Question about Toshiba 61HX70 61" Rear Projection Television
Picture gone screwy
Last night I was attempting to clear up the picture on my 6 year old 61HX70 by tightening the coaxial cable. After unhooking and rehooking it, I noticed that the picture had become distorted and the colors were not lined up correctly in the corners. It has 2 "lines" that scroll up the screen and each time the scroll the extent of the lineup on the colors changes. Along with this the sound has changed somewhat to a somewhat muted audio with some static in the background. Any idea what might have happened and what it would take to fix this?
  • 6 more comments
  • Don King Aug 07, 2007
    Ok, so I have ordered 2 of the IC's (STK392-110E). I should get them this week and will get them installed this weekend. I am a little concerned about getting that board out. There are 2 white connectors that appear to jump from 1 board to another. Is there a trick to getting the board out?
  • Don King Aug 10, 2007
    Ok, I got the chassis out, but I have 1 board/box that is preventing me from getting to the IC's. It appears to be soldered in. Best way to get this out or get around it? See pics...
    Pic 2
    Pic 2
  • Don King Aug 14, 2007
    Ok, I replace the IC's, but the problem is still there, maybe even worse. Anyone want a slighty use 61" TV?
    in the southeast, about 50 miles north of Atlanta.
    I do have a service manual, but tracing circuits is beyond me. Looks like I will need to call a service tech if this is to be fixed.
  • Don King Sep 07, 2007
    I had a guy who was coming out to work on it but he was a no show. I plan to call him the first of the week and see what happened.
    Sergeant:
  • 279 Answers
Did you end up taking this in for service? If so, were they able to fix it?
Posted on Sep 06, 2007
    President:
  • 3,130 Answers
The two lines, do they appear like a picture in 3-D? If that is the case, the convergence amp IC's probably were weak already, and took a dive when you were adjusting the set. As when the picture changes, so do the voltages on the power supply shift a little. I think you may have a power supply problem as well. Probably a capacitor in the main supply that gives you the plus and the negative voltages for the convergence. If you have the knowledge of soldering and working on printed circuit boards, you can change the two convergence IC's first. After that measure the + and the - voltages on the IC's and see if they are low or vary any significant amount. If you cannot solder, maybe a relative, friend, or maybe a neighbor can assist you, as changing the convergence IC's is not really difficult. A repair person will charge you anywhere from 300 to 400 bucks for a job like this. The IC's only cost about 15 bucks or so each. Good Luck, and let me know if you can handle this repair and if you need any more information's regarding this repair. Oh, one more thing, it is always a good ideal to get the service manual for this set, so you will know what and where everything is and can make any adjustments after the repair. The manual is available Here; http://www.servicemanuals.net/results.aspx?type=SM&brand=0&model=61HX70
Posted on Aug 04, 2007
  • 2 more comments
  • Larry  Dillon
    Larry Dillon Aug 07, 2007
    slde the entire chassis out of the set and disconnect the plugs you need to. Just be sure they are marked or you will need to mak them somehow.
  • Larry  Dillon
    Larry Dillon Aug 14, 2007
    you may have a few resistors or circuit protectors blown in the set. This is very common problem in these TV sets. What part of the country are you in?
  • Larry  Dillon
    Oh too far for me I'm afraid. I live way up north in Northern Michigan. Do you have the service manual on this set and can you do circuit traces and check voltages with a multimeter?
  • Larry  Dillon
    Oh too bad, if you can trace maybe I can help, but it is good that you know your limitations, as you do not want to get involved over your head, and maybe end up hurting yourself, possibly seriously!
I have a sanyo DP50740plasma tv a few years old. Last night I got wi fi and hooked up a Samsung blue ray player and the sound quit working. the picture is clear on dish (on HDMI 3) and the blue ray p
What happens when you take the bluray hdmi out? or turn the bluray power off from wall? can you connect audio from bluray with a separate cable? often one device overrides the other. there may be a way of daisy chaining the devices
Dec 17, 2014 | Sanyo 50" Plasma Hdtv Dp50740a W/ Free...
No picture, has sound. Black screen with green lines.
Probably a power supply issue in a 7-year-old TV
Feb 13, 2014 | Sharp LC Televison & Video
Toshiba 61hx70 picture bounces and goes in and out of distortion
Most likely bulbs are failing and dirt and dust are caught up in cooling fans and in the projector of the set.
Apr 15, 2010 | Toshiba 61HX70 61" Rear Projection...
Bent Picture at top and bottom
You have bad convergence amps.The fluid may need to be changed if the picture had a hazey look to it before the convergence went bad.
Dec 13, 2008 | Philips 60PP9202 60" Rear Projection...
No picture
It's likely the Ssb is out, Philips p/n# 319801634710 which on a difficult scale of 1-10 is about a 6 or 7 for repairs. That is a DPTV310 chassis and somewhat tight quarters inside. It's not so bad taking the strappings loose to get at the board but a tight area to work through getting the standup board unplugged from the signal board. One noteable caution: unplug the set for at least 10 minutes before opening the back VERY STATIC SENSITIVE..
Bill
Apr 02, 2008 | Philips 60PP9352 60" Rear Projection...
How do I decrease the amount of green in the picture?
Unfortunately this model has a bad CRT. If is 3-4 years old and the greenish picture is in all inputs, for sure the picture tube is gone. If the picture is green only in component input check the connections for the blue and red cables.
Dec 26, 2007 | JVC AV-27230 27" TV
Picture problem
Since it is 9 years model definetely loose contact and flux corrosion is there in wire connector and pcb also. Make one general service. Prolem solved.
Aug 23, 2007 | Toshiba CF35F50 TV
Flickering of screen (comes and goes) and weird DVD/reception problems
Depending on how old this set is, there might be a bad Hyper board bad. good Luck
Jun 29, 2007 | Toshiba 43H70 43" Rear Projection...
Toshiba model 61HX70 convergence issue
It is a good possibility you damaged something on that PCB that had the IC's, I like to use an upgraded chip the STK394-160e that is designed for HD signal stresses. I dont know why they ordered the convergence board but I suspect it would have been ok, there are also 2 jumpers that need soldering JW10 and JW50 that supply power to the chips and they REQUIRE resoldering or it will fail again. Might try reseating the RED CRT board, check for cables that you may have unhooked to see if they are not seated in their sockets properly, double check every wire you unhooked, Make sure you used a Silicone Heatsink Compound on to the back of the IC's. I dont know what all you unhooked, but check the wires going between the CRT Boards. Check for cracks in the boards to make sure they werent flexed to much. Good Luck.
Sep 09, 2006 | Toshiba 61HX70 61" Rear Projection...
Toshiba 61HX70 61" Rear Projection Television Logo
35 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
