Tried 192.168.1.1 in address, got a box with unsername and password. Directions said to leave username blank and put in "admin" for password. A pink restricted page came up. What now?
Here ya go this should help you out. I think the username is admin and the password is blank...depends on the model. Let me know if you need more help. Don't forget to rate this solutio with 4 stars before logging out.
The default login information for Linksys routers depends on the model as shown below.
Default user names:
Reset your Linksys router back to default: The easiest method of resetting your Linksys router’s password is to reset your router back to the default factory settings. This is done by simply holding down the reset button located on the back of the unit for at least 30 seconds. Once the router has been reset, it must be reconfigured. Using your web browser go to URL address http://192.168.1.1. You will then be prompted to login to your router. A log-in screen asking for the password will automatically appear. At this time enter the default password “admin”, in lower case letters into the password field. The username field may be left blank at this time. (Note: both the default username and default password are set to “admin” on some of the newer Linksys router models).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
The default password (or the password which has been set by you previously) is not getting accepted by the router either due to firmware issues or simply because you might have been entering the wrong password. Hence the above error.
Please try the following:
1. First you need to hard reset the router. Press and hold the 'Reset' button with a sharp object for 90 seconds continuously. The first 30 seconds of the reset process should be with the power cable of the router plugged in, the next 30 seconds with the power cable unplugged and the final 30 seconds the router should be reset with the power cable of the router plugged in.
However, remember to hold the RESET button continuously for the entire 90 seconds, even as you plug/unplug the power cable. This should reset the router to factory defaults.
2. Then try to access the router's web interface 192.168.1.1. Generally, there is no username by default for linksys router. The default password for the linksys router is "admin"
Since the router has been hard reset in step 1, step 2 should work and you should be able to access your router's web interface.
I hope this helps. If it does, kindly rate the solution.
Depends on age of router. Older ones had blank username and "admin" for password. Newer ones have "admin" for both username and password. Of course this is only if you've totally reset the router to it's factory defaults.
Was this helpful?
Yes
No
Popular Solutions for Dell Inspiron 6400 PC Notebook
i have dell inspiron 1318 with windows vista but my my microphone does not work ? if this laptop...
(More)
i have dell inspiron 1318 with windows vista but my my microphone does not work ? if this laptop contain the builtin microphone then why it is not working ????
i got a dell 6400 @ a garrage sale and it has a bios password,i need to clear it but i am not sure...
(More)
i got a dell 6400 @ a garrage sale and it has a bios password,i need to clear it but i am not sure how to
I switch on my laptop and nothing happens except the power light comes on and there is a indication...
(More)
I switch on my laptop and nothing happens except the power light comes on and there is a indication that the keys are locked
When I load facebook, the page does not load and all I see is a message saying hello and I cant...
(More)
When I load facebook, the page does not load and all I see is a message saying hello and I cant click on anything. Totally stuck on an almost blank page.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
