Question about iLO V27DMBX Television
Ilo 27inch hdmi hd tv monitor
What cable do i need to connect the ilo 27 inch hdmi hd tv monitor to a computer???? The computer has vga /serial port
You would need to connect a VGA + Audio to HDMI Converter. The downsize it the converter goes for about $150 us
Posted on Apr 12, 2008
2 Suggested Answers
SOURCE:
Benimur
  • 6966 Answers
SOURCE: ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Posted on Jul 31, 2007
What kind of wire do I need to connect my samsung laptop to panasonic viera hd 3d plasma tv?
Most TVs will have HDMI and RCA component and composite jacks. Some TVs will also have a VGA port. Your laptop will have a VGA port. (If the laptop is fairly new, it may also have an HDMI port.)
Not all TVs will support an HDMI signal from a computer, so the VGA signal is often better. However, that limits you to SD (anything with HDCP will fail.)
Very few TVs ship with the HDMI or component cables. However, there are some vendors who do package the HDMI cable with their TV. Without knowing which exact model of TV and laptop, I can only make a few suggestions. I know that the TCP42ST30 (Plasma 42") doesn't have a VGA port.
Look at your laptop for any external monitor port. VGA ports are generally blue female ports with 15 holes (D-Sub). If your TV has a matching VGA port, get a standard VGA monitor cable.
If you have the VGA port on the laptop but not on the TV, you can try a converting from VGA to HDMI. (You may need a DVI to VGA adapter and either a DVI to HDMI cable or a DVI to HDMI adapter.) Note: this gives an analog signal (RGB format) to the TV. You'll also need to make sure that your VGA port is active (in the BIOS for some computers) and then set your computer to send the signal to the external monitor. It is best to turn off both the computer and the TV before connecting the two. Then turn on the TV and set it to the correct input before turning on the computer. (In Windows 7, I set the video signal for the external monitor by right clicking on the desktop and selecting Graphics Properties. Set the signal to the external monitor and click Apply. Then click OK (in the external monitor's screen).)
If this doesn't work, you need a VGA to component video converter. (Not a VGA to component video cable - those are for projectors that read the RGB signal.) See http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-video/c10000-c11200-c11215-p1.html .
Some laptops come with an HDMI, mini-HDMI or a DisplayPort option. For the latter two, you will need the appropriate cable with that end and the HDMI connector on the other. Then connect the TV and the computer as described above. (Note: my TVs accept a computer signal at the HDMI port labeled HDMI/DVI. However, you need to make sure that your TV understands this signal. It isn't the same format as that from a set-top box. My laptop has VGA and HDMI out; the desktops have VGA, DVI and HDMI (on one).)
If you add a comment with the model of your TV and laptop, I'll be glad to give you more specific options to connect the TV and the computer.
I hope this helps.
(A DVI port is a digital video out option with ~21 pins and is usually white.)
Feb 03, 2012 | Panasonic VIERA Televison & Video
Hello, I was wondering, if there is any way to connect my computer, which is a Dell Dimension C521, up to my T.V., which is a 32 inch ilo. I have a Philips Video and Audio red white and yellow connector,...
Connecting a pc to a TV is quite simple. Your PC has either a vga out or HDMI port. Just get the right cable and connect to your vga port on the TV or HDMI port on your TV.
This way you can even have the two screens running, alternatively press Fn and the appropriate F key to switch off the laptop screen.
Your sound will still be thru your PC speakers.
Jan 10, 2011 | Computers & Internet
How do I connect my laptop to tv to use as monitor
It depends on the laptop and the TV. If both have a VGA port, then use a VGA cable between them. Make sure the VGA port is enabled on the computer (possibly in the BIOS) and then set the monitor properties. You may need to reboot the computer to get the TV on.
If the TV has HDMI input and the laptop also has an HDMI port then you need to check the TV specs. Some HDMI ports can accept a signal from a computer (often labeled HDMI/DVI) and others don't. If the HDMI port is compatible with a computer source, then use an HDMI cable between the two. Again make sure the port is active. If TV's HDMI port is not compatible with the computer, you will need a converter.
If the TV doesn't have a VGA port (and the laptop doesn't have any video port other than VGA), then you will need a VGA to component video converter (or VGA to composite video) depending on the inputs of the TV. See http://www.svideo.com/pctocomponent.html for some converters.
Note: the converters are needed since computers output in a different format than the TV input understands. For analog, the computer is RGB and the component video is YPbPr.
A few media PCs might have a TV out port. This would eliminate the need for a converter. Check the specs for the cable you need.
I hope this helps.
Dec 10, 2010 | Televison & Video
We have a panasonic 32"inch lcd tv.we want to
hdmi Ports Qty 3 port(s) PC Interface VGA (HD-15) HDCP Compatible Yes
I read your tv has 3 hdmi ports and a PC input.
if your pc has hdmi out - the you use a hdmi cable from the pc to the tv on one of the hdmi inputs.
if your pc has a 15pin vga cable you can unplug from your PC monitor (or go buy a VGA cable if you want to keep one on the tv and one on your pc monitor - or if you are using a laptop).
when you unplug the computer from the monitor .. check the pins - should look to be about 15 pins in the connector. it that will plug into the tv- then you are using a vga cable. if it will not plug into the tv pc input .. don't force it. It could be a dvi connector . .take the cable off the PC and to radio shack and they can fix you up (you need a dvi to vga cable - not likely, but possible)
I always turn off a pc before disconnecting monitors - and plug into the other display before turning the pc back on.
Good luck.
Bill.
Nov 29, 2010 | Panasonic TCL32U22 32 in. TV
How do i connect my adventt9101 to my sony lcd tv, i want to use hdmi leads but i dont think my pc has hdmi port? any help
If you don't have an HDMI connection on your computer, then you will need to get a VGA cable. There should be a VGA connection on your tv. Just disconnect the monitor on your computer and connect the VGA cable from the computer monitor port to the VGA port on the tv. You may have to set the tv for PC or Aux input. You won't have high definition or sound to the tv with a VGA cable though. The sound will still come through your PC speakers.
Jun 25, 2010 | Computers & Internet
I HAVE A LG Full HD 1080p HDMI W2753V-PF 27-inch i was told my my tech that the monitor needs an inverter...Where can i get one and what is the part number ..if anyone could help me...
Well, you monitor has several input interfaces/connectors like;
  • D-Sub (Vga connector)
  • DVI
  • HDMI
If you are connecting this monitor to a computer, then you can use the Vga cable which came with the package. You can see the Vga cable here.. 3d8a2c8.jpg
You have to plug in either the terminal to the computer Vga port as shown below; 876c259.jpg
If in case you want better video quality and you don't have hdmi or dvi port
Dvi Port and Connector;
Hdmi Port
cables (these are available in most retailer stores)
It is not important to connect or purchase additional converter/hardware to connect you computer to the monitor, if you don't like the vga, you can simply get those cables.
I you let me know the Video card of your computer, I can help you better and shortened all these, but never mind, just refer to the pictures above and let me know if you can't make sure of yourself.
Good luck.
Thanks for using FixYa.
Jun 23, 2010 | Computers & Internet
How to conect my laptop to LCD
It depends on the laptop connections. First make sure that your computer is sending data to the port (particularly VGA); you may have to access the BIOS to change the setting (often F1 or F2 on restart). If you have a VGA port on the laptop, get a video cable (VGA-VGA) and connect the two together (this is usually a blue port and you need M/M ends). Then enable in the graphics properties (right click on the display where there are no icons or running program). You want the section that lets you choose sending to the external monitor, the laptop monitor or showing the same contents on both. The version of your OS may alter which command you need (you can also access this in the Control Panel (Display). You may need to restart the computer with the TV on to get the computer to recognize the TV. Set the TV to have the source the PC input. Also connect the speaker cable from the laptop to the TV if you want to use the TV's speakers (there is an audio port next to the VGA port that I believe is a 3.5 mm jack (would need a stereo 3.5 mm m/m cable between the two). Make sure you select the optimum resolution of 1360 x 768.
If you have an HDMI port on the laptop (newer laptops), get an HDMI cable (m/m) and connect the two. Set the TV to DVI or HDMI source (depending on if you need the audio cables separate) and reboot the computer. Then enable the display, as above. I believe you still need the audio cable as well (should use a 3.5 mm stereo to RCA R/L (red/white) cable) look for the DVI audio next to the HDMI/DVI port.
I hope this helps.
(my understanding is that computer HDMI ports do not send the audio but you should check your laptop manual.)
Jun 09, 2010 | Samsung LE32R71B 32 in. HD-Ready LCD...
Play laptop video on tv
yes vga plays hd video. but an hdmi cable is better. get a VGA to HDMI cable
Jan 17, 2009 | Compaq Presario V4000 Notebook
Pioneer SD-643HD5 HD set up
Yes a simple cable will do it. Look for a converter designed to display a computer vga on an HDMI jack. I have one, and would expect it to work in reverse. My cable has a male VGA like a computer monitor cable.
Oct 22, 2008 | Pioneer SD-643HD5 64" Rear Projection...
Ilo 27 inch hdmi/dvi hd tv monitor
Jul 31, 2007 | iLO V27DMBX Television
iLO V27DMBX Television Logo
318 people viewed this question
Top iLO Televison & Video Experts
Steve Allison
Steve Allison
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
