Question about Panasonic PT-50LCX63 50" Rear Projection Television
TV turns on with sound&pic then shuts of lamp&on/off blink red
Tv turns on normally, then without reason turns off with blinking red lamp indicator and red blinking on/off button. After a short break, tv turns on again with picture and sound ok, cycle conintues. Checked lamp, rebuilt model installed 9 months ago last year, filament good, lens good. Vacuumed rear electronics. Two visible fans working, but never turn off even when lamp is cold. Fans turn off only when plug is pulled out of wall. Thermal unit on lamp housing looks ok visually. Not sure what is going on. Any ideas?
  • 1 more comment
  • Peter Cermak Jan 31, 2009
    Yavier,
    Thank you for your reply, I have need of more insight. You say that a component on the power supply board is overheating. I am not sure how this is happening, or if this is occuring. Hear me out just a bit... The tv is off and stone cold. The back panel is off, all the dust is gone, and the three fans that I can see are running. They do not turn off right now. There is a large 5 inch fan on the far right, one 3 inch fan next to where the power chord enters the rear, and on flat on top of the rear plug in panel. The air temp is 68 degrees in the house and with all that, when I turn on the tv, within 20 seconds of seeing a picture, it shuts off - snap. It seems to me that there is not enough time for anything to overheat. I can even touch the lamp casing cause it doesn't get time to heat up. Does this change your analysis of the problem, or can the board heat up instantly causing this sudden shut off? Thanks for your patience. Let me know if this information changes anything.
  • Peter Cermak Feb 01, 2009
    It has been suggested that my television is shutting down because a component on the power board is overheating. I hope you can read my earlier postings, He is a summary again: When I turn on my tv, within 60 seconds, sound, picture on, channel selection functioning, it shuts off. I checked the rear area, cleaned out the dust, three visible fans running ok, everything cool. When it shuts off, the red lamp blinks and the power button blinks red as well. When I turn it on, the power button turns green again and the lamp warning turns off. Can a component overheat in 50 seconds? Any other ideas? Thanks
    Hey Guys, looks like it is off to the M. Emco repair dude down the road. At least we have some sense of direction to go on. Will let you know what the final outcome is for future reference. Thanks, Peter
    President:
  • 1,952 Answers
  • Plug a lamp into the outlet to make sure it is live. If the lamp works, then the problem is the TV. It not, the outlet is defective or the fuse is blown or the circuit breaker is tripped. There is another very simple explanation that is sometimes overlooked: This is a switched outlet. You always wondered what that wall switch was for that didn't seem to do anything and you flipped randomly. :-) Well, now you know!
  • Try wiggling the TV's cord both at the outlet (also push the wire toward the plug) and TV (also push the cord toward the TV) with the set on and/or while pressing the power-on button. If you can get a response, even momentarily, the cord likely has broken wires internally.
Beyond these basic causes, troubleshooting will be needed inside the set todetermine what is defective. Also see the section:Intermittently dead set - bad cordset.
Posted on Feb 01, 2009
  • 1 more comment
  • mohammed marika thambi
    mohammed marika thambi Feb 01, 2009
    posistor is a combination of a PTC (positive temperature coefficient)
    resistor and another resistor-element to heat it up and keep it hot.
    Sometimes, these will go by the name posister or thermistor. The heater
    is a disk shaped resistor across the power line and the themister
    is a disk shaped device in series with the degauss coil. They are in
    clamped together to be in close contact thermally. You can pry off the
    lid and see for yourself.
    The most common failure mode is for the part to short across the line.
    Its function is to control degauss, so the only thing you lose when you
    remove one of these is the degauss function on power-on. When you turn
    the TV or monitor on, the PTC resistor is cold and low resistance. When
    heated, it becomes very high resistance and turns off the degauss coil
    but gradually - the current ramps down to zero rather than being abruptly
    cut off..
    • A low voltage power transformer feeding one or more sets of rectifiers,
      filter capacitors, and possibly regulators.
      A power surge could cause the primary of the transformer to open up.
      There may also be a thermal fuse under the outer layers of insulation
      which blew either due to overheating or a power surge. However, if the
      primary is open, it is best to replace the transformer rather than
      attempting repair it.
    • One or more voltage dividers connected directly to the AC line feeding
      rectifiers, filter capacitors, and possibly regulators.
      Open resistors and dried up capacitors are common failures since the
      resistors are often not rated adequately and run hot, in close proximity
      to the capacitors.
    • A portion of the main (switchmode) power supply that runs all the time.
      Failures could be almost anything that would affect normal operation of
      the power supply as well as problems with the control circuitry.
    • Deflection yoke - since the horizontal coils are part of the horizontal
      flyback circuit, there could be problems running without a yoke. This
      could be anything from it appearing totally dead to an overheating or
      blown horizontal output transistor. There may be no problems. Vertical
      and any convergence coils may or may not be problems as well.
    • CRT video Driver board - pulling this should not usually affect anything
      except possibly video output and bias voltages.
    • CRT 2nd anode - without the CRT, there will be no capacitor to filter
      the high voltage and you would certaily want to insulate the HV connector
      **real** well. I do not know whether there are cases where damage to
      flyback could result from running in thie manner, however.
    • Front panel controls - disconnecting these may result in inability to
      even turn the set on, erratic operation, and other unexpected behavior.
    • Degauss - you just won't have this function when disconnected. But who
      cares - you are not going to be looking at the screen anyhow.
    Genius:
  • 1,913 Answers
I think your chipset diode trnsistor or register is gone.i think it is beeter adviced to call tchnical person to change those blown thing.also check your power supply waltage and earthing problem.may be if u connect more than 1 device to powersupply this problem occurs. so try to turn your tv with opther power supply bord in your home.Best of luck.
    Sergeant:
  • 326 Answers
If the tv is in warranty get it replaced.as it the board problem.
Posted on Jan 31, 2009
  • 10,594 Answers
Do you have service manual of your PT-50LCX63 TV?
You can have it from Manual Zone for small fee to check circuits.
Blinking lamp and standby light is error sign, Please count blinks and check in service manual as it has details about error codes and suggestions where fault can be.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, it could be the relay at the power supply board. You can try to verify by listening closely for the clicking sound when the unit turns on or off. Either the relay contacts are pitted/burned and would need replacement or the driver transistor of the relay has cold solder issues. In some instances, it could be the filter capacitor of the B+ to the relay that needs looking into.
Good luck and thank you for using FixYa.
    Sergeant:
  • 250 Answers
Its due to any of the component on the main power supply board getting overheated.just do not use the tv till it get rep[aired as it will damage the board as if you will use it .
Yellow blinking light . what does it mean
A blinking yellow for this model indicates the TV is too hot, unplug & allow 30-45 min to cool before re-plugging .
OR: lamp not installed or lamp door not closed. there is a lamp door switch that may not be closing, simulating door not closed
LED Indications
The front panel Status LED provides an indication of
the set's operation and the possible cause of a malfunction.
If an abnormal condition is indicated, perform the
Self Diagnostics procedure.
Self Diagnostics
To activate, press the front panel <ACTIVITY> &<CH
??> buttons at the same time and hold for 5 seconds.
The STATUS LED will then flash denoting a two digit
code.
• The number of flashes indicates the value of the
MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2
second.
• The LED then flashes indicating the value of the
(ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED
will flash two times, pause, and then flash three
times.
Table 2-2: LED Indications
Error Codes, descriiptions and the most likely cause of
the error are listed in Table 2-3.
Note: The TV must be in "Shut Down." The LED
will probably be indicating an abnormal
condition. If the TV is switched Off, AC is
removed, or a System Reset is performed, the
code automatically resets to "12" No Error.
See the Error Code Log to retrieve a history of
errors.
Note: Use the front panel buttons, not the remote
control.
Note: If there is no response, the front panel may be
locked by a V-Chip setting. To unlock, press
and hold <ACTIVITY> on the front panel for
8 seconds.
LED Indication Condition
Off Off (standby)
Green Power On
Slow Blink Green Power Off with Timer Set
Fast Blink Green (80 seconds) > Off Power Off (Cooling fan still working, 80 sec)
Red Lamp Failure
Yellow TV Too Hot
Slow Blink Red TV May Require Service
Slow Blink Yellow Lamp Door Open or No Lamp Installed
NORMAL INDICATIONS
ABNORMAL INDICATIONS (For details perform Self Diagnostics Procedure.)
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
Tip
Error code by led indicator samsung SP67L6HX1X
<img src="mas_baz.jpg" /><br />There are three LED indicators. LAMP, TIMER, STANDBY/TEMP. Each Led or combination leds indicated problem.<br /> <ul> <li>LAMP blinking : The picture will automatically appear in about 15 seconds.</li> <li>TIMER and STANDBY/TEMP blinking : A cooling fan inside the set is not operating normally.</li> <li>LAMP and STANDBY/TEMP blinking : Lamp cover on the rear of the set is not properly shut.</li> <li>STANDBY/TEMP blinking : Check if the ventilation hole on the rear of the set is blocked, because if the inner temperature is too high, the power will shut off.</li> <li>All LED blinking : Lamp may be defective.<br /></li></ul>It takes about 30 seconds for the TV to warm up, so normal brightness may not appear immediately. The TV has a fan to keep the inside lamp from overheating. You'll occasionally hear it working.<br /><br /><br />
on Mar 29, 2011 | Samsung HL-R6167W 61" HDTV
Samsung dlp tv wont turn on, blinks lamp light green and temp light red
These blinks of LEDs are fault indications. If you wish to get more details about these blinking codes, check this link. The details are there. It is very difficult to include all those details in tables here by this window.
Feb 03, 2013 | Samsung HLN467W 46" Rear Projection HDTV
Sony kdf50e2000 shuts down after 20 minutes, then 3 red blinks
This is the cause; 3 red flashes is bad main logic or power board, check for standby volts if ok replace main logic board
May 06, 2017 | Sony Televison & Video
Sony 3 lcd rear projection tv hd w/ wega gate. kdf-e42a10. tv will atempt to turn, shuts down, greem power light blinks 12 times on average. red standby light blinks 4 times. i replaced lamp [ xl 2400...
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Mar 02, 2011 | Sony KDF-E42A10 42 in. LCD Television
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Hello, We have the Panasonic project TV (PT-50LC14). We purchased a new bulb this past July. We're now experiencing problems with the TV. After turning it on for less than 5 minutes, the TV shuts off. ...
Hello well this kind of problem all the time is because you have a fan problem and you could have dirt inside of your tv and sounds also like a ballast problem i have this issue also and I got connected on the live chat that a web say has that they call discount-merchant they sell parts and lamps for TV they could help you they help me twice.
Regards
Jan 01, 2010 | Panasonic PT-50LC14 50" Rear Projection...
I have an LG DLP. that turns off after 15 -30 seconds
If the second light is blinking to orange or red, that is usually the lamp indicator light on an LG DLP tv. That indicates your bulb needs replaced, or something surrounding the bulb has failed (like the cooling fan for the bulb for example) IF you have a spare bulb handy, I'd replace the bulb, keeping in mind if you touch any part of a new bulb with your bare hands, you just cut the life of the bulb by more then half.
Jul 30, 2009 | LG RU-52SZ51D 52" Rear Projection...
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Dec 06, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Panasonic PT-50LCX63 50" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
