Question about Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub Washer
Turns on but will not stay on
Amana stailess steel designer dryer will turn on and heats well but will not remain on for more than a minute. After which, it will not turn on again for a period of time. What could be causing this?
  • 943 Answers
The problem is with the motor over heating It should be taken apart & cleaned, the motor is over heating,If ater you clean out the lint It still does the same thing Its the motor
Posted on Jan 31, 2009
Amana furnace has turns on for a minute then off, it may stay on for a few minutes or seconds and repeats...we have heat, but blower is intermitten...what do i do???
You will need to verify that you have constant high and low voltage AT THE MOTOR. If the voltage remains constant and the motor still running intermittently then the motor is bad.
Dec 06, 2017 | Amana Heating & Cooling
I have an Amana NED7200TW dryer that is approx. 2 1/2 years old and am having issues. The first sign of a problem was it would not come back on after running a 40-50 minute cycle. Nothing would come on,...
Open the cabinet and look for lint buildup around the motor. Lint will act like a blanket and hold to heat in on the motor which in turn will cause it to shut down by way of it's safety mechanism. Check that out and post back your findings.
Oct 16, 2012 | Amana NED7200TW Electric Dryer
Dryer will heat then run for a while then shut off after a few minutes you can start-up again what is wrong.
Reach in there and turn the drum. Does it turn real easy? If it don't the you need to check the glides and rollers. Amana dryer service manual
May 03, 2011 | Amana Dryers
Amana Designer series dryer Model LE447W tries to turn on but wont
You can watch a video that explains how to test all the major heating components inside the dryer at the link below.
http://www.appliancerepairlesson.com/
Mar 11, 2011 | Amana Dryers
Dryer is not heating up. yesterday the dryer would not turn on, the black wire on the cord had burned in half. bought a new cord, dryer turns on but no heat. circuit breaker was not tripped. turned it off...
These are pretty simple to fix. Take the service panel off and check the heater elementthemobilian_1392.jpg
The limits and element is all in one nice little bundle and only 2 screws to mess with.
Note: the control stat is mounted on the blower housing, these limits on the heater element only tripp if there is air restrictions.
I have your service manual right ova heah: Amana dryer tech service brochure
Feb 10, 2011 | Amana ALE230RAW Electric Dryer
This is a simple dryer design. The limits and heater are all mounted on the heater assembly. 9ce9b7a.jpgGet the front off and take a look see. AMANA DRYER
May 04, 2010 | Amana NED5500TQ Electric Dryer
Amana Dryer 14 years old, turn on the dryer heats for about 10 minutes, then I hear noise like grinding noise and the heat turns off?
Remove the front panel and check the blower wheel on the motor. If it turns freely on the motor shaft replace it.
Aug 30, 2009 | Amana Dryers
Heating Element Won't Turn Off
Ok, this is a control fault that may be corrected by shutting the power off for 5 minutes. this will reset the chip set on the control board. plug the unit back into the socket after the 5 minute ait and check to see if the element is still on. If so, replace the control board.
May 29, 2009 | Amana ADW662EA Built-in Dishwasher
Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub Washer Logo
89 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
