Keys on keyboard not working properly
My keyboard suddenly have messed up all keys, when i press backspace my PC will immediately switched off and some of the number keys are not working as well. when i press ? button, the outlook pops out, and > key, my document pops out....
PLEASE HELP!
    Problem Solver:
  • 7 Answers
Go control panel, hit mouse and find default settings. hit default, ok and do a reset on your computer.
If you have a special install disk for your mouse when the system starts back up ,test your keys then install the disk(or CD). if this does not correct your problem , check to see if someone changed the language on your pc. If english, buy a new keyboard.
Posted on Jan 31, 2009
BackSpace key does not work in charter.email formatting
I have the same problem - but it is a Charter email problem not a keyboard problem. The backspace key quit working suddenly and it doesn't work on ANY computer - so it's not related to the keyboard. I must have inadvertently changed the settings or something...
Sep 21, 2013 | Computers & Internet
Hot to fix messed up keyboard on laptops
The keyboard is faulty and needs to be replaced.
This WEB site may have a keyboard for your model laptop.
Keyboard replacement, LCD screens for mobile phones, Ipods and computer equipment. http://www.yallstore.com/index.php?main_page=advanced_search_result&search_in_description=1&zenid=1lrjst3ncshlb4c7frn9bev3c3&keyword=keyboards
Apr 17, 2013 | Computers & Internet
My backspace in not working at all suddenly
Get a can of compressed air and attach the straw, gently lift up key with fingernail and give several blasts of air to clean out the possible buildup of dirt under the key. If this should fail you will probably need to replace the keyboard, go to www.ebay.com and type make and model of laptop, refine search to keyboard.
Sep 17, 2012 | HP Mini 1000 Vivienne Tam Edition
When using my laptop it behave like any body has press backspace key I wont stop this problem,again I am pushing backspace key with my other hand it functioning properly,if I remove hand from backspace...
Hi dipannvora,
This could happen when they keyboard setting is malfunctioning or there is a possible virus which is the reason behind this misbehavior.
I would suggest you start the PC in safe mode and then check if it works fine , if it does , then the problem could be with a virus , else you need to get your laptop's keyboard serviced and the problem would be solved.
Aug 01, 2011 | Computers & Internet
Hi, this is molly vang, sorry i can't spaces on my keyboard. The spacerbar is not working and I can't understand what happened. Also, now the backspace is not working good to...
This sounds like a hardware issue. Try using a USB keybord to confirm that it's only your laptop keyboard. If the USB keyboard doesn't work properly, then you should run a virus scan and update your laptop's drivers.
If you've spilled liquid in your pc shut it down immediately, remove the key caps, and clean the domes with Isopropyl Alcohol on a Q-TIP.
If your usb keyboard won't work, and you haven't spilled liquid: Pry the key up and check if your rubber domes are broken. Sometimes keys that are used frequently will break. Try placing a piece of paper on top of the dome, and snap the key back on.
Dec 31, 2010 | Acer Computers & Internet
My HP Pavillion keyboard is keying properly
az i think your keyboard language has changed. from language bar you should change the language of keyboard. control panel-region and language- keyboard and language- change keyboard.
Apr 06, 2010 | HP Pavilion dv7-1020us Notebook
Backspace, g and h keys intermittently not working
I have had the same problem on my HP dv6700....backspace, h, g (maybe more) just randomly work and then don't work...must be a simple fix b/c this sounds like a problem for a number of people on different computers...we must be in some weird function or something? Any help?
Jul 29, 2009 | HP Pavilion dv7-1130us laptop
Backspace key
you might have sticky keys permanetly stuck on, ive had this problem, it worked after i held down shift and press the backspace key, then it worked nomally again. hope this helps.
Jul 15, 2008 | Acer NSK8458AN Keyboard
N, H, T and Backspace keys suddenly not working.
You can try blowing it out with compressed air, but you will probably need to remove the keyboard to make sure nothing was spilled or stuck in there. You should be able to remove the keyboard by removing the battery, then removing the keyboard securing strip, and then you should be able to take a screwdriver and pry the keyboard up and out.
May 11, 2008 | Toshiba Portege 2000 Notebook
KeyboaRD ISSUES
replace your keyboard if possible
May 08, 2008 | Toshiba Portege 3500 Tablet PC
Computers & Internet Logo
754 people viewed this question
David Payne
David Payne
