Question about Toshiba Satellite Pro L300 Notebook
When restoring my SP L300 I get an adapter fail to install
During complete restore on my Satellite Pro L300 all items seamed to reinstall except for the very last thing is a box that says adapter failed driver not installed. What adapter failed and how can I figuare it out?
  • wildrose745 Feb 03, 2009
    That was the first thing I did but to no avail. Nothing shows a problem, I've scanned for issues - nothing but when I get going on the computer it stresses out shuts down and restarts with a error of failure system recover box. Any other Ideas would be appreciated...
  • alangunn1 Feb 05, 2009
    I have the same laptop and have just re installed vista from the recovery disk.
    Now it found unknown usb device and installs it as the same.
    But i have no wifi adapter now ??? just the unknown usb.
    So i put xp in and everything is ok now ????
    Done my head in all night.
  • 31 Answers
Click Start>Control Panel>System>Click the Hardware Tab, Click the Device Manager, Look for the item that has a question mark.
 Go to Toshiba's website, download the driver and install it.
Posted on Jan 31, 2009
Toshiba Satellite l300 1ap windows 7
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on the hard drive then follow these steps to restore your Toshiba to the Out of the Box condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the system recovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
Oct 15, 2012 | Toshiba Satellite Pro L300 (L300-EZ1502)...
I replace the ram from my laptop toshiba satellite pro-300 but when i start the computer by recovery disk it freze after loading files
If you have more than one memory stick installed, test the system with a single memory module at a time:
Take out both modules, install a single module and turn on the system. Try to restore
If it fails, turn it off, disconnect battery and adapter. Take out the same memory module and install it in another memory slot
Turn it on again
Repeat the same steps with another module
Sep 19, 2011 | Toshiba Satellite Pro L300 Notebook
I have a Toshiba Satellite Pro L300 With Windows Vista on it. Keep getting BOOTMGR during startup. I'm not in the possession of a vista dvd. Seeing this laptop came with the OS...
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
May 30, 2011 | Toshiba Satellite Pro L300 Notebook
System restore will not restore to ANY point it says it encountered an unspecified problem TOSHIBA SATELLITE PRO L300
Hi There,
I'd like to qualify this answer as a trouleshooting attempt rather than a solution to be judged with negative feedback. Sometimes, Toshiba OEM (Original Equipment Manufacturer) Software can interfere with normal Windows Programs. A possible way around this is to use Safe Mode.
1. With your computer completely powered off, push the power on button and hit the F8 key repeatedly until a screen appears with choices to boot Windows from Safe Mode.
2. Using the arrow keys, navigate to "Safe Mode with Networking" (this allows internet access in Safe Mode) Hit the Enter key.
3. Once arrived at the Desktop, go to Start>All Programs>Accessories>System Tools>System Restore and try the System Restore from Safe Mode.
If this is not successful, you may have a virus (many of which often attack and disable System Restore).
4. If you have a hidden virus, you should download this program in Safe Mode to find out:
http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html
If Malwarebytes does not find a virus then your issue may be difficult to diagnose from here.
Best Regards,
Selk
Mar 31, 2011 | Toshiba Satellite Pro L300 Notebook
Toshiba satellite L300 black screen. Tried the 0 key and it only goes 1/3. thinking booing/registry corrupt. No recovery disk or software came with my laptop. O/S is Vista I have data and photos that...
Yes everything will be wiped out, once you do the recovery. It will reinstall the factory settings.
You may try this first; Turn OFF the laptop, remove the power sources (ac adapter and battery). Without power sources, hold power button 10 secs. Put back the power sources, then try to boot from safemode. Tap F8 upon booting up to enter the advance boot option. Select safe mode, save your files once loaded in safe mode. You may first try the system restore from , go to start/all programs/accessories/system tools/system restore, select the previous date the laptop was working fine. If this will not work then the last resolution is the recovery.
Hope this helps.
Mar 22, 2011 | Toshiba Satellite Pro L300 Notebook
I need to get a recovery disc for my TOSHIBA SATELLITE M200. I lost the back up cd.
To create recoverry disk follow bellow the link
https://www.csd.toshiba.com/cgi-bin/tais/support/jsp/serviceUnitVerification.jsp?orderType=SFF
You need to install java.
You can restore, factorry setting just follow bellow link.
http://www.pcrecoverydisks.com/hp/hp-system-restore-vista/
Choice the >company >Os and do it
Hope it will help you.
Jan 01, 2011 | Toshiba Satellite Pro L300 Notebook
Takes more then 1hr of logging off
Have you already checked it on safe mode? if it is similar problem, you can do system restore.but, just to remind you that don't just proceed for system restore as it will delete your current data depends on the date that you will restore. If your'e sure enough that no datas affected during this procedure then, you can proceed. Cheers!!
Dec 28, 2010 | Toshiba Satellite Pro L300 Notebook
My toshiba cd or dvdram drive if i click says enter disc in drive
During boot press F8 and from the menu that will appear select the Recovery one.
Jul 05, 2010 | Toshiba Satellite Pro L300 Notebook
How do i set my toshiba satellite pro L300 back to factoery settings
Put the original restore CD into the drive and restart the computer. It will then go into a "restore mode" and allow you to erase everything and start it over like it was brand new again. If you don't have the restor CD then you could use any copy of a Windows Operating System (XP, VISTA, 7) to reset it all
Dec 25, 2009 | Toshiba Satellite Pro L300-EZ1005X...
Toshiba Satellite Pro L300 Notebook Logo
51 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
