, 2011 | Microwave Ovens
Side sprayer won't spray
THe diverter inside of the faucet is malfuncting. Remove and replace the diverter valve. It is located right under the spout assemble.
Mar 25, 2009 | Kohler K-10416-BN Fort½ Single Control...
Unable to pull spout to replace O'Ring in Kohler Faucet F10416
They just pull out, sometimes things get stuck and I cant get them lose as a plumber and you just have to buy a new one...dont feel bad
Jan 31, 2009 | Kohler K-10416-BN Fort½ Single Control...
Cannot pull out spout to replace o'ring of Kohler Faucet 10416
the pic u have up doesnt show it being a pull out u trying to fix airater?
American Standard Kitchen Faucet 6310 020 White Easy Touch Pull-Out Kitchen... Logo
386 people viewed this question
Top American Standard Plumbing Experts
Donni Steen
john h
TED
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
