Question about Safety 1st Summit Booster Car Seat - Cannoby
I cannot figure out how to put the straps, harness back in the carseat correctly after washing the cover. are there and instructions online?
  • 25 Answers
You can search for a copy of the instruction manual here.
Posted on Feb 18, 2009
Footmuff instructions
Hi Beth - First open the footmuff, and set the carseat down on the floor in front of you so you're facing it. Take the harness pads and ****** pad off the harness straps and place the footmuff into the carseat. Pull the harness straps through the holes in the footmuff and press the back of the footmuff into the curve of the carseat. Replace the harness pads. You're ready to go! When you use the carseat, simply put baby in and do up the harness as usual, then do up the footmuff for cosy, safe travelling.
Nov 24, 2011 | Maxi-Cosi Baby Gear
I recently removed the cover of my maxi cosi priori car seat to wash it. Now I cannot work out how to put it back on. Basically I have unhooked both shoulder straps that I think were previously threaded...
Good Afternoon
Go to www.maxi-cosi.com and select the CabrioFix carseat to download a replacement instruction manual for details of how to replace the fabric.
The harness should not have been completely removed from the carseat in order to remove the fabric. If the harness has been completely removed we cannot advise that you re-thread it due to the safety implications of it being incorrectly done. In this instance please contact the customer service department on 01284 413 141 Mon-Fri 8.30-4.30 to discuss the carseat being sent to our engineers for them to re-thread the harness.
Aug 16, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
Hi i have got a maxi cosi cabriofix car baby car seat and cannot seem to remove the cover at the bottom where the grey circle is how do i do this and can i was the cover in the washing machine once...
Good Morning
The grey tensioner strap appears to be stitched in place but it isn't. Follow it around under the bottom of the carseat and the strap is in a piece of plastic catch shaped like an H on it's side. Wiggle one way then the other to unhook from this catch, and the carseat fabric can be removed (where the grey circle part is the fabric is tucked underneath slightly, once you've unhooked the tensioner strap you'll be able to get the fabric off easily).
Hand washing is recommended, but if you have delicate or handwash cycle on machine this is also suitable. Use a mild detergent and maximum temp 30 degrees for washing. Do not tumble dry: Do not leave in direct sunlight to dry. Ensure fabric is completely dry before putting it back on for use as damp fabrics may result in mould or mildew growth.
Remember never remove the harness straps from the carseat, the fabrics can be completely removed while the harness remains in place!
Aug 04, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
Have removed cover from front facing car seat can't secure straps at back when put back on
The carseat harness should never be removed due to the safety implications of it being incorrectly re-fitted. Your carseat will need to be sent to the engineers for them to fit the harness correctly.
Feb 05, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
Once removed how do you replace the cover and put the strap back correctly for rear facing maxi-cosi car seat?
Good Evening
Instructions for replacing your fabrics are in your Maxi Cosi CabrioFix user manual. If you no longer have your user manual you can download another copy at www.maxi-cosi.com and selecting the CabrioFix carseat. Above the product image you will see a tab to download a user manual.
If you have removed the harness from the carseat completely this carseat needs to be sent to our engineers for them to re-thread the harness. Due to the safety implications of this being done incorrectly we cannot recommend that this is done by anyone else. The standard charge is £50 and this would include courier delivery service of the carseat back to your address. In addition you will need to make arrangements and cover costs for a courier delivery service of the carseat into our engineers.
Jan 08, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
Evenflo carseat,can't figure out the straps after washing
You need to put the straps throught the bottom, then the top openings you put it through the 2nd **** or where the baby will be comfortable. Then you tie it on the back.
Jun 17, 2009 | Baby Gear
How to lower straps on evenflo infant carseat
You're trying to unattach the straps from the wrong end....flip the car seat over and on the very bottom there is a little gold clip that pops out and you can push through the hole.
May 19, 2009 | Evenflo Embrace
Washed liner, need to know how to put car seat back together
How to put car seat belt around infant car seat?
Jan 08, 2008 | Baby Gear
Cosco 5-point omega carseat
ok I had such a hard time with this, i looked on the internet for hours and found NOTHING!! haha so i went to babies r us and checked out a similar one so here it is.
first the strap goes on the bottom, pull them even and the add the buckle, plastic buckle thing, and the other thing soft thing. then put the strap through the back of the seat (you should have two ends) not the must go OVER the adjusts! now take the metal piece that adjust the length and pull it long enough for it to reach the two straps and hook them up!! haha if this isnt good enough go to a store that carries the alpha omega elite car seats and check it out! GOOD LUCK!!
May 10, 2007 | Cosco Alpha Omega Elite 5-Point 22-155
Safety 1st Summit Booster Car Seat - Cannoby Logo
707 people viewed this question
Top Safety 1st Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Safety 1st Baby Gear Expert? Answer questions, earn points and help others
