Question about B&K AVR-507 Receiver
Audio problem with B&K AVR507
My receiver no longer senses the optical audio inputs. When I switch to any of them I get nothing. I hooked up the analog set (white and red) and it now works but you have to switch inputs a couple of times before it does....and no Dolby Digital any longer when available. It use to make a switching sound when you went from one input to another but it doesn't any longer. I have an extensive electronics background and could replace components if I knew what to replace. Any help would be appreciated....the unit is only a couple of years old and heat is not an issue.
  • 2 more comments
  • Anonymous Nov 07, 2007
    I have the exact same problem with my AVR 307. Just talked to B&K and they are familiar with the problem. Send it to them and they will make the fix for no charge. Inconvenient but at least you'll get the Dolby Digital sound. I'm sending mine off today.
    I did a hard reset...meaning I unplugged the unit and reset it. It has worked fine ever since.
  • Anonymous Nov 25, 2007
    My B&K AVR507 creates no sound "link" - it has a "Please Wait" sign with no start up. I have tried using the direct remote, rather than my universal remote, with no luck. It interlinks with my Pioneer Plasma monitor. There is no problem with the Pioneer screen, just no sound.
  • masgab Sep 01, 2008
    I have only a muffled base sound coming thru, no otther sounds can be heard. I have unpluged the unit and nothing seems to work. What now?
I have the exact same problem with my AVR 307. Called B&K and they are familiar with the problem. Send it to them and they will upgrade your unit for no charge.
Posted on Nov 07, 2007
SOURCE:
Hi, when I plug my TV's optical out into the Nakamichi AV8's optical input, and switch to "DVD/Optical" (after hitting "Digital Input" buttno) ... no sound comes out. I have...
Maybe assign it?
If the digital TV-related audio actually originates elsewhere (Cable Box?) you could skip the TV and use the Cable Box as the audio source. Nothing is gained by flinging an audio or video signal around the room to be handled (but not improved) by any device. I have no video entering my receiver and nothing but bare bones analog audio going to my TV in case I want to just watch the news or something else lo-fi.
Jul 14, 2011 | Nakamichi AV-8 5.1 Channels Receiver
Trying to hook up tv to JVC RX-315 and not sure what to hook up where
Hi,here is my simple solution...
If you want to listen your TV on your Stereo system thru your receiver,
** you need to connect "Audio Output " RCA jacks or "Optic cable output" of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver ( except Phone ) or "Optic Cable input"
** than just switch to respective mode on RECEIVER corresponding your RCA or Optic connection..
There you go..Your TV sound is on the Receiver..By this means whatever you watch on the
TV (
tuner, satellite , Xbox ) ,it's sound will come thru your stereo..
Hope this helps!
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 24, 2011 | JVC Audio Players & Recorders
Is the digital optical socket at the back of mySony MHC ZX30AV a digital in or a digital out or both way?
It should be the input since the receiver is acting as the audio amplifier. It wouldn't make sense for this type of unit to output optical audio.
Mar 24, 2011 | Audio Players & Recorders
Hooking up optical input output
What kind ot TV?
Not sure what you mean by all signals.
Think about this: if your TV had any AUDIO capabilities that were superior to your REAL audio components, why would you need them?
The TV is the end of the line. Wouldn't it make more sense to get your TV-related audio as close to the source as possible? Your BD, DVD, cable and satellite all have high end audio outputs just begging for a place in the Pioneer.
Mar 20, 2010 | Pioneer VSX-D557
Digital optical output for technics 5.1 surround sound receiver
I went to the HDTV plasma manual. It stated the only way the digital optical audio output would work (from this TV) was to go to the menu, select audio and turn off the TV speakers. Basically, it had nothing to do with the technics receiver.
Sep 16, 2009 | Technics SA-DX930 Receiver
I have a 50 incch samsung tv with samsung surrond sound/receiver/dvd player. I have no voices when we play a dvd but the music plays what is wrong
You need to have the audio from the DVD player hooked up to the same input path on the receiver.(if your running video thru the receiver) DVD audio should be hooked up to either an analog input (RCA cables) or Digital input like Digital Coaxial or Optical. Next to where you are plugging in these cables will be writing like "DVD optical" or "DVD digital". Then, make sure you switch the input of the receiver to "DVD" then it should work fine. If you still have problems post a comment and I will help some more. Hope this helps
Jun 14, 2009 | Audio Players & Recorders
Lose audio unless projector is on or unplugging hdmi cable from sharp xr-32x projector. works fine when watching projector
Your receiver is sensing the video source. Try using optical, or coaxial digital audio for an input, this may work.
May 11, 2009 | Yamaha HTR-6160 Receiver
DVD optical/TOSLINK input no longer working
If it's only the DVD input, and you had tested it systematically, like you'd stated, then the input connector could be loose or defective.
iTritek Solutions
www.itritek.com
Mar 24, 2008 | Panasonic SA-XR45S 5.1 Channels Receiver
VSX D511 No input select
I am getting no sound via my optical cable input. The back of the AMP says that the optical is TV/SAT but i can't change the input to digital it will only go to analog. DVD player is set to Bitstream all dvd options set to DTS, but still no sound going through. Any help would be apprecaited
Jan 29, 2008 | Pioneer VSX-D511 Receiver
Hooking up a sony playstation 3 with digital optical cable
Here's one solution, if you have an audio output from your tv, you can go from the audio output on your tv to the audio input on your receiver that way anything that is playing on your tv for example, playstation 3, dvd player etc. Anything playing on your tv will have audio on your onkyo home theater system. The other thing I would try if you want to hook ps3 directly to receiver is go to your connection settings on your ps3 menu and change your connection method to digital optical cable.
Dec 27, 2007 | Onkyo HT-S790S System
B&K AVR-507 Receiver Logo
979 people viewed this question
Top B&K Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
 Grubhead
Grubhead
rjivaro
Are you a B&K Audio Player and Recorder Expert? Answer questions, earn points and help others
