Question about Sony VPL-EX1 Multimedia Projector
Removing the "lamp needs replacing" warning message
I am up on a mine site as a tecchnician and I am told the lamp has been replaced with correct type globe.The problem being without a remote control we cant remove the warning message now that we yhave replaced the globe.any ideas?
  • juda_kwt Mar 26, 2008
    I have the same problem, in getting rid of the replace lamp message and to reset the lamp timer, however i do have the remote but there seem to be no option for that.
    Jude
  • 563 Answers
Hi guys
Firstly you need the remote to reset the lamp timer.
Hold down the left and right scroll buttons on the remote and press menu. That will reset your lamp timer.
Posted on Mar 26, 2008
  • Gyoza_Daimyo Oct 29, 2010
    I do not have a remote for the VPL-EX1 either and need to reset the lamp timer.
    On the unit itself there is no 'reset' button, one a joystick/enter button and a menu button.
    I tried pushing both these buttons at once in the hope that it would reset but no luck.
    Does anyone have any idea how to reset the lamp timer on this unit *without* the remote?
    Thanks in advance, Ben
SOURCE:
Warning message for lamp replacement appears at each power up!
After replacing the lamp, make sure the lamp cover is securely closed. Select the Lamp Replacement option in the menu, (MENU > Settings > Setup menu) and follow the on-screen procedure.
Apr 20, 2017 | Sony LMP-H130 Projector Lamp Projector...
My pt-ae900u wont turn on. the lamp light is flashing red..and the motor or fan is making a soft scratching noise. I never got any warning on the screen saying the bulb was in need of replacing..but its...
First of all check the remove the lamp and check the same. if it found burned you have to replace it. Remember one thing you have to reset the lamp hour After replacing the lamp. You can see the option in the menu.
resetting procedure.
1. inset the new lamp.
2. power on the projector.
3. Press menu and select OPTION.
4. Press enter button and the select LAMP RUN TIME.
5. Press and hold MENU button for 3 seconds.
6. Lamp reset , power off message will display.
7. power off the projector. this will reset the lamp hour.
Also Check the lamp cooling fan of your projector. may be its has some problem. its not running at the correct RPM. Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now u can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector. power ON the projector and watch.
ok
Mar 10, 2011 | Panasonic PT-AE900U Multimedia Projector
Bulb "End of Life" message
hi,
for replacing the lamp do yhe following.
1.Remove the lamp cover by pushing two grooves lightly with the flathead
screwdriver. You can see the lamp cover on the top of the projector. ( left side of the lens)
2.Loosen the two screws securing the lamp housing until the screwdriver
goes into a freewheeling condition. The two screws are not
removable
3.Remove the lamp housing by pulling out the handle
4.Insert a new lamp housing until the lamp housing is plugged into the
Socket
5.Secure it in place with the two screws.Be sure to tighten the screws.
6.Reattach the lamp cover
7.Snap the lamp cover into place.
Replacing a new lamp automatically clears the lamp usage hours ok
Jan 27, 2011 | NEC MT1060 Multimedia Projector
HD70 DLP Projector: after replacing bulb warning message of "replaceme...
You need to reset the light counter. Access through right most menu item. Then arrow down to lamp settings.
May 17, 2010 | Optoma HD70 DLP Projector
Replaced bulb but still getting "lamp will fail soon replace" warning
When you replace the lamp, you need to reset the lamp counter as well. The procedure for this should be in the owner's manual. This counter is a guide only. Lamps have an expected lifetime and the message indicates that the lamp is nearing that lifetime. Once reset, the counter will again trigger the message once this new lamp reaches that usage time.
Dan
May 06, 2010 | Optoma H30 Multimedia Projector
My sony KDF-50E2000 TV has screen message coming up that says projection lamp life is expiring, is the XL2400 the proper replacement and will that correct the problem
Yes XL2400 is correct number. Replace Lamp message is a timed message that will reset and turn off if you unplug TV when lamp is removed and replaced.
Mar 02, 2010 | Sony KDF-50E2000 50" HDTV
The lamp went out on our 4 year old 42" samsung, model #HL-R4266W where do I get a new bulb and how do I change it
Check the following before replacing the lamp:
  1. The replacement lamp must be of the same code number and type with the old one.(Samsung BP96-01472A Lamp)
  2. The lamp type is indicated on the right side of the TV. It is also indicated on the lamp case.
  3. You can search online where to buy replacement lamp.
Caution:
  1. Replace the lamp with the correct lamp type to avoid damage to the TV.
  2. Turn off the TV and wait for 30 minutes before replacing the lamp to allow it to cool
  3. Do not touch the glass part of the lamp with your bare hands nor insert any foreign object inside the cover as it may cause poor screen quality, electric shock or fire.
  4. Do not place the old lamp near flammable objects or within the reach of children.
Tools needed:
  1. Phillips screwdriver and a pair of gloves.
Procedure:
  4. Separate the Lamp from the engine by holding the handle and pulling it out. 3cd3c78.jpgc21b6a2.jpg
  5. Reinstall the Lamp by following these steps in reverse order.
  6. Align the lamp cover with the groove and secure the screws. The TV will not turn on if the lamp cover is not correctly closed.
Nov 27, 2009 | Computers & Internet
The person I purchased this t.v from is saying the lamp was just replaced, but the FINAL WARNING REPLACE BULB AND RESET TIMER message pops up every time I power the tv on. She said she forgot to reset the...
If the timer has not been reset telling the unit it has a new lamp you will get that message. Call a servicer to find out how to reset the timer if you don't have the owners manual. If the message continues after that you will need to purchace a new lamp. There are problems that accur with some aftermarket lamps.
Sep 21, 2009 | Televison & Video
Lamp Hour Meter
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Lamp hour reset to many popular projection TVs are given.
Mar 03, 2017 | Televison & Video
Lamp Hour Meter
This proceedure should work for your model to reset the lamp meter.
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Mar 29, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Sony VPL-EX1 Multimedia Projector Logo
659 people viewed this question
Top Sony Office Equipment & Supplies Experts
Jaime Hernandez
jasbo
jasbo
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
