Question about Panasonic PT-47WX53 47" Rear Projection HDTV
No Picture_Panasonic PT-47WX53
It seems like I have the same problem as you described to another member, something dealing with the high voltage system. The picture suddenly went out and now I have sound but no picture instead I have a faint line down the middle of the TV. Do you have an estimate of how much that would cost? Yatrik
  • tinyfeet Nov 03, 2007
    I have the same problem as a few of you. My tv still has great sound but a rainbow of the few colors through the middle of the set. What can be done? Is it a simple fix job?
  • Dj9926 Nov 14, 2007
    I am having the same problem... I'm using the service manual and checking capacitors with a multimeter only. First I though it was around the horizontal output transistor, but now I am looking around IC801 in the power supply. Can you be a little more specific on which capacitor. Your help is greatly appreciated. Thank you
Your problem lies with one single component that has failed. It is a capacitor in the HV area that is either shorted or open. The part is quite cheap and should only require one hour of labour. Judging by the labour rated these days, you should not expect to pay more than $100 for the repair.
Posted on Sep 06, 2007
No picture, sound ok except buzzing noise, some light in vertical stripe center of screen
your vertical drive would have failed or lost connection in the pcb.Only if you are familiar with high voltage electronics do attempt. or else this could be aminor issue , to resolder the vertical drive, vertical power failure or drive. A quick votage check into this vertical section will confirm and the sweep can be retained.
Jun 29, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Hi started my panasonic PT-47wx53 and it seem it was going to start up(could see picture coming up and heard voices) it then shut it self down and the power light flashed 3 times interval. tried again with...
Replace both of your STK ICs eample STK392-110
number will be printed on them also CK small blue capacitor 2k volt by hori output Transistor sometimes they burn up S Mats Electronics has STKs for $10.95
each Shops retail these for $55.00 each
1-800-628-1118. Good Luck and let me know if you need anything else.
Mar 24, 2010 | Panasonic PT-47WX53 47" Rear Projection...
No picture
Petty vauge possible Flyback/horizontal. since you don't get codes.. I would start with checking for +210 at D519, or look for high voltage.
Oct 04, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Jumping Screen 61" cinemavision
Hello dana1983165,
The problem you described is caused by poor voltage regulation in the High Voltage power supply. This can be caused by a defective fylback transformer, a defective focus block, a defective HV trippler, of the horizontal output transistor/damper diode assembly. I would first check the high voltage from the flyback to see if it was fluctuating, you can do this with a high voltage probe. The I would check the horzontal output transistor out of circuit with a transistor checker to see if it passes.
If you do not have equipment what you can do is remove the deflection/HV board and order a replacement from panasonic.
Look up Panasonic's web site and contact their technical support number and call them to find out the part number and have them order the part for you. If this fails try PTS at http://www.ptscorp.com
I hope this helps
Shuttle83
http://www.electron-age-technologies-llc.com
Feb 22, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX54J --- Picture Problems
Yes,try cleaning your mirror inside of tv they do get real dirty, also clean dirt off of tube lenses there are 3 of them red,green,blue. these are your picture tubes. Thank You for using FixYa and Have a nice Day.
Feb 05, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Picture shows only about a 2-3" blue,green,or red vertical line down the middle
If your seeing vertical line across the screen you need to check the components in the vertical stage as well as the vertical IC could be bad, or the yoke could open.
Also check if any voltage reaching the vertical stage.
Good luck.
Was this help full.
Oct 31, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX53 47 in
ck mosfet and hori output also look for burnted capacitors [2] of them 1200pf 2k volts.
Oct 09, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX53 Horizontal Picture Size
Normally, when I see this problem in the customer's home, I find the main culprit to be the cable or satelite receiver box. The remote for the cable box may have a button on it to change the format or picture size. You may have to go into the menu of the cable box to change the format setting. Hope this helps.
Apr 28, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47wx53 screen converged to middle of screen
This sounds like a classic High Voltage problem. Yes the two issues are related. Something in the High Voltage circuit has failed and originally caused the increased size. If you described the problem to the warranty people I'm surprised that they didn't recognize the problem and fix it under warranty. Now you have a short or partial short in the same circuit causing the fault (light blinking) after a few minutes. This problem will not cure itself. As I have told customers in the past "Electronics are not human and will not heal themselves". Maybe in the future, but not yet. You need a technician and it should be covered under warranty if things are as you described. I would recommend calling Panasonic customer service. They are usually a very good customer oriented company.
Nov 05, 2005 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
51 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
